LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY spi_bus IS
GENERIC(
sysCLK : INTEGER := 100000000; --system clock default is 100MHz
d_width : INTEGER := 16; --data bus width
clk_freq : INTEGER := 10000000 --SPI clock fequency default is 10MHz
PORT(
clock : IN STD_LOGIC; --system clock
reset_n : IN STD_LOGIC; --asynchronous reset
tx_data : IN STD_LOGIC_VECTOR(d_width-1 DOWNTO 0); --data to transmit
rx_data : OUT STD_LOGIC_VECTOR(d_width-1 DOWNTO 0); --data received
RD_dat : IN STD_LOGIC;
WR_dat : IN STD_LOGIC;
miso : IN STD_LOGIC; --master in, slave out
sclk : BUFFER STD_LOGIC := '0'; --spi clock
ss_n : BUFFER STD_LOGIC := '1'; --slave select
mosi : OUT STD_LOGIC --master out, slave in
END spi_bus;
ARCHITECTURE logic OF spi_bus IS
signal clk_counter: integer range 0 to (sysCLK / clk_freq / 2 - 1) := 0;
signal width_counter: integer range 0 to (2 * d_width + 3) := 2 * d_width + 1;
signal tx_buf : STD_LOGIC_VECTOR(d_width-1 DOWNTO 0); --data to transmit
signal rx_buf : STD_LOGIC_VECTOR(d_width-1 DOWNTO 0); --data received
signal regclk : STD_LOGIC;
BEGIN
regclk <= sclk when WR_dat = '1' else
clock when WR_dat = '0' else
'1';
process (reset_n, WR_dat, RD_dat, regclk, clock)
variable i,j : integer;
begin
if(reset_n = '1') then
if(WR_dat = '0') then
if(regclk'event and regclk = '1') then
tx_buf <= tx_data;
end if;
end if;
if(RD_dat = '0') then
if(clock'event and clock = '1') then
rx_data <= rx_buf;
end if;
end if;
if(regclk'event and regclk = '1' and WR_dat = '1' and width_counter > 0) then
mosi <= tx_buf(d_width -1);
for i in d_width-1 downto 1 loop
tx_buf(i) <= tx_buf(i-1);
end loop;
tx_buf(0) <= '0';
end if;
if(regclk'event and regclk = '0' and ss_n = '0') then
for j in 1 to d_width-1 loop
rx_buf(j) <= rx_buf(j-1);
end loop;
rx_buf(0) <= miso;
end if;
if(WR_dat = '1') then
if (clock'event and clock = '1') then
if (clk_counter = (sysCLK / clk_freq / 2 - 1)) then
if (width_counter < 2 * d_width) then
sclk <= not sclk;
end if;
if (width_counter < 2 * d_width + 1) then
width_counter <= width_counter + 1;
end if;
clk_counter <= 0;
else clk_counter <= clk_counter + 1;
end if;
end if;
else width_counter <= 0;
clk_counter <= 0;
end if;
if (width_counter < 2 * d_width + 1 and wr_dat = '1') then
ss_n <= '0';
else ss_n <= '1';
end if;
else tx_buf <= (others => '0');
ss_n <= '1';
rx_data <= (others => '0');
sclk <= '0';
end if;
end process;
END logic;
