void i2c_init(void)
SCL_Pin_SET; //PD0 高
SDA_Pin_SET; //PD1 高
SCL_DDR_OUT; //PD0 输出
SDA_DDR_OUT; //PD1 输出
void i2c_start(void)
SDA_DDR_OUT;//PD1 输出
SDA_Pin_SET;
SCL_Pin_SET;
DelayUS(1);
SDA_Pin_CLR;
DelayUS(1);
SCL_Pin_CLR;
DelayUS(1);
void i2c_stop(void)
SDA_Pin_CLR;
DelayUS(1);
SCL_Pin_SET;
DelayUS(1);
SDA_Pin_SET;
DelayUS(1);
void i2c_write(unsigned char data)
unsigned char i;//re_ack
//re_ack=0;
SDA_DDR_OUT;//PD1 数据输出
for(i=0;i<8;i++) // 输出8位数据
if(data&0x80) {SDA_Pin_SET;}
else {SDA_Pin_CLR;}
SCL_Pin_SET;
DelayUS(1);
data<<=1;
DelayUS(1);
SCL_Pin_CLR;
DelayUS(1);
SDA_DDR_IN;//PD1 数据输入
SDA_Pin_SET;//上拉
DelayUS(0);
SCL_Pin_SET; // 接收应答
//DelayUS(1);
//if(SDA_Dat) re_ack=1;
DelayUS(1);
SCL_Pin_CLR;
DelayUS(1);
//return re_ack;
unsigned char i2c_read(unsigned char ACK)
unsigned char i,data;
//SDA_Pin_SET;//上拉
SDA_Pin_CLR;//不上拉
data=0;
for(i=0;i<8;i++) // 输入8位数据
SCL_Pin_SET;
DelayUS(1);
data<<=1;
if(SDA_Dat) data++; // 一般
DelayUS(1);
SCL_Pin_CLR;
DelayUS(1);
if(ACK==0)SDA_Pin_SET;
else SDA_Pin_CLR;
DelayUS(1);
SCL_Pin_SET; // 发出无效应答
DelayUS(1);
DelayUS(1);
SCL_Pin_CLR;
DelayUS(1);
return(data);
void DS3501_Write_Byte(unsigned char addr, unsigned char data )
i2c_start();
i2c_write( 0x50 );
i2c_write( addr );
i2c_write( data );
i2c_stop();
unsigned char DS3501_Read_Byte(unsigned char addr )
unsigned char re;
i2c_start();
i2c_write( 0x50 );
i2c_write( addr );
i2c_start();
i2c_write( 0x51 );
re =i2c_read( 0 );
i2c_stop();
return re;
只能写00h,反应正常,其他位置写不了也读不出,温度也是0,,真心请教,这有什么诀窍吗?
