发表于 2015-5-28 17:24:24
代码我调试过,输出的NAL数据和win32下完整显示视频的数据是一致的。
- http://blog.csdn.net/jasonwang1002/article/details/12094419
- // MPEG2RTP.h
- #include <stdio.h>
- #include <stdlib.h>
- #include <string.h>
- #include <sys/socket.h>
- //#include "mem.h"
- #define PACKET_BUFFER_END (unsigned int)0x00000000
- #define MAX_RTP_PKT_LENGTH 1400
- //#define DEST_IP "192.168.1.110"
- #define DEST_IP "202.112.157.24"
- #define DEST_PORT 24444
- #define H264 96
- typedef int SOCKET;
- typedef struct
- /**//* byte 0 */
- unsigned char csrc_len:4; /**//* expect 0 */
- unsigned char extension:1; /**//* expect 1, see RTP_OP below */
- unsigned char padding:1; /**//* expect 0 */
- unsigned char version:2; /**//* expect 2 */
- /**//* byte 1 */
- unsigned char payload:7; /**//* RTP_PAYLOAD_RTSP */
- unsigned char marker:1; /**//* expect 1 */
- /**//* bytes 2, 3 */
- unsigned short seq_no;
- /**//* bytes 4-7 */
- unsigned long timestamp;
- /**//* bytes 8-11 */
- unsigned long ssrc; /**//* stream number is used here. */
- } RTP_FIXED_HEADER;
- typedef struct {
- //byte 0
- unsigned char TYPE:5;
- unsigned char NRI:2;
- unsigned char F:1;
- } NALU_HEADER; /**//* 1 BYTES */
- typedef struct {
- //byte 0
- } FU_INDICATOR; /**//* 1 BYTES */
- typedef struct {
- //byte 0
- unsigned char R:1;
- unsigned char E:1;
- unsigned char S:1;
- } FU_HEADER; /**//* 1 BYTES */
- //BOOL InitWinsock();
- // NALDecoder.cpp : Defines the entry point for the console application.
- #include <memory.h>
- #include "h264.h"
- //add this to 声明 inet_addr
- #include <arpa/inet.h>
- #include <sys/types.h>
- #include <netinet/in.h>
- typedef struct
- int startcodeprefix_len; //! 4 for parameter sets and first slice in picture, 3 for everything else (suggested)
- unsigned len; //! Length of the NAL unit (Excluding the start code, which does not belong to the NALU)
- unsigned max_size; //! Nal Unit Buffer size
- int forbidden_bit; //! should be always FALSE
- int nal_reference_idc; //! NALU_PRIORITY_xxxx
- int nal_unit_type; //! NALU_TYPE_xxxx
- char *buf; //! contains the first byte followed by the EBSP
- unsigned short lost_packets; //! true, if packet loss is detected
- } NALU_t;
- FILE *bits = NULL; //!< the bit stream file
- static int FindStartCode2 (unsigned char *Buf);//查找开始字符0x000001
- static int FindStartCode3 (unsigned char *Buf);//查找开始字符0x00000001
- static void dumpnal (NALU_t *nal);
- //static bool flag = true;
- static int info2=0, info3=0;
- RTP_FIXED_HEADER *rtp_hdr;
- NALU_HEADER *nalu_hdr;
- FU_INDICATOR *fu_ind;
- FU_HEADER *fu_hdr;
- /*BOOL InitWinsock()
- int Error;
- WORD VersionRequested;
- WSADATA WsaData;
- VersionRequested=MAKEWORD(2,2);
- Error=WSAStartup(VersionRequested,&WsaData); //启动WinSock2
- if(Error!=0)
- return FALSE;
- else
- if(LOBYTE(WsaData.wVersion)!=2||HIBYTE(WsaData.wHighVersion)!=2)
- WSACleanup();
- return FALSE;
- return TRUE;
- //为NALU_t结构体分配内存空间
- NALU_t *AllocNALU(int buffersize)
- NALU_t *n;
- if ((n = (NALU_t*)calloc (1, sizeof (NALU_t))) == NULL)
- printf("AllocNALU: n");
- exit(0);
- n->max_size=buffersize;
- void *calloc(size_t n, size_t size);
- 功 能: 在内存的动态存储区中分配n个长度为size的连续空间,函数返回一个指向分配起始地址的指针;如果分配不成功,返回NULL。
- calloc在动态分配完内存后,自动初始化该内存空间为零,而malloc不初始化,里边数据是随机的垃圾数据。
- if ((n->buf = (char*)calloc (buffersize, sizeof (char))) == NULL)
- free (n);
- printf ("AllocNALU: n->buf");
- exit(0);
- return n;
- //释放
- void FreeNALU(NALU_t *n)
- if (n)
- if (n->buf)
- free(n->buf);
- n->buf=NULL;
- free (n);
- void OpenBitstreamFile (char *fn)
- if (NULL == (bits=fopen(fn, "rb")))
- printf("open file error\n");
- exit(0);
- //这个函数输入为一个NAL结构体,主要功能为得到一个完整的NALU并保存在NALU_t的buf中,获取他的长度,填充F,IDC,TYPE位。
- //并且返回两个开始字符之间间隔的字节数,即包含有前缀的NALU的长度
- int GetAnnexbNALU (NALU_t *nalu)
- int pos = 0;
- int StartCodeFound, rewind;
- unsigned char *Buf;
- if ((Buf = (unsigned char*)calloc (nalu->max_size , sizeof(char))) == NULL)
- printf ("GetAnnexbNALU: Could not allocate Buf memory\n");
- nalu->startcodeprefix_len=3;//初始化码流序列的开始字符为3个字节
- /*fread是一个函数。从一个文件流中读数据,最多读取count个元素,每个元素size字节,如果调用成功返回实际读取到的元素个数,如果不成功或读到文件末尾返回 0。*/
- if (3 != fread (Buf, 1, 3, bits))//从码流中读3个字节
- free(Buf);
- return 0;
- info2 = FindStartCode2 (Buf);//判断是否为0x000001
- if(info2 != 1)
- //如果不是,再读一个字节
- if(1 != fread(Buf+3, 1, 1, bits))//读一个字节
- free(Buf);
- return 0;
- info3 = FindStartCode3 (Buf);//判断是否为0x00000001
- if (info3 != 1)//如果不是,返回-1
- free(Buf);
- return -1;
- else
- //如果是0x00000001,得到开始前缀为4个字节
- pos = 4;
- nalu->startcodeprefix_len = 4;
- else
- //如果是0x000001,得到开始前缀为3个字节
- nalu->startcodeprefix_len = 3;
- pos = 3;
- //查找下一个开始字符的标志位
- StartCodeFound = 0;
- info2 = 0;
- info3 = 0;
- while (!StartCodeFound)
- /*如果文件结束,则返回非0值,否则返回0,文件结束符只能被clearerr()清除。yy*/
- if (feof (bits))//判断是否到了文件尾
- nalu->len = (pos-1)-nalu->startcodeprefix_len;
- /*void *memcpy(void *dest, const void *src, size_t n);
- 从源src所指的内存地址的起始位置开始拷贝n个字节到目标dest所指的内存地址的起始yy*/
- memcpy (nalu->buf, &Buf[nalu->startcodeprefix_len], nalu->len);
- nalu->forbidden_bit = nalu->buf[0] & 0x80; //1 bit
- nalu->nal_reference_idc = nalu->buf[0] & 0x60; // 2 bit
- nalu->nal_unit_type = (nalu->buf[0]) & 0x1f;// 5 bit
- free(Buf);
- return pos-1;
- Buf[pos++] = fgetc (bits);//读一个字节到BUF中
- info3 = FindStartCode3(&Buf[pos-4]);//判断是否为0x00000001
- if(info3 != 1)
- info2 = FindStartCode2(&Buf[pos-3]);//判断是否为0x000001
- StartCodeFound = (info2 == 1 || info3 == 1);
- // Here, we have found another start code (and read length of startcode bytes more than we should
- // have. Hence, go back in the file
- (表达式)? x : y ;首先计算表达式的值,若为ture,则"(表达式)? x : y "返回x;否则返回y.yy
- rewind = (info3 == 1)? -4 : -3;
- int fseek(FILE *stream, long offset, int fromwhere);函数设置文件指针stream的位置。
- 如果执行成功,stream将指向以fromwhere为基准,偏移offset(指针偏移量)个字节的位置,函数返回0。如果执行失败(比如offset超过文件自身大小),则不改变stream指向的位置,函数返回一个非0值
- 第一个参数file指针
- 第二个参数移动的偏移量
- 第三个参数移动到哪里
- 分别用3个宏
- SEEK_SET 既0 文件开头
- SEEK_CUR 既1 文件当前位置
- SEEK_END 既2 文件结尾
- 但不推荐用数字 最好用宏
- 简言之:
- fseek(fp,100L,SEEK_SET);把fp指针移动到离文件开头100字节处;
- fseek(fp,100L,SEEK_CUR);把fp指针移动到离文件当前位置100字节处;
- fseek(fp,100L,SEEK_END);把fp指针退回到离文件结尾100字节处。
- 此函数常用来计算流的长度:
- int filesize = fseek( fp, 0, SEEK_END );
- fseek( fp, 0, SEEK_SET );
- if (0 != fseek (bits, rewind, SEEK_CUR))//把文件指针指向前一个NALU的末尾
- free(Buf);
- printf("GetAnnexbNALU: Cannot fseek in the bit stream file");
- // Here the Start code, the complete NALU, and the next start code is in the Buf.
- // The size of Buf is pos, pos+rewind are the number of bytes excluding the next
- // start code, and (pos+rewind)-startcodeprefix_len is the size of the NALU excluding the start code
- nalu->len = (pos+rewind)-nalu->startcodeprefix_len;
- memcpy (nalu->buf, &Buf[nalu->startcodeprefix_len], nalu->len);//拷贝一个完整NALU,不拷贝起始前缀0x000001或0x00000001
- free(Buf);
- return (pos+rewind);//返回两个开始字符之间间隔的字节数,即包含有前缀的NALU的长度
- //输出NALU长度和TYPE
- void dump(NALU_t *n)
- if (!n)return;
- //printf("a new nal:");
- printf(" len: %d ", n->len);
- printf("nal_unit_type: %x\n", n->nal_unit_type);
- //added by yy 输出NAL单元
- dumpnal(n);
- printf("\n");
- int main(int argc, char* argv[])
- //FILE *stream;
- //stream=fopen("Test.264", "wb");
- OpenBitstreamFile("./video-264/test1.264");//打开264文件,并将文件指针赋给bits,在此修改文件名实现打开别的264文件。
- NALU_t *n;
- char* nalu_payload;
- char sendbuf[1500];
- unsigned short seq_num =0;
- //printf("seq_num=%d\n",seq_num);//added by
- int bytes=0;
- //InitWinsock(); //初始化套接字库
- SOCKET socket1;
- struct sockaddr_in server;
- int len =sizeof(server);
- float framerate=30; // win下为15
- unsigned int timestamp_increase=0,ts_current=0;
- timestamp_increase=(unsigned int)(90000.0 / framerate); //+0.5);
- server.sin_family=AF_INET;
- server.sin_port=htons(DEST_PORT);
- server.sin_addr.s_addr=inet_addr(DEST_IP);
- socket1=socket(AF_INET,SOCK_DGRAM,0);
- connect(socket1, (const struct sockaddr *)&server, len) ;//申请UDP套接字
- n = AllocNALU(8000000);//为结构体nalu_t及其成员buf分配空间。返回值为指向nalu_t存储空间的指针
- //added by yy
- // int test=feof(bits);
- while(!feof(bits))
- GetAnnexbNALU(n);//每执行一次,文件的指针指向本次找到的NALU的末尾,下一个位置即为下个NALU的起始码0x000001
- dump(n);//输出NALU长度和TYPE
- memset(sendbuf,0,1500);//清空sendbuf;此时会将上次的时间戳清空,因此需要ts_current来保存上次的时间戳值
- //rtp固定包头,为12字节,该句将sendbuf[0]的地址赋给rtp_hdr,以后对rtp_hdr的写入操作将直接写入sendbuf。
- rtp_hdr =(RTP_FIXED_HEADER*)&sendbuf[0];
- //设置RTP HEADER,
- rtp_hdr->payload = H264; //负载类型号,
- rtp_hdr->version = 2; //版本号,此版本固定为2
- rtp_hdr->marker = 0; //标志位,由具体协议规定其值。
- rtp_hdr->ssrc = htonl(10); //随机指定为10,并且在本RTP会话中全局唯一
- // 当一个NALU小于1400字节的时候,采用一个单RTP包发送
- if(n->len<=1400)
- //设置rtp M 位;
- rtp_hdr->marker=1;
- rtp_hdr->seq_no = htons(seq_num ++); //序列号,每发送一个RTP包增1
- //设置NALU HEADER,并将这个HEADER填入sendbuf[12]
- nalu_hdr =(NALU_HEADER*)&sendbuf[12]; //将sendbuf[12]的地址赋给nalu_hdr,之后对nalu_hdr的写入就将写入sendbuf中;
- nalu_hdr->F=n->forbidden_bit;
- nalu_hdr->NRI=n->nal_reference_idc>>5;//有效数据在n->nal_reference_idc的第6,7位,需要右移5位才能将其值赋给nalu_hdr->NRI。
- nalu_hdr->TYPE=n->nal_unit_type;
- nalu_payload=&sendbuf[13];//同理将sendbuf[13]赋给nalu_payload
- memcpy(nalu_payload,n->buf+1,n->len-1);//去掉nalu头的nalu剩余内容写入sendbuf[13]开始的字符串。
- ts_current=ts_current+timestamp_increase;
- rtp_hdr->timestamp=htonl(ts_current);
- bytes=n->len + 13 ; //获得sendbuf的长度,为nalu的长度(包含NALU头但除去起始前缀)加上rtp_header的固定长度12字节
- send( socket1, sendbuf, bytes, 0 );//发送rtp包
- // printf("\nseq_no:%d\n",rtp_hdr->seq_no);
- //sleep(1);
- //fwrite(sendbuf,bytes, 1, stream);
- else if(n->len>1400)
- //得到该nalu需要用多少长度为1400字节的RTP包来发送
- int k=0,l=0;
- k=n->len/1400;//需要k个1400字节的RTP包
- l=n->len%1400;//最后一个RTP包的需要装载的字节数
- int t=0;//用于指示当前发送的是第几个分片RTP包
- while(t<=k)
- if(!t)//发送一个需要分片的NALU的第一个分片,置FU HEADER的S位
- //设置rtp M 位;
- rtp_hdr->marker=0;
- //设置FU INDICATOR,并将这个HEADER填入sendbuf[12]
- fu_ind =(FU_INDICATOR*)&sendbuf[12]; //将sendbuf[12]的地址赋给fu_ind,之后对fu_ind的写入就将写入sendbuf中;
- fu_ind->F=n->forbidden_bit;
- fu_ind->NRI=n->nal_reference_idc>>5;
- fu_ind->TYPE=28;
- //设置FU HEADER,并将这个HEADER填入sendbuf[13]
- fu_hdr =(FU_HEADER*)&sendbuf[13];
- fu_hdr->E=0;
- fu_hdr->R=0;
- fu_hdr->S=1;
- fu_hdr->TYPE=n->nal_unit_type;
- nalu_payload=&sendbuf[14];//同理将sendbuf[14]赋给nalu_payload
- memcpy(nalu_payload,n->buf+1,1400);//去掉NALU头
- bytes=1400+14; //获得sendbuf的长度,为nalu的长度(除去起始前缀和NALU头)加上rtp_header,fu_ind,fu_hdr的固定长度14字节
- //sleep(1);
- t++;
- //发送一个需要分片的NALU的非第一个分片,清零FU HEADER的S位,如果该分片是该NALU的最后一个分片,置FU HEADER的E位
- else if(k==t)//发送的是最后一个分片,注意最后一个分片的长度可能超过1400字节(当l>1386时)。
- //设置rtp M 位;当前传输的是最后一个分片时该位置1
- fu_ind->TYPE=28;
- fu_hdr->R=0;
- fu_hdr->S=0;
- fu_hdr->E=1;
- nalu_payload=&sendbuf[14];//同理将sendbuf[14]的地址赋给nalu_payload
- memcpy(nalu_payload,n->buf+t*1400+1,l-1);//将nalu最后剩余的l-1(去掉了一个字节的NALU头)字节内容写入sendbuf[14]开始的字符串。
- bytes=l-1+14; //获得sendbuf的长度,为剩余nalu的长度l-1加上rtp_header,FU_INDICATOR,FU_HEADER三个包头共14字节
- t++;
- //sleep(1);
- else if(t<k&&0!=t)
- //设置rtp M 位;
- fu_ind->TYPE=28;
- //fu_hdr->E=0;
- fu_hdr->R=0;
- fu_hdr->S=0;
- fu_hdr->E=0;
- memcpy(nalu_payload,n->buf+t*1400+1,1400);//去掉起始前缀的nalu剩余内容写入sendbuf[14]开始的字符串。
- bytes=1400+14; //获得sendbuf的长度,为nalu的长度(除去原NALU头)加上rtp_header,fu_ind,fu_hdr的固定长度14字节
- //sleep(1);
- t++;
- //usleep(40000);
- FreeNALU(n);
- return 0;
- if(Buf[0]!=0 || Buf[1]!=0 || Buf[2] !=1) return 0; //判断是否为0x000001,如果是返回1
- else return 1;
- if(Buf[0]!=0 || Buf[1]!=0 || Buf[2] !=0 || Buf[3] !=1) return 0;//判断是否为0x00000001,如果是返回1
- else return 1;
- // 打印前面 NAL个字节
- int i;
- for (i = 0; i < nal->len; i++) {
- printf( " %02x ", (unsigned char)nal->buf[i]);
