发表于 2015-2-26 16:12:13
我觉得还好,跟ST探索套件比,的确是没啥优势,跟ST的综合套件比,我觉得这个价格可以。
ATSAMV71Q21 microcontroller
One mechanical reset button
One power switch button
Two mechanical user pushbuttons
Two yellow user LEDs
Supercap backup
12.0 MHz crystal
32.768 kHz crystal
2 MB SDRAM
2 MB QSPI Flash
IEEE 802.3az 10Base-T/100Base-TX Ethernet RMII PHY
AT24MAC402 256KByte EEPROM with EUI-48 address
Stereo audio codec
External PLL for precise clock generation
Microphone jack
Headphone jack
ATA6561 CAN Transceiver
SD Card connector with SDIO support
Camera interface connector
MediaLB connector
Two Xplained Pro extension headers One Xplained Pro LCD header
Coresight 20 connector for 4-bit ETM
Arduino due compatible shield connectors
External debugger connector
USB interface, device and host mode
Embedded Debugger
Auto-ID for board identification in Atmel Studio
One yellow status LED
One green board power LED
Symbolic debug of complex data types including scope information
Programming and debugging
Data Gateway Interface: SPI, I²C, 4 GPIOs
Virtual COM port (CDC)
External power input (5-14V)
USB powered
Supported with application examples in Atmel Software Framework
跟intel比,这些都是小儿科,去年intel给国内的1000多所高校免费发放30套左右的 Galileo 开发板(每个学校)。我们学校是给了30套。 |
