回复: 83
Source insight 3.5.0076 最新版本
发表于 2015-3-17 00:20:04 | 显示全部楼层 |阅读模式
Version 3.5.0076 built on Feb 19, 2015.
下载地址:http://www.sourceinsight.com/distribute/Si3576Setup.exe
官网:http://www.sourceinsight.com/
序 号:SI3US-361500-17409
发表于 2015-3-17 00:56:14 | 显示全部楼层
Version 3.5.0076 built on Feb 19, 2015.   这货还有更新呢,不知道汉字注解的问题解决没,看代码利器
发表于 2015-3-17 06:17:46 | 显示全部楼层
这么多年居然更新了
发表于 2015-3-17 06:34:50 来自手机 | 显示全部楼层
神器升级了
发表于 2015-3-17 08:15:00 | 显示全部楼层
mark 一下,source insight。
发表于 2015-3-17 08:29:24 | 显示全部楼层
没看到有什么二样
发表于 2015-3-17 08:36:15 | 显示全部楼层
OurWay 发表于 2015-3-17 00:56
Version 3.5.0076 built on Feb 19, 2015.   这货还有更新呢,不知道汉字注解的问题解决没,看代码利器 ...
汉字还是那鸟样。
使用了比较久,没见到与原来不同。。。
发表于 2015-3-17 08:39:37 | 显示全部楼层
一早就看到好消息,谢谢LZ,立马更新下~
发表于 2015-3-17 08:43:21 | 显示全部楼层
是不是只是兼容了WIN8而已啊?
发表于 2015-3-17 08:44:11 | 显示全部楼层
WIN8 一直可以用哦
发表于 2015-3-17 08:51:44 | 显示全部楼层
不知道ctrl+F死机的问题是不是真的解决了,以前0072说解决了这个问题,但是用的时候还是死机
出425入0汤圆
发表于 2015-3-17 08:51:57 | 显示全部楼层
非常好的编辑软件,我以为不再有更新了。
发表于 2015-3-17 08:52:21 | 显示全部楼层
更新了那些功能呢
发表于 2015-3-17 09:05:40 | 显示全部楼层
这货上次更新是什么时候了,好像很久没更新了,好惊喜啊
出425入0汤圆
发表于 2015-3-17 09:13:47 | 显示全部楼层
Version 3.50.0076 - Feb 19, 2015
Fix: Draft View was showing source code in monochrome. Draft view is supposed to show only color formatting, but not font or font size changes.
Version 3.50.0075 - Feb 11, 2015
Fix: Crash when searching with certain regular expression patterns.
Fix: Crash when synchronizing projects and building the search index, which was caused by very long identifier names.
Fix: When using Search and Replace and the replacement string was empty, then the search would skip over the next character.
Fix: Crash in some cases during project synchronization if an error occurred updating the symbol database for a particular source file. It now skips the problem file and continues with synchronization.
Fix: Searching with the "whole words only" option would not find matches if the search pattern contained multiple words. For example, searching for "dog cat" with "whole words only" would fail to find some instances.
Fix: Crash could occur if a display Style contained both a "font size" AND a "font scale" value.
Fix: Crash could occur when exiting Source Insight on Window 8/8.1.
Update: The C/C++ token macros (in the c.tom file) were updated with more definitions.
Update: Code signing certificate was renewed.
Change: Switched to InstallShield for the installer program. Be sure to run as an Administrator when you run the setup program.
Change: The default font was changed to Consolas, and the default syntax formatting styles were changed. This only affects fresh installs, so your existing settings won't change. If you want to reset to the new defaults, exit Source Insight. Go to the "Documents\Source Insight\Settings" folder and rename "Global.CF3" to something else. Restart SI.
Change: Several "custom language" extensions are now part of the installation. They get installed into the \languages folder. They are automatically added to the languages list available via Options > Document Options. These files were (and still are) available on our web site at www.sourceinsight.com/public/languages
Change: Some default settings were changed.
Change: Added additional logging and checking during program initialization.
发表于 2015-3-17 09:14:21 | 显示全部楼层
这货竟然更新了。增加了什么新功能
出425入0汤圆
发表于 2015-3-17 09:15:57 | 显示全部楼层
如果中文问题解决就完美了。
发表于 2015-3-17 09:16:57 | 显示全部楼层
嘿嘿,最强的查看源代码软件
发表于 2015-3-17 10:51:27 | 显示全部楼层
汉字还是那鸟样....乱码
+10086
发表于 2015-3-17 13:07:40 | 显示全部楼层
很难得看到这货升一次级
发表于 2015-3-17 14:06:26 | 显示全部楼层
现在用TKSTUDIO  也不错,只是周公 也不更新了,哎
发表于 2015-3-17 15:06:20 | 显示全部楼层
用这么久,还真第一次见到升级
发表于 2015-3-17 15:11:36 | 显示全部楼层
更新就好,谢谢楼主!下载去了。
发表于 2015-3-17 22:19:34 | 显示全部楼层
下载了,感谢楼主分享!~
发表于 2015-3-17 22:42:45 | 显示全部楼层
汉字还是那样,搞得自己习惯英文注释
发表于 2015-3-18 06:32:40 来自手机 | 显示全部楼层
要是哪天出4.0了估计一切都完美了。这么棒的工具不更新真是太可惜了。看linux代码时,对头文件处理有点问题,在驱动里想看module_xxx的定义,出来的总是一堆不同驱动的module_xxx,而找不到头文件的真正定义。要能根据.config文件自动生成仅包含相关功能的浏览数据库就好了
发表于 2015-3-18 07:50:48 | 显示全部楼层
这神器居然升级了
发表于 2015-3-18 09:11:41 | 显示全部楼层
升级了 下载下来看看
发表于 2015-3-18 10:20:55 来自手机 | 显示全部楼层
回头下载,虽然最近程序写的少了
发表于 2015-3-18 11:35:44 来自手机 | 显示全部楼层
千年等一回
发表于 2015-3-18 11:37:32 来自手机 | 显示全部楼层
最关心的是老版本相对路径设置的bug更改了没
发表于 2015-3-18 11:38:09 | 显示全部楼层
神器。谢谢楼主。
发表于 2015-3-18 11:43:53 | 显示全部楼层
升级了,不容易啊
发表于 2015-3-18 13:02:51 | 显示全部楼层
非常好的软件。谢谢!
发表于 2015-3-23 13:20:23 | 显示全部楼层
谢谢,学着用下,还没有用过这个软件.要学的东西挺多的.
发表于 2015-3-23 14:28:21 | 显示全部楼层
还是不支持utf8
发表于 2015-3-23 20:09:51 | 显示全部楼层
看代码神器,就是不知道中文显示的问题有解决没?
出110入109汤圆
发表于 2015-3-23 20:42:54 | 显示全部楼层
升级步子迈得很保守啊
正在用3.5.0029
发表于 2015-3-23 22:11:51 | 显示全部楼层
guolun 发表于 2015-3-17 08:51
非常好的编辑软件,我以为不再有更新了。
优势是阅读和跳转。   编辑?你确定没说错?  编辑简直是一坨屎,惨不忍睹。
出425入0汤圆
发表于 2015-3-24 09:29:32 | 显示全部楼层
huangqi412 发表于 2015-3-23 22:11
优势是阅读和跳转。   编辑?你确定没说错?  编辑简直是一坨屎,惨不忍睹。   ...
我确定没有弄错,我用过的编辑软件不多,从不好用开始排序:IAR, keil,AVR_STUDIO,GCC的PN, source insight。SI让我有“相见恨晚”的感觉。估计你没有怎么用过SI。还有什么比她好的吗?
发表于 2015-3-24 13:59:06 | 显示全部楼层
更新一下电脑上的版本,只用来看代码,写代码用这个还真不习惯。
发表于 2015-3-24 14:02:15 | 显示全部楼层
好东西,以为不更了
发表于 2015-3-26 11:20:04 | 显示全部楼层
正需要,太谢谢了
发表于 2015-4-14 22:38:45 | 显示全部楼层
谢谢,楼主还提供注册码
发表于 2015-4-18 20:59:17 | 显示全部楼层
谢谢楼主分享!
发表于 2015-4-23 18:54:53 | 显示全部楼层
谢谢,刚下载起就用了
发表于 2015-4-23 19:40:29 | 显示全部楼层
mark
发表于 2015-4-23 19:40:49 | 显示全部楼层
mark
发表于 2015-5-10 21:04:26 | 显示全部楼层
下过来试试。
发表于 2015-9-25 12:31:49 | 显示全部楼层
用了很长时间了  很不错的软件
发表于 2015-9-25 15:13:51 | 显示全部楼层
看代码不错的选择,windows上都用这个
发表于 2015-9-29 23:16:08 | 显示全部楼层
更新一下,3.5.0079,更新内容不详。
http://www.sourceinsight.com/distribute/Si3579Setup.exe
发表于 2015-10-8 09:53:01 | 显示全部楼层
用习惯了si
发表于 2015-10-8 11:28:40 | 显示全部楼层
有了新版本3.5.0079,SN有吗?
用老的SN可以吗?
发表于 2015-10-8 11:31:48 | 显示全部楼层
http://www.sourceinsight.com/distribute/Si3579Setup.exe ...
这个最新版本的SN用的是哪个?
发表于 2015-10-8 13:37:42 | 显示全部楼层
SN:SI3US-361500-17409
发表于 2015-10-8 15:01:00 | 显示全部楼层
source insight,以前用过,看看
发表于 2015-10-8 15:05:58 | 显示全部楼层
安装后打开就出现这个弹出窗口
没有机会输入SN啊,请教如何解决?
sourse insight  setup program  在哪里啊,安装目录下也没有找到。
发表于 2015-10-8 15:27:18 | 显示全部楼层
谢谢
我没有卸载旧版本,直接覆盖安装了这个0079版本,也可以直接使用。应该没有什么后遗症吧?
发表于 2015-10-9 13:44:49 | 显示全部楼层
收藏了回去下载
发表于 2015-10-9 14:23:13 | 显示全部楼层
以前有,直接安装后出现58楼的问题。
估计卸载重装没有问题。
发表于 2015-10-9 15:01:53 | 显示全部楼层
安装前得小心对待了。
卸载后,再安装出现一样的问题。估计得把注册表清干净了才行。
用360卸载也不好用呀。
发表于 2015-10-10 10:40:02 | 显示全部楼层
很好用!!谢谢分享!!
发表于 2015-11-4 21:13:17 | 显示全部楼层
谢谢。79版本很配这个SN。最新的已经到81了。
发表于 2016-1-21 22:56:12 | 显示全部楼层
good stuff, thanks for sharing
发表于 2016-2-15 08:43:45 | 显示全部楼层
这是个好东西 ,mark
发表于 2016-2-15 14:52:45 | 显示全部楼层
最新版的0081也可以用,不错
发表于 2016-2-15 22:31:12 | 显示全部楼层
SN到底可不可以用啊
发表于 2016-2-20 17:55:00 | 显示全部楼层
有中文版的么
发表于 2016-4-9 22:29:53 | 显示全部楼层
谢谢分享!
出0入25汤圆
发表于 2016-4-10 08:21:10 | 显示全部楼层
goooooooooood
发表于 2016-4-10 08:39:47 | 显示全部楼层
好软件,一直在用
发表于 2016-4-10 09:10:40 | 显示全部楼层
多谢楼主
发表于 2016-4-10 11:11:47 | 显示全部楼层
下载了,多谢
发表于 2016-4-23 12:42:37 | 显示全部楼层
网上的4.0难道都是假的吗
发表于 2016-7-17 09:58:42 | 显示全部楼层
又发现了一个看代码的神器,多谢楼主分享
发表于 2016-7-17 11:06:24 | 显示全部楼层
好东西,但更新的速度也太慢了。
出110入109汤圆
发表于 2016-8-28 20:58:53 | 显示全部楼层
这货还真有升级推送了!
出10入0汤圆
发表于 2016-9-27 16:24:10 | 显示全部楼层
yu2008 发表于 2015-10-8 15:05
安装后打开就出现这个弹出窗口
没有机会输入SN啊,请教如何解决?
我也碰到过这个,先卸载si,然后regedit删除所有与si有关的注册表项,再重新安装就可以输入注册码了
删除注册表时小心点,搞挂了不负责的哈...
发表于 2016-9-27 17:23:34 | 显示全部楼层
这货竟然更新了
发表于 2016-10-26 16:06:14 | 显示全部楼层
升级推送了!
发表于 2016-10-27 07:22:00 来自手机 | 显示全部楼层
有空装上学习linux 源码去
发表于 2016-11-4 10:44:08 | 显示全部楼层
这个必然要升级了
发表于 2016-11-7 15:14:47 | 显示全部楼层
谢谢  赞!!
GMT+8, 2024-7-23 14:19
