Freescale的无线方案中有Qi v1.2吗?
引用:
Qi v1.2 will make it possible to charge devices from a
greater distance, meaning you don’t need to physically
leave your phone on a charging pad. The new chargers
reportedly work at up to 45mm away, compared to the
7mm allowed by earlier models. Qi v1.1 also functions
at up to 30mm away, and the WPC notes that v1.1 and
1.2 are compatible with one another.
WPC also revealed that the updated Qi standard could
be used to power kitchen appliances at up to 2,000
watts, potentially reducing the need for multiple outlets
in every room.
45毫米,2000瓦,厨房可以用--- 表示怀疑。
另:
坛里, 有做Qi v1.2产品的公司吗? 或做Qi v1.1经验,有能力做Qi v1.2的吗? 考虑定制合作
如果天空是黑暗的,那就摸黑生存;
如果发出声音是危险的,那就保持沉默;
如果自觉无力发光,那就蜷伏于牆角。
但是,不要习惯了黑暗就为黑暗辩护;
也不要为自己的苟且而得意;
不要嘲讽那些比自己更勇敢的人。
我们可以卑微如尘土,但不可扭曲如蛆虫。
