根据weebee的例子改了一下。我每次发送 FE 02 41 80 01 01 00.(这里的CM0 CM1是在另一个例子里看来的,不知道是什么意思) 1S发一次,协调器接到串口时间之后,把数据广播出去。发送数据一多,协调器就再也收不到数据了。
不知道是什么原因。求大神指教。
- void MT_UartProcessZToolData ( uint8 port, uint8 event )
- uint8 ch;
- uint8 bytesInRxBuffer;
- (void)event; // Intentionally unreferenced parameter
- while (Hal_UART_RxBufLen(port))
- HalUARTRead (port, &ch, 1);
- //HalLedSet(HAL_LED_1,HAL_LED_MODE_TOGGLE);
- switch (state)
- case SOP_STATE:
- if (ch == MT_UART_SOF)
- state = LEN_STATE;
- break;
- case LEN_STATE:
- LEN_Token = ch;
- tempDataLen = 0;
- /* Allocate memory for the data */
- pMsg = (mtOSALSerialData_t *)osal_msg_allocate( sizeof ( mtOSALSerialData_t ) +
- MT_RPC_FRAME_HDR_SZ + LEN_Token );
- if (pMsg)
- /* Fill up what we can */
- pMsg->hdr.event = CMD_SERIAL_MSG;
- pMsg->msg = (uint8*)(pMsg+1);
- pMsg->msg[MT_RPC_POS_LEN] = LEN_Token;
- state = CMD_STATE1;
- else
- state = SOP_STATE;
- return;
- break;
- case CMD_STATE1:
- pMsg->msg[MT_RPC_POS_CMD0] = ch;
- state = CMD_STATE2;
- break;
- case CMD_STATE2:
- pMsg->msg[MT_RPC_POS_CMD1] = ch;
- /* If there is no data, skip to FCS state */
- if (LEN_Token)
- state = DATA_STATE;
- else
- state = FCS_STATE;
- break;
- case DATA_STATE:
- /* Fill in the buffer the first byte of the data */
- pMsg->msg[MT_RPC_FRAME_HDR_SZ + tempDataLen++] = ch;
- /* Check number of bytes left in the Rx buffer */
- bytesInRxBuffer = Hal_UART_RxBufLen(port);
- /* If the remain of the data is there, read them all, otherwise, just read enough */
- if (bytesInRxBuffer <= LEN_Token - tempDataLen)
- HalUARTRead (port, &pMsg->msg[MT_RPC_FRAME_HDR_SZ + tempDataLen], bytesInRxBuffer);
- tempDataLen += bytesInRxBuffer;
- else
- HalUARTRead (port, &pMsg->msg[MT_RPC_FRAME_HDR_SZ + tempDataLen], LEN_Token - tempDataLen);
- tempDataLen += (LEN_Token - tempDataLen);
- /* If number of bytes read is equal to data length, time to move on to FCS */
- if ( tempDataLen == LEN_Token )
- break;
- case FCS_STATE:
- FSC_Token = ch;
- /* Make sure it's correct */
- //if ((MT_UartCalcFCS ((uint8*)&pMsg->msg[0], MT_RPC_FRAME_HDR_SZ + LEN_Token) == FSC_Token))
- osal_msg_send( App_TaskID, (byte *)pMsg );
- // else
- /* deallocate the msg */
- // osal_msg_deallocate ( (uint8 *)pMsg );
- /* Reset the state, send or discard the buffers at this point */
- break;
- default:
- break;
调试发现下面的提示串口输出代码,只要都注释掉,就很容易就死掉了。
放着就能正常工作挺久。
- void SampleApp_SerialCMD(mtOSALSerialData_t *cmdMsg)
- uint8 i,len,*str=NULL; //len有用数据长度
- str=cmdMsg->msg; //指向数据开头
- len=*str; //msg里的第1个字节代表后面的数据长度
- /********打印出串口接收到的数据,用于提示*********/
- //Onboard_wait(300);
- //for(i=0;i<=len+2;i++)
- //HalUARTWrite(0,str+i,1 );
- HalUARTWrite(0,"\n",1 );//换行
- HalLedSet(HAL_LED_1,HAL_LED_MODE_TOGGLE);
- /*******发送出去***参考网蜂 1小时无线数据传输教程*********/
- if ( AF_DataRequest( &SampleApp_Periodic_DstAddr, &SampleApp_epDesc,
- SAMPLEAPP_PERIODIC_CLUSTERID,//自己定义一个
- len+3, // 数据长度
- str, //数据内容
- &SampleApp_TransID,
- AF_DISCV_ROUTE,
- AF_DEFAULT_RADIUS ) == afStatus_SUCCESS )
- else
- // Error occurred in request to send.
复制代码 |
