飞思卡尔最新的i.MX 6SoloX处理器,上个月刚发布的,欧比特认为亮点有三:
1.支持异构双核,一个A9处理器+一个M4处理器,可以一个跑Linux,另外一个跑MQX,或者UCOS,或者裸奔。
2.支持双通道QSI,可以使用QSPI NOR FLASH做启动,与一般的SPI FLASH 控制器相比,可以提供4倍的读写速度。
NOR FLASH比常用的NAND 在工业上使用,鲁棒性更好。
3.支持双千兆以太网与PCI-E总线,以太网控制器,相对原来的I.MX6Q上的,做了修改,性能大幅度提升。
另外就支持工业级与汽车级温度范围,可以用在大量工业测控,与汽车电子。
其他特性如下:
•1GHz Cortex-A9 with 512KB L2, 32KB instruction and data caches, NEON SIMD
•200MHz Cortex-M4 with 16KB instruction and data caches, 64KB TCM, MPU and FPU
•Optional Vivante GC400T with 3D/2D acceleration
•32-bit DDR3/LVDDR3/LPDDR2-800 memory interface from each core
•Flexible boot options, including support for DDR QSPI and raw NAND
•Configurable resource domain controller
•Supports asymmetric multiprocessing (AMP)
•Security features like TrustZone, ciphers, eFuses, RNG
•Dual-port gigabit Ethernet audio video bridging (AVB) for quality-of-service with enhanced traffic shaping and packet prioritization
•Multimedia I/O including 24-bit RGB, ASRC audio, S/PDIF, CSI digital camera, and optional analog camera, LVDS, and NTSC
•Industrial I/O including FlexCAN, SPI, UART, I2C, I2S, USB 2.0 host and OTG, IEEE1588, MMC 4.4, SD 3.0, and optional ADC, MLB, and PCIe
•Operating temperature options including -20 to 105°C (consumer @ 1GHz, -40 to 105°C (industrial @ 800MHz), and -40 to 125°C (automotive @ 800MHz)
以上是官方的演示版,以及框图,最下面一个是欧比特设计中的核心板截图。
