发表于 2015-1-23 17:41:51
经过测试这段程序完全可用!
- // PLAYSTATION CONTROLLER(DUALSHOCK TYPE) INTERFACE TOP
- // Version : 2.00
- // Copyright(c) 2003 - 2004 Katsumi Degawa , All rights reserved
- // Important !
- // This program is freeware for non-commercial use.
- // An author does no guarantee about this program.
- // You can use this under your own risk.
- // 2003.10.30 It is optimized . by K Degawa
- `timescale 100ps/10ps
- //--------- SIMULATION ----------------------------------------------
- //`define SIMULATION_1
- `ifdef SIMULATION_1
- `define Timer_siz 18
- `else
- `define Timer_siz 12
- `endif
- `define Dualshock
- module psPAD_top(
- I_CLK250K, // MAIN CLK 250KHz
- I_RSTn, // MAIN RESET
- O_psCLK, // psCLK CLK OUT
- O_psSEL, // psSEL OUT
- O_psTXD, // psTXD OUT
- I_psRXD, // psRXD IN
- O_RXD_1, // RX DATA 1 (8bit)
- O_RXD_2, // RX DATA 2 (8bit)
- O_RXD_3, // RX DATA 3 (8bit)
- O_RXD_4, // RX DATA 4 (8bit)
- O_RXD_5, // RX DATA 5 (8bit)
- O_RXD_6, // RX DATA 6 (8bit)
- I_CONF_SW, // Dualshook Config ACTIVE-HI
- I_MODE_SW, // Dualshook Mode Set DEGITAL PAD 0: ANALOG PAD 1:
- I_MODE_EN, // Dualshook Mode Control OFF 0: ON 1:
- I_VIB_SW, // Vibration SW VIB_SW[0] Small Moter OFF 0:ON 1:
- // VIB_SW[1] Bic Moter OFF 0:ON 1(Dualshook Only)
- I_VIB_DAT // Vibration(Bic Moter)Data 8'H00-8'HFF (Dualshook Only)
- input I_CLK250K,I_RSTn;
- input I_CONF_SW;
- input I_MODE_SW,I_MODE_EN;
- input [1:0]I_VIB_SW;
- input [7:0]I_VIB_DAT;
- input I_psRXD;
- output O_psCLK;
- output O_psSEL;
- output O_psTXD;
- output [7:0]O_RXD_1;
- output [7:0]O_RXD_2;
- output [7:0]O_RXD_3;
- output [7:0]O_RXD_4;
- output [7:0]O_RXD_5;
- output [7:0]O_RXD_6;
- wire W_scan_seq_pls;
- wire W_type;
- wire [3:0]W_byte_cnt;
- wire W_RXWT;
- wire W_TXWT;
- wire W_TXSET;
- wire W_TXEN;
- wire [7:0]W_TXD_DAT;
- wire [7:0]W_RXD_DAT;
- wire W_conf_ent;
- ps_pls_gan pls(
- .I_CLK(I_CLK250K),
- .I_RSTn(I_RSTn),
- .I_TYPE(W_type), // DEGITAL PAD 0: ANALOG PAD 1:
- .O_SCAN_SEQ_PLS(W_scan_seq_pls),
- .O_RXWT(W_RXWT),
- .O_TXWT(W_TXWT),
- .O_TXSET(W_TXSET),
- .O_TXEN(W_TXEN),
- .O_psCLK(O_psCLK),
- .O_psSEL(O_psSEL),
- .O_byte_cnt(W_byte_cnt),
- //.Timer(O_Timer)
- .Timer()
- `ifdef Dualshock
- txd_commnd cmd(
- .I_CLK(W_TXSET),
- .I_RSTn(I_RSTn),
- .I_BYTE_CNT(W_byte_cnt),
- .I_MODE({I_CONF_SW,~I_MODE_EN,I_MODE_SW}),
- .I_VIB_SW(I_VIB_SW),
- .I_VIB_DAT(I_VIB_DAT),
- .I_RXD_DAT(W_RXD_DAT),
- .O_TXD_DAT(W_TXD_DAT),
- .O_TYPE(W_type),
- .O_CONF_ENT(W_conf_ent)
- `else
- txd_commnd_EZ cmd(
- .I_CLK(W_TXSET),
- .I_RSTn(I_RSTn),
- .I_MODE(),
- .I_VIB_DAT(),
- .I_RXD_DAT(),
- .O_TYPE(W_type),
- `endif
- ps_txd txd(
- .I_RSTn(I_RSTn),
- .I_WT(W_TXWT),
- .I_EN(W_TXEN),
- .I_TXD_DAT(W_TXD_DAT),
- .O_psTXD(O_psTXD)
- ps_rxd rxd(
- .I_CLK(O_psCLK),
- .I_RSTn(I_RSTn),
- .I_WT(W_RXWT),
- .I_psRXD(I_psRXD),
- .O_RXD_DAT(W_RXD_DAT)
- //---------- RXD DATA DEC ----------------------------------------
- reg [7:0]O_RXD_1;
- reg [7:0]O_RXD_2;
- reg [7:0]O_RXD_3;
- reg [7:0]O_RXD_4;
- reg [7:0]O_RXD_5;
- reg [7:0]O_RXD_6;
- reg W_rxd_mask;
- always@(posedge W_scan_seq_pls)
- W_rxd_mask <= ~W_conf_ent;
- always@(negedge W_RXWT)
- begin
- if(W_rxd_mask)begin
- case(W_byte_cnt)
- 3: O_RXD_1 <= W_RXD_DAT;
- 4: O_RXD_2 <= W_RXD_DAT;
- 5: O_RXD_3 <= W_RXD_DAT;
- 6: O_RXD_4 <= W_RXD_DAT;
- 7: O_RXD_5 <= W_RXD_DAT;
- 8: O_RXD_6 <= W_RXD_DAT;
- default:;
- endcase
- end
- end
- endmodule
- `ifdef Dualshock
- module txd_commnd_EZ(
- I_CLK,
- I_RSTn,
- I_BYTE_CNT,
- I_MODE,
- I_VIB_SW,
- I_VIB_DAT,
- I_RXD_DAT,
- O_TXD_DAT,
- O_TYPE,
- O_CONF_ENT
- input I_CLK,I_RSTn;
- input [3:0]I_BYTE_CNT;
- input [2:0]I_MODE;
- input [7:0]I_RXD_DAT;
- output [7:0]O_TXD_DAT;
- output O_TYPE;
- output O_CONF_ENT;
- reg [7:0]O_TXD_DAT;
- assign O_TYPE = 1'b1;
- assign O_CONF_ENT = 1'b0;
- always@(posedge I_CLK or negedge I_RSTn)
- begin
- if(! I_RSTn)begin
- O_TXD_DAT <= 8'h00;
- end
- else begin
- case(I_BYTE_CNT)
- 0:O_TXD_DAT <= 8'h01;
- 1:O_TXD_DAT <= 8'h42;
- 3:begin
- if(I_VIB_SW) O_TXD_DAT <= 8'h40;
- else O_TXD_DAT <= 8'h00;
- end
- 4:begin
- if(I_VIB_SW) O_TXD_DAT <= 8'h01;
- end
- default: O_TXD_DAT <= 8'h00;
- endcase
- end
- end
- endmodule
- `endif
- module txd_commnd(
- I_CLK,
- I_RSTn,
- I_BYTE_CNT,
- I_MODE,
- I_VIB_SW,
- I_VIB_DAT,
- I_RXD_DAT,
- O_TXD_DAT,
- O_TYPE,
- O_CONF_ENT
- output O_TYPE;
- wire [1:0]pad_mode = I_MODE[1:0];
- wire ds_sw = I_MODE[2];
- reg [2:0]conf_state;
- reg conf_entry;
- reg conf_ent_reg;
- reg conf_done;
- reg pad_status;
- reg pad_id;
- assign O_TYPE = pad_id;
- assign O_CONF_ENT = conf_entry;
- begin
- if(! I_RSTn) pad_id <= 1'b0;
- else begin
- if(I_BYTE_CNT==2)begin
- case(I_RXD_DAT) //------ GET TYPE(Byte_SEQ)
- 8'h23: pad_id <= 1'b1;
- 8'h41: pad_id <= 1'b0;
- 8'h53: pad_id <= 1'b1;
- 8'h73: pad_id <= 1'b1;
- 8'hE3: pad_id <= 1'b1;
- 8'hF3: pad_id <= 1'b1;
- default: pad_id <= 1'b0;
- endcase
- end
- end
- end
- begin
- if(! I_RSTn)begin
- conf_entry <= 1'b0;
- conf_ent_reg <= 1'b0;
- conf_done <= 1'b1;
- conf_state <= 0;
- pad_status <= 0;
- end
- else begin
- //---------- nomal mode --------------------------------------------------------
- //----------------- read_data_and_vibrate_ex 01,42,00,WW,PP(,00,00,00,00)
- // --,ID,SS,XX,XX(,XX,XX,XX,XX)
- if(~conf_entry)begin
- case(I_BYTE_CNT)
- 3:begin
- if(I_RXD_DAT==8'h00) conf_ent_reg <= 1'b1;
- if(pad_status)begin
- if(I_VIB_SW[0]) O_TXD_DAT <= 8'h01;
- end
- else begin
- if(I_VIB_SW[0] | I_VIB_SW[1]) O_TXD_DAT <= 8'h40;
- end
- end
- 4:begin
- if(I_VIB_SW[1]) O_TXD_DAT <= I_VIB_DAT;
- end
- else begin
- if(I_VIB_SW[0] | I_VIB_SW[1]) O_TXD_DAT <= 8'h01;
- end
- if(pad_id==0)begin
- if(conf_state == 0 && ds_sw)
- conf_entry <= 1'b1;
- if(conf_state == 7 && (pad_status&conf_ent_reg))begin
- conf_state <= 0;
- end
- end
- end
- 8:begin
- if(pad_id==1)begin
- conf_state <= 0;
- end
- end
- end
- endcase
- end
- //---------- confg mode --------------------------------------------------------
- else begin
- case(conf_state)
- //-------- config_mode_enter (43): 01,43,00,01,00(,00 x 4 or XX x 16)
- // --,ID,SS,XX,XX(,XX x 4 or XX x 16)
- 0:begin
- case(I_BYTE_CNT)
- 0:begin
- O_TXD_DAT <= 8'h01;
- conf_done <= 1'b0;
- end
- 1:O_TXD_DAT <= 8'h43;
- 3:O_TXD_DAT <= 8'h01;
- 4:begin
- if(pad_status) conf_state <= 3;
- else conf_state <= 1;
- end
- end
- 8:begin
- end
- end
- default:O_TXD_DAT <= 8'h00;
- endcase
- end
- //-------- query_model_and_mode (45): 01,45,00,5A,5A,5A,5A,5A,5A
- // FF,F3,5A,TT,02,MM,VV,01,00
- 1:begin
- case(I_BYTE_CNT)
- 1:O_TXD_DAT <= 8'h45;
- 2:begin
- conf_done <= (I_RXD_DAT == 8'hF3)? 1'b0:1'b1;
- end
- 4:begin
- if(I_RXD_DAT==8'h01 || I_RXD_DAT==8'h03) pad_status <= 1;
- if(pad_id==0 && conf_done==1'b1)begin
- conf_state <= 7;
- end
- end
- 8:begin
- conf_state <= 2;
- if(pad_id==1 && conf_done==1'b1)begin
- conf_state <= 7;
- end
- end
- endcase
- end
- //-------- set_mode_and_lock (44): 01,44,00,XX,YY,00,00,00,00
- // --,F3,5A,00,00,00,00,00,00
- 2:begin
- case(I_BYTE_CNT)
- 1:O_TXD_DAT <= 8'h44;
- 3:O_TXD_DAT <= pad_mode[0] ? 8'h01:8'h00;
- 4:O_TXD_DAT <= pad_mode[1] ? 8'h03:8'h00;
- 8:begin
- conf_state<= 3;
- end
- endcase
- end
- //-------- vibration_enable (4D): 01,4D,00,00,01,FF,FF,FF,FF
- // --,F3,5A,XX,YY,FF,FF,FF,FF
- 3:begin
- case(I_BYTE_CNT)
- 1:O_TXD_DAT <= 8'h4D;
- 2,3:O_TXD_DAT <= 8'h00;
- 4:O_TXD_DAT <= 8'h01;
- 8:begin
- O_TXD_DAT <= 8'hFF;
- conf_state<= 6;
- end
- default:O_TXD_DAT <= 8'hFF;
- endcase
- end
- //-------- config_mode_exit (43): 01,43,00,00,5A,5A,5A,5A,5A
- 6:begin
- case(I_BYTE_CNT)
- 8:begin
- O_TXD_DAT <= 8'h5A;
- conf_state<= 7;
- conf_entry<= 1'b0;
- conf_ent_reg<= 1'b0;
- end
- default:O_TXD_DAT <= 8'h5A;
- endcase
- end
- default:;
- endcase
- end
- end
- end
- endmodule
- module ps_pls_gan(
- I_CLK,
- I_RSTn,
- I_TYPE,
- O_SCAN_SEQ_PLS,
- O_RXWT,
- O_TXWT,
- O_TXSET,
- O_TXEN,
- O_psCLK,
- O_psSEL,
- O_byte_cnt,
- Timer
- parameter Timer_size = `Timer_siz;
- input I_TYPE;
- output O_SCAN_SEQ_PLS;
- output O_RXWT;
- output O_TXWT;
- output O_TXSET;
- output O_TXEN;
- output O_psCLK;
- output O_psSEL;
- output [3:0]O_byte_cnt;
- output [Timer_size-1:0]Timer;
- reg [Timer_size-1:0]Timer;
- reg O_SCAN_SEQ_PLS;
- reg RXWT;
- reg TXWT;
- reg TXSET;
- reg psCLK_gate;
- reg psSEL;
- reg [3:0]O_byte_cnt;
- begin
- if(! I_RSTn) Timer <= 0;
- else Timer <= Timer+1;
- end
- begin
- if(! I_RSTn)
- O_SCAN_SEQ_PLS <= 0;
- else begin
- if(Timer == 0) O_SCAN_SEQ_PLS <= 1;
- else O_SCAN_SEQ_PLS <= 0;
- end
- end
- begin
- if(! I_RSTn)
- begin
- psCLK_gate <= 1;
- RXWT <= 0;
- TXWT <= 0;
- TXSET <= 0;
- end
- else begin
- case(Timer[4:0])
- 6: TXSET <= 1;
- 8: TXSET <= 0;
- 9: TXWT <= 1;
- 11: TXWT <= 0;
- 12: psCLK_gate <= 0;
- 20: psCLK_gate <= 1;
- 21: RXWT <= 1;
- 23: RXWT <= 0;
- default:;
- endcase
- end
- end
- begin
- if(! I_RSTn)
- psSEL <= 1;
- else begin
- if(O_SCAN_SEQ_PLS == 1)
- psSEL <= 0;
- else if((I_TYPE == 0)&&(Timer == 158))
- psSEL <= 1;
- else if((I_TYPE == 1)&&(Timer == 286))
- psSEL <= 1;
- end
- end
- begin
- if(! I_RSTn)
- O_byte_cnt <= 0;
- else begin
- if( O_SCAN_SEQ_PLS == 1)
- O_byte_cnt <= 0;
- else begin
- if( Timer[4:0] == 5'b11111)begin
- if(I_TYPE == 0 && O_byte_cnt == 5)
- O_byte_cnt <= O_byte_cnt;
- else if(I_TYPE == 1 && O_byte_cnt == 9)
- else
- O_byte_cnt <= O_byte_cnt+1;
- end
- end
- end
- end
- assign O_psCLK = psCLK_gate | I_CLK | psSEL;
- assign O_psSEL = psSEL;
- assign O_RXWT = ~psSEL&RXWT;
- assign O_TXSET = ~psSEL&TXSET;
- assign O_TXWT = ~psSEL&TXWT;
- assign O_TXEN = ~psSEL&(~psCLK_gate);
- endmodule
- module ps_rxd(
- I_CLK,
- I_RSTn,
- I_WT,
- I_psRXD,
- O_RXD_DAT
- input I_CLK,I_RSTn,I_WT;
- input I_psRXD;
- output [7:0]O_RXD_DAT;
- reg [7:0]O_RXD_DAT;
- reg [7:0]sp;
- if(! I_RSTn) sp <= 1;
- else sp <= { I_psRXD, sp[7:1]};
- always@(posedge I_WT or negedge I_RSTn)
- if(! I_RSTn) O_RXD_DAT <= 1;
- else O_RXD_DAT <= sp;
- endmodule
- module ps_txd(
- I_CLK,
- I_RSTn,
- I_WT,
- I_EN,
- I_TXD_DAT,
- O_psTXD
- input I_WT,I_EN;
- input [7:0]I_TXD_DAT;
- output O_psTXD;
- reg O_psTXD;
- reg [7:0]ps;
- always@(negedge I_CLK or negedge I_RSTn)
- begin
- if(! I_RSTn)begin
- O_psTXD <= 1;
- ps <= 0;
- end
- else begin
- if(I_WT)
- ps <= I_TXD_DAT;
- else begin
- if(I_EN)begin
- O_psTXD <= ps[0];
- ps <= {1'b1, ps[7:1]};
- end
- else begin
- O_psTXD <= 1'd1;
- ps <= ps;
- end
- end
- end
- end
- endmodule
复制代码 |
