发表于 2015-2-13 15:33:01
U-Boot 2009.08-dirty (Feb 13 2015 - 15:00:33)
CPU: Freescale i.MX6 family TO1.2 at 792 MHz
Thermal sensor with ratio = 180
Temperature: 32 C, calibration data 0x5714bd7d
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock : 66000000Hz
ipg per clock : 66000000Hz
uart clock : 80000000Hz
cspi clock : 60000000Hz
ahb clock : 132000000Hz
axi clock : 264000000Hz
emi_slow clock: 132000000Hz
ddr clock : 528000000Hz
usdhc1 clock : 198000000Hz
usdhc2 clock : 198000000Hz
usdhc3 clock : 198000000Hz
usdhc4 clock : 198000000Hz
nfc clock : 24000000Hz
Board: i.MX6Q-SABRESD: unknown-board Board: 0x63012 [POR ]
Boot Device: SD
I2C: ready
DRAM: 1 GB
MMC: FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3
In: serial
Out: serial
Err: serial
Net: got MAC address from IIM: 00:00:00:00:00:00
FEC0 [PRIME]
Hit any key to stop autoboot: 3 2 1 0
kernel @ 10808000 (4841928)
ramdisk @ 11800000 (496509)
kernel cmdline:
use uboot command line:
console=ttymxc0,115200 init=/init video=mxcfb0:dev=lcd,YSDC-070,if=RGB24 video=mxcfb1:off video=mxcfb2:off fbmem=10M fb0base=0x27b00000 vmalloc=400M androidboot.console=ttymxc0 androidboot.hardware=freescale
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Initializing cgroup subsys cpu
Linux version 3.0.35-06497-gcc45965-dirty (ls8050xgl@ubuntu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #32 SMP PREEMPT Fri Feb 13 15:15:14 CST 2015
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Freescale i.MX 6Quad/DualLite/Solo Sabre-SD Board
Ignoring unrecognised tag 0x54410008
Memory policy: ECC disabled, Data cache writealloc
CPU identified as i.MX6Q, silicon rev 1.2
PERCPU: Embedded 7 pages/cpu @c133e000 s6528 r8192 d13952 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 208128
Kernel command line: console=ttymxc0,115200 init=/init video=mxcfb0:dev=lcd,YSDC-070,if=RGB24 video=mxcfb1:off video=mxcfb2:off fbmem=10M fb0base=0x27b00000 vmalloc=400M androidboot.console=ttymxc0 androidboot.hardware=freescale
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 379MB 378MB 64MB = 821MB total
Memory: 819988k/819988k available, 228588k reserved, 441344K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xfbe00000 - 0xffe00000 ( 64 MB)
vmalloc : 0xd9800000 - 0xf2000000 ( 392 MB)
lowmem : 0xc0000000 - 0xd9000000 ( 400 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.init : 0xc0008000 - 0xc0047000 ( 252 kB)
.text : 0xc0047000 - 0xc0910520 (8998 kB)
.data : 0xc0912000 - 0xc09ac5b0 ( 618 kB)
.bss : 0xc09ac5d4 - 0xc0b348fc (1569 kB)
Preemptible hierarchical RCU implementation.
NR_IRQS:624
MXC GPIO hardware
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
arm_max_freq=1GHz
MXC_Early serial console at MMIO 0x2020000 (options '115200')
bootconsole [ttymxc0] enabled
Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
pid_max: default: 32768 minimum: 301
Security Framework initialized
SELinux: Initializing.
Initializing cgroup subsys debug
Initializing cgroup subsys cpuacct
Initializing cgroup subsys freezer
CPU: Testing write buffer coherency: ok
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
CPU1: Booted secondary processor
CPU2: Booted secondary processor
CPU3: Booted secondary processor
Brought up 4 CPUs
SMP: Total of 4 processors activated (6324.22 BogoMIPS).
print_constraints: dummy:
print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal
print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal
print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal
print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal
print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal
print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal
ram_console: got buffer at 3ff00000, size 100000
ram_console: uncorrectable error in header
ram_console: no valid data in buffer (sig = 0xffffffff)
console [ram-1] enabled
No AHCI save PWR: PDDQ enabled
hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
hw-breakpoint: maximum watchpoint size is 4 bytes.
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x32070000, Cache size: 1048576 B
bio: create slab <bio-0> at 0
mxs-dma mxs-dma-apbh: initialized
print_constraints: VDDA: 2500 mV
print_constraints: VDDIO: 3300 mV
print_constraints: VDDD: 1800 mV
print_constraints: vmmc: 3300 mV
vgaarb: loaded
SCSI subsystem initialized
spi_imx imx6q-ecspi.0: probed
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Freescale USB OTG Driver loaded, $Revision: 1.55 $
mc_pfuze 0-0008: ID: 0,Full lay: 2 ,Metal lay: 1
mc_pfuze 0-0008: FAB: 0 ,FIN: 0
print_constraints: PFUZE100_SW1A: 300 <--> 1875 mV at 1300 mV
print_constraints: PFUZE100_SW1B: 300 <--> 1875 mV at 300 mV
print_constraints: PFUZE100_SW1C: 300 <--> 1875 mV at 1300 mV
print_constraints: PFUZE100_SW2: 800 <--> 3950 mV at 3300 mV
print_constraints: PFUZE100_SW3A: 400 <--> 1975 mV at 1500 mV
print_constraints: PFUZE100_SW3B: 400 <--> 1975 mV at 1500 mV
print_constraints: PFUZE100_SW4: 800 <--> 3950 mV at 3150 mV
print_constraints: PFUZE100_SWBST: 5000 <--> 5150 mV at 5000 mV
print_constraints: PFUZE100_VSNVS: 1200 <--> 3000 mV at 1800 mV
print_constraints: PFUZE100_VREFDDR: at 750 mV
print_constraints: PFUZE100_VGEN1: 800 <--> 1550 mV at 1500 mV
print_constraints: PFUZE100_VGEN2: 800 <--> 1550 mV at 1500 mV
print_constraints: PFUZE100_VGEN3: 1800 <--> 3300 mV at 2500 mV
print_constraints: PFUZE100_VGEN4: 1800 <--> 3300 mV at 1800 mV
print_constraints: PFUZE100_VGEN5: 1800 <--> 3300 mV at 2800 mV
print_constraints: PFUZE100_VGEN6: 1800 <--> 3300 mV at 3300 mV
imx-ipuv3 imx-ipuv3.1: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
MIPI CSI2 driver module loaded
Advanced Linux Sound Architecture Driver Version 1.0.24.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
i2c-core: driver [max17135] using legacy suspend method
i2c-core: driver [max17135] using legacy resume method
Switching to clocksource mxc_timer1
IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
TCP established hash table entries: 65536 (order: 7, 524288 bytes)
TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
TCP: Hash tables configured (established 65536 bind 65536)
TCP reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 0 bytes, default 32
Unpacking initramfs...
Freeing initrd memory: 484K
PMU: registered new PMU device of type 0
Static Power Management for Freescale i.MX6
wait mode is enabled for i.MX6
cpaddr = d9880000 suspend_iram_base=d9928000
PM driver module loaded
iMX6 PCIe PCIe RC mode imx_pcie_pltfm_probe entering.
PCIE: imx_pcie_pltfm_probe start link up.
link up failed, DB_R0:0x001bd700, DB_R1:0x08200000!
IMX PCIe port: link down with power supply 1!
IMX usb wakeup probe
the wakeup pdata is 0xd46efe20
add wake up source irq 75
the wakeup pdata is 0xd46efba0
cpu regulator mode:ldo_bypass
_regulator_get: get() with no identifier
mx6_cpu_regulator_init: failed to get pu regulator
i.MXC CPU frequency driver
audit: initializing netlink socket (disabled)
type=2000 audit(1.900:1): initialized
highmem bounce pool size: 64 pages
ashmem: initialized
NTFS driver 2.1.30 [Flags: R/O].
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.16)
msgmni has been set to 740
SELinux: Registering netfilter hooks
NET: Registered protocol family 38
cryptodev: driver loaded.
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
MIPI DSI driver module loaded
mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver lcd
mxc_sdc_fb mxc_sdc_fb.1: Can't get fb option for mxcfb1!
imx-ipuv3 imx-ipuv3.0: IPU Warning - IPU_INT_STAT_10 = 0x00100000
mxc_sdc_fb mxc_sdc_fb.2: Can't get fb option for mxcfb2!
imx-sdma imx-sdma: loaded firmware 1.1
imx-sdma imx-sdma: initialized
Serial: IMX driver
imx-uart.2: ttymxc2 at MMIO 0x21ec000 (irq = 60) is a IMX
imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
console [ttymxc0] enabled, bootconsole disabled
loop: module loaded
m25p80 spi0.0: unrecognized JEDEC id ffffff
ONFI flash detected
ONFI param page 0 valid
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xda (Micron MT29F2G08ABAEAWP)
gpmi-nand imx6q-gpmi-nand.0: enable asynchronous EDO mode 5
Scanning device for bad blocks
Creating 5 MTD partitions on "gpmi-nand":
0x000000000000-0x000000300000 : "bootloader"
0x000000300000-0x000000500000 : "env"
0x000000500000-0x000000a00000 : "kernel1"
0x000000a00000-0x000000f00000 : "kernel2"
0x000000f00000-0x000010000000 : "rootfs"
GPMI NAND driver registered. (IMX)
vcan: Virtual CAN interface driver
CAN device driver interface
flexcan netdevice driver
FEC Ethernet Driver
fec_enet_mii_bus: probed
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000
fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
add wake up source irq 72
fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200
fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbserial
usbserial: USB Serial Driver core
USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
option: v0.7.2:USB Driver for GSM modems
USB Serial support registered for Qualcomm USB modem
usbcore: registered new interface driver qcserial
ARC USBOTG Device Controller driver (1 August 2005)
android_usb gadget: Mass Storage Function, version: 2009/09/11
android_usb gadget: Number of LUNs=1
lun0: LUN: removable file: (no medium)
Gadget Android: controller 'fsl-usb2-udc' not recognized
android_usb gadget: android_usb ready
Suspend udc for OTG auto detect
USB Host suspend begins
will suspend roothub and its children
ehci_fsl_bus_suspend begins, DR
ehci_fsl_bus_suspend ends, DR
host suspend ends
USB Gadget resume begins
fsl_udc_resume, Wait for wakeup thread finishes
dr_controller_run: udc enter low power mode
USB Gadget resume ends
fsl-usb2-udc: bind to driver android_usb
mousedev: PS/2 mouse device common for all mice
input: gpio-keys as /devices/platform/gpio-keys/input/input0
input: max11801_ts as /devices/platform/imx-i2c.2/i2c-2/2-004b/input/input1
i2c-core: driver [isl29023] using legacy suspend method
i2c-core: driver [isl29023] using legacy resume method
using rtc device, snvs_rtc, for alarms
snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
i2c /dev entries driver
Linux video capture interface: v2.00
ov5642_read_reg:write reg error:reg=300a
camera ov5642 is not found
usb 2-1: new high speed USB device number 2 using fsl-ehci
ov5640_read_reg:write reg error:reg=300a
camera ov5640 is not found
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v1.1.0)
hub 2-1:1.0: USB hub found
hub 2-1:1.0: 4 ports detected
i2c-core: driver [mag3110] using legacy suspend method
i2c-core: driver [mag3110] using legacy resume method
imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
Bluetooth: Virtual HCI driver ver 1.3
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCIATH3K protocol initialized
Bluetooth: Generic Bluetooth USB driver ver 0.6
usbcore: registered new interface driver btusb
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci sdhci-esdhc-imx.1: no write-protect pin available!
mmc0: SDHCI controller on platform [sdhci-esdhc-imx.1] using DMA
mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
VPU initialized
mxc_asrc registered
Galcore version 4.6.9.9754
revserved_memory_account:viv_gpu registerd
Thermal calibration data is 0x5714bd7d
Anatop Thermal registered as thermal_zone0
anatop_thermal_probe: default cooling device is cpufreq!
Registered led device: chg_now_led
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
logger: created 256K log 'log_main'
logger: created 256K log 'log_events'
logger: created 256K log 'log_radio'
logger: created 256K log 'log_system'
usb 2-1.2: new low speed USB device number 3 using fsl-ehci
usbcore: registered new interface driver snd-usb-audio
mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio
Cirrus Logic CS42888 ALSA SoC Codec Driver
i2c-core: driver [cs42888] using legacy suspend method
i2c-core: driver [cs42888] using legacy resume method
imx-hdmi-soc-dai imx-hdmi-soc-dai.0: Failed: Load HDMI-video first.
sgtl5000 1-000a: sgtl5000 revision 17
print_constraints: 1-000a: 850 <--> 1600 mV at 1200 mV normal
mmc0: host does not support reading read-only switch. assuming write-enable.
mmc0: new high speed SDHC card at address e624
mmcblk0: mmc0:e624 SU08G 7.40 GiB
mmcblk0: p1 p2 p3 < p5 p6 p7 p8 > p4
mmcblk0: p4 size 13352010 extends beyond EOD, truncated
input: USB Optical Mouse as /devices/platform/fsl-ehci.1/usb2/2-1/2-1.2/2-1.2:1.0/input/input2
generic-usb 0003:192F:0416.0001: input,hidraw0: USB HID v1.11 Mouse [USB Optical Mouse] on usb-fsl-ehci.1-1.2/input0
asoc: sgtl5000 <-> imx-ssi.1 mapping ok
input: sgtl5000-audio Headphone Jack as /devices/platform/soc-audio.1/sound/card0/input3
imx_3stack asoc driver
Initialize HDMI-audio failed. Load HDMI-video first!
ALSA device list:
#0: sgtl5000-audio
oprofile: using arm/armv7-ca9
u32 classifier
Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (12819 buckets, 51276 max)
ctnetlink v0.93: registering with nfnetlink.
NF_TPROXY: Transparent proxy support initialized, version 4.1.0
NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
xt_time: kernel timezone is -0000
ip_tables: (C) 2000-2006 Netfilter Core Team
arp_tables: (C) 2002 David S. Miller
TCP cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 10
usb 2-1.3: new high speed USB device number 4 using fsl-ehci
Mobile IPv6
ip6_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 17
NET: Registered protocol family 15
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
can: raw protocol (rev 20090105)
can: broadcast manager protocol (rev 20090105 t)
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
lib80211: common routines for IEEE802.11 drivers
lib80211_crypt: registered algorithm 'NULL'
lib80211_crypt: registered algorithm 'WEP'
lib80211_crypt: registered algorithm 'CCMP'
lib80211_crypt: registered algorithm 'TKIP'
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
Bus freq driver module loaded
Bus freq driver Enabled
mxc_dvfs_core_probe
DVFS driver module loaded
regulator_init_complete: PFUZE100_VGEN6: incomplete constraints, leaving on
regulator_init_complete: PFUZE100_VGEN3: incomplete constraints, leaving on
regulator_init_complete: PFUZE100_VGEN2: incomplete constraints, leaving on
regulator_init_complete: PFUZE100_VGEN1: incomplete constraints, leaving on
regulator_init_complete: VDDD: incomplete constraints, leaving on
snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:00 UTC (0)
Freeing init memory: 252K
nit: timerfd_create failed
healthd: BatteryTemperaturePath not found
healthd: BatteryTechnologyPath not found
init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
binder: 2302:2302 transaction failed 29189, size 0-0
init: using deprecated syntax for specifying property 'ro.serialno', use ${name} instead
init: property 'ro.serialno' doesn't exist while expanding '$ro.serialno'
init: cannot expand '$ro.serialno' while writing to '/sys/class/android_usb/android0/iSerial'
init: using deprecated syntax for specifying property 'ro.product.manufacturer', use ${name} instead
init: using deprecated syntax for specifying property 'ro.product.model', use ${name} instead
init: property 'sys.powerctl' doesn't exist while expanding '${sys.powerctl}'
init: powerctl: cannot expand '${sys.powerctl}'
init: property 'sys.sysctl.extra_free_kbytes' doesn't exist while expanding '${sys.sysctl.extra_free_kbytes}'
SELinux: initialized (dev fuse, type fuse), uses genfs_contexts
init: cannot expand '${sys.sysctl.extra_free_kbytes}' while writing to '/proc/sys/vm/extra_free_kbytes'
android_usb: already disabled
mtp_bind_config
root@sabresd_6dq:/ # imx-ipuv3 imx-ipuv3.0: IPU Warning - IPU_INT_STAT_10 = 0x00100000
ERROR: v4l2 capture: slave not found!
SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
warning: `zygote' uses 32-bit capabilities (legacy support in use)
request_suspend_state: wakeup (3->0) at 29094283672 (1970-01-02 00:00:11.039623334 UTC)
cpufreq_interactive_input_connect: connect to max11801_ts
eth0: no PHY, assuming direct connection to switch
PHY 0:00 not found
eth0: could not attach to PHY
acc_open
acc_release
ehci_fsl_bus_resume begins, DR
binder: 2658:2658 transaction failed 29189, size 100-0
init: sys_prop: permission denied uid:1003 name:service.bootanim.exit
root@sabresd_6dq:/ # ps
USER PID PPID VSIZE RSS WCHAN PC NAME
root 1 0 672 488 c0144530 0001a004 S /init
root 2 0 0 0 c00ac990 00000000 S kthreadd
root 3 2 0 0 c00946e0 00000000 S ksoftirqd/0
root 4 2 0 0 c00a8584 00000000 S kworker/0:0
root 5 2 0 0 c00a8584 00000000 S kworker/u:0
root 6 2 0 0 c00d196c 00000000 S migration/0
root 7 2 0 0 c00d5fec 00000000 S watchdog/0
root 8 2 0 0 c00d196c 00000000 S migration/1
root 9 2 0 0 c00a8584 00000000 S kworker/1:0
root 10 2 0 0 c00946e0 00000000 S ksoftirqd/1
root 11 2 0 0 c00d5fec 00000000 S watchdog/1
root 12 2 0 0 c00d196c 00000000 S migration/2
root 13 2 0 0 c00a8584 00000000 S kworker/2:0
root 14 2 0 0 c00946e0 00000000 S ksoftirqd/2
root 15 2 0 0 c00d5fec 00000000 S watchdog/2
root 16 2 0 0 c00d196c 00000000 S migration/3
root 17 2 0 0 c00a8584 00000000 S kworker/3:0
root 18 2 0 0 c00946e0 00000000 S ksoftirqd/3
root 19 2 0 0 c00d5fec 00000000 S watchdog/3
root 20 2 0 0 c00a88cc 00000000 S khelper
root 21 2 0 0 c00a8584 00000000 S kworker/u:1
root 26 2 0 0 c00a88cc 00000000 S suspend
root 391 2 0 0 c0114334 00000000 S sync_supers
root 393 2 0 0 c01152f8 00000000 S bdi-default
root 395 2 0 0 c00a88cc 00000000 S kblockd
root 430 2 0 0 c00a88cc 00000000 S imx6q-ecspi.0
root 440 2 0 0 c03c3540 00000000 S khubd
root 450 2 0 0 c00d7384 00000000 S irq/459-pfuze
root 482 2 0 0 c049e110 00000000 D ipu1_task
root 483 2 0 0 c049e110 00000000 D ipu1_task
root 511 2 0 0 c00a88cc 00000000 S rpciod
root 512 2 0 0 00000000 00000000 R kworker/0:1
root 520 2 0 0 c0072d1c 00000000 S usb_wakeup thre
root 522 2 0 0 c00a88cc 00000000 S otg_switch
root 526 2 0 0 c0072d1c 00000000 S usb_wakeup thre
root 539 2 0 0 c010cb10 00000000 S kswapd0
root 541 2 0 0 c0168c60 00000000 S fsnotify_mark
root 542 2 0 0 c00a88cc 00000000 S nfsiod
root 544 2 0 0 c00a88cc 00000000 S crypto
root 578 2 0 0 c00a88cc 00000000 S mxcfb0-vsync-pr
root 687 2 0 0 c00a8584 00000000 S kworker/1:1
root 1131 2 0 0 c0341568 00000000 S kapmd
root 1138 2 0 0 c00a8584 00000000 S kworker/2:1
root 1165 2 0 0 c03745b4 00000000 S mtdblock0
root 1170 2 0 0 c03745b4 00000000 S mtdblock1
root 1175 2 0 0 c03745b4 00000000 S mtdblock2
root 1180 2 0 0 c03745b4 00000000 S mtdblock3
root 1185 2 0 0 c03745b4 00000000 S mtdblock4
root 1210 2 0 0 c00a8584 00000000 S kworker/3:1
root 1238 2 0 0 c00a88cc 00000000 S f_mtp
root 1243 2 0 0 c03f4ac4 00000000 S file-storage
root 1253 2 0 0 c00d7384 00000000 S irq/452-max1180
root 1290 2 0 0 c00a8584 00000000 S kworker/0:2
root 1291 2 0 0 c00d7384 00000000 S irq/308-MAX8903
root 1292 2 0 0 c00d7384 00000000 S irq/309-MAX8903
root 1293 2 0 0 c00d7384 00000000 S irq/310-MAX8903
root 1294 2 0 0 c00d7384 00000000 S irq/307-MAX8903
root 1307 2 0 0 c047198c 00000000 S kinteractiveup
root 1310 2 0 0 c00a8584 00000000 S kworker/u:2
root 1315 2 0 0 c00a88cc 00000000 S vpu_wq
root 1320 2 0 0 c00a88cc 00000000 S galcore workque
root 1321 2 0 0 c00b1ec8 00000000 S Vivante Kernel
root 1322 2 0 0 c00b1ec8 00000000 S galcore daemon
root 1323 2 0 0 c00b1ec8 00000000 S galcore daemon
root 1324 2 0 0 c00b1ec8 00000000 S galcore daemon
root 1340 2 0 0 c00a88cc 00000000 S binder
root 1375 2 0 0 c0481420 00000000 S mmcqd/0
root 1407 2 0 0 c0651e34 00000000 S krfcommd
root 1418 1 612 260 c0144530 0001a004 S /sbin/ueventd
root 2291 1 472 4 c00b15f0 00025fc4 S /sbin/watchdogd
root 2293 2 0 0 c01f1700 00000000 S jbd2/mmcblk0p5-
root 2294 2 0 0 c00a88cc 00000000 S ext4-dio-unwrit
root 2296 2 0 0 c01f1700 00000000 S jbd2/mmcblk0p4-
root 2297 2 0 0 c00a88cc 00000000 S ext4-dio-unwrit
root 2298 2 0 0 c01f1700 00000000 S jbd2/mmcblk0p6-
root 2299 2 0 0 c00a88cc 00000000 S ext4-dio-unwrit
root 2300 2 0 0 c01f1700 00000000 S jbd2/mmcblk0p7-
root 2301 2 0 0 c00a88cc 00000000 S ext4-dio-unwrit
root 2302 1 1436 4 c016c208 000112a8 S /sbin/healthd
root 2303 1 932 476 c0050a74 401f6208 S /system/bin/sh
system 2304 1 1004 180 c04e1c0c 4015b664 S /system/bin/servicemanager
root 2305 1 4668 936 ffffffff 4014ff7c S /system/bin/vold
root 2306 1 9712 1100 ffffffff 401d7f7c S /system/bin/netd
root 2307 1 1032 240 c05346a8 40110378 S /system/bin/debuggerd
system 2308 1 211548 5904 ffffffff 40113834 S /system/bin/surfaceflinger
root 2309 1 677760 41032 ffffffff 417e74d8 R zygote
drm 2310 1 9556 3220 ffffffff 4029c664 S /system/bin/drmserver
media 2311 1 18284 6044 ffffffff 40152664 S /system/bin/mediaserver
install 2312 1 992 220 c05e57a8 401153a0 S /system/bin/installd
keystore 2313 1 3348 984 c04e1c0c 40229664 S /system/bin/keystore
root 2314 1 2420 684 ffffffff 400a5f7c S /system/bin/rild
media_rw 2318 1 6072 436 ffffffff 402f23a0 S /system/bin/sdcard
root 2320 1 7788 888 ffffffff 40130efc S /system/bin/ingsvcd
root 2656 2 0 0 c0157aa4 00000000 S flush-179:0
system 2658 2309 915184 38168 ffffffff 4004c834 S system_server
u0_a5 2777 2309 687916 20160 ffffffff 4004c834 S android.process.media
u0_a8 2790 2309 890344 31076 ffffffff 4004c834 S com.android.launcher
u0_a7 2802 2309 873260 26896 ffffffff 4004c834 S com.android.systemui
u0_a38 2852 2309 686916 16700 ffffffff 4004c834 S com.android.printspooler
u0_a33 2866 2309 687300 18296 ffffffff 4004c834 S com.android.music
root 8789 2 0 0 c00a8584 00000000 S kworker/0:3
root 13785 2303 1240 240 00000000 4019e3a0 R ps
radio 13845 2309 687056 17120 ffffffff 4181fb94 R com.android.phone
root@sabresd_6dq:/ # binder: release 2658:2668 transaction 73134 in, still active
binder: send failed reply for transaction 73134 to 14374:14374
binder: release 2658:14369 transaction 73116 out, still active
binder: send failed reply for transaction 73148 to 2311:2467
binder: send failed reply for transaction 73145 to 14387:14387
alarm_release: clear alarm, pending 0
binder: 2866:2866 transaction failed 29189, size 212-4
request_suspend_state: wakeup (0->0) at 95600942014 (1970-01-02 00:01:17.546280676 UTC)
binder: release 2311:2467 transaction 73116 in, still active
binder: send failed reply for transaction 73116, target dead
init: untracked pid 14387 exited
init: untracked pid 2866 exited
init: untracked pid 14374 exited
init: untracked pid 2777 exited
init: untracked pid 2790 exited
init: untracked pid 2852 exited
init: untracked pid 2802 exited
