发表于 2015-3-1 15:16:02
SerialPort 类
- using System;
- using System.IO.Ports;
- using System.Threading;
- public class PortChat
- static bool _continue;
- static SerialPort _serialPort;
- public static void Main()
- string name;
- string message;
- StringComparer stringComparer = StringComparer.OrdinalIgnoreCase;
- Thread readThread = new Thread(Read);
- // Create a new SerialPort object with default settings.
- _serialPort = new SerialPort();
- // Allow the user to set the appropriate properties.
- _serialPort.PortName = SetPortName(_serialPort.PortName);
- _serialPort.BaudRate = SetPortBaudRate(_serialPort.BaudRate);
- _serialPort.Parity = SetPortParity(_serialPort.Parity);
- _serialPort.DataBits = SetPortDataBits(_serialPort.DataBits);
- _serialPort.StopBits = SetPortStopBits(_serialPort.StopBits);
- _serialPort.Handshake = SetPortHandshake(_serialPort.Handshake);
- // Set the read/write timeouts
- _serialPort.ReadTimeout = 500;
- _serialPort.WriteTimeout = 500;
- _serialPort.Open();
- _continue = true;
- readThread.Start();
- Console.Write("Name: ");
- name = Console.ReadLine();
- Console.WriteLine("Type QUIT to exit");
- while (_continue)
- message = Console.ReadLine();
- if (stringComparer.Equals("quit", message))
- _continue = false;
- else
- _serialPort.WriteLine(
- String.Format("<{0}>: {1}", name, message));
- readThread.Join();
- _serialPort.Close();
- public static void Read()
- while (_continue)
- try
- string message = _serialPort.ReadLine();
- Console.WriteLine(message);
- catch (TimeoutException) { }
- // Display Port values and prompt user to enter a port.
- public static string SetPortName(string defaultPortName)
- string portName;
- Console.WriteLine("Available Ports:");
- foreach (string s in SerialPort.GetPortNames())
- Console.WriteLine(" {0}", s);
- Console.Write("Enter COM port value (Default: {0}): ", defaultPortName);
- portName = Console.ReadLine();
- if (portName == "" || !(portName.ToLower()).StartsWith("com"))
- portName = defaultPortName;
- return portName;
- // Display BaudRate values and prompt user to enter a value.
- public static int SetPortBaudRate(int defaultPortBaudRate)
- string baudRate;
- Console.Write("Baud Rate(default:{0}): ", defaultPortBaudRate);
- baudRate = Console.ReadLine();
- if (baudRate == "")
- baudRate = defaultPortBaudRate.ToString();
- return int.Parse(baudRate);
- // Display PortParity values and prompt user to enter a value.
- public static Parity SetPortParity(Parity defaultPortParity)
- string parity;
- Console.WriteLine("Available Parity options:");
- foreach (string s in Enum.GetNames(typeof(Parity)))
- Console.Write("Enter Parity value (Default: {0}):", defaultPortParity.ToString(), true);
- parity = Console.ReadLine();
- if (parity == "")
- parity = defaultPortParity.ToString();
- return (Parity)Enum.Parse(typeof(Parity), parity, true);
- // Display DataBits values and prompt user to enter a value.
- public static int SetPortDataBits(int defaultPortDataBits)
- string dataBits;
- Console.Write("Enter DataBits value (Default: {0}): ", defaultPortDataBits);
- dataBits = Console.ReadLine();
- if (dataBits == "")
- dataBits = defaultPortDataBits.ToString();
- return int.Parse(dataBits.ToUpperInvariant());
- // Display StopBits values and prompt user to enter a value.
- public static StopBits SetPortStopBits(StopBits defaultPortStopBits)
- string stopBits;
- Console.WriteLine("Available StopBits options:");
- foreach (string s in Enum.GetNames(typeof(StopBits)))
- Console.Write("Enter StopBits value (None is not supported and \n" +
- "raises an ArgumentOutOfRangeException. \n (Default: {0}):", defaultPortStopBits.ToString());
- stopBits = Console.ReadLine();
- if (stopBits == "" )
- stopBits = defaultPortStopBits.ToString();
- return (StopBits)Enum.Parse(typeof(StopBits), stopBits, true);
- public static Handshake SetPortHandshake(Handshake defaultPortHandshake)
- string handshake;
- Console.WriteLine("Available Handshake options:");
- foreach (string s in Enum.GetNames(typeof(Handshake)))
- Console.Write("End Handshake value (Default: {0}):", defaultPortHandshake.ToString());
- handshake = Console.ReadLine();
- if (handshake == "")
- handshake = defaultPortHandshake.ToString();
- return (Handshake)Enum.Parse(typeof(Handshake), handshake, true);
