发表于 2015-2-6 22:13:48
先发个时钟部分代码吧。调试已经通过。
- #include "includes.h" //包涵总头文件
- void MCGIRCLK_OutEnable(uint_8 clock); //启用内部快速时钟
- volatile uint_16 DSEC;
- unsigned char const MONTH_Table[12] = { 31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31 };
- unsigned int Time_MARK[6] = {2015,2,3,23,59,50};
- unsigned int Time_LAST[6] = {2000,8,18,18,18,18};
- #define YEAR Time_MARK[0]
- #define MONTH Time_MARK[1]
- #define DATE Time_MARK[2]
- #define HOUR Time_MARK[3]
- #define MINUTE Time_MARK[4]
- #define SECOND Time_MARK[5]
- int main(void)
- //1.声明主函数使用的局部变量
- uint_8 i,j;
- uint_8 * g_time[] ={"00","01","02","03","04","05","06","07","08","09",
- "10","11","12","13","14","15","16","17","18","19",
- "20","21","22","23","24","25","26","27","28","29",
- "30","31","32","33","34","35","36","37","38","39",
- "40","41","42","43","44","45","46","47","48","49",
- "50","51","52","53","54","55","56","57","58","59",
- }; //0~59字符LCD显示转换
- uint_8 g_DispalyInit1[20] = "Now time is 88:88:88";
- uint_8 g_DispalyInit2[20] = " 2015-01-28";
- uint_8 g_DispalyInit3[20] = "Last feed time 88:88";
- uint_8 g_DispalyInit4[20] = "Next feed time 88:88";
- //2.关总中断
- DISABLE_INTERRUPTS;
- //3.初始化底层模块
- LEDInit(); //LED初始化
- LCDInit(); //LCD初始化
- KBInit(); //键盘初始化
- tpm_init(TPM0,TPM_CLKSRC_PLL,1000); //初始化TPM模块,1ms中断一次
- //4. 给有关变量赋初值
- i = 0;
- //LCD输出格式化
- LCD_write_String(1,0,g_DispalyInit1,20);
- LCD_write_String(2,0,g_DispalyInit2,20);
- LCD_write_String(3,0,g_DispalyInit3,20);
- LCD_write_String(4,0,g_DispalyInit4,20);
- //5. 使能模块中断
- tpm_enable_int(0);
- //6. 开总中断
- ENABLE_INTERRUPTS;
- for(;;)
- Clock_OnTimer();
- if(DSEC == 0) //判断秒钟是否发生变化
- if(Time_LAST[3] != HOUR)
- i = HOUR;
- LCD_write_String(1,12,g_time[i],2);
- Time_LAST[3] = HOUR;
- if(Time_LAST[4] != MINUTE)
- i = MINUTE;
- LCD_write_String(1,15,g_time[i],2);
- Time_LAST[4] = MINUTE;
- if(Time_LAST[5] != SECOND)
- i = SECOND;
- LCD_write_String(1,18,g_time[i],2);
- Time_LAST[5] = SECOND;
- if(Time_LAST[0] != YEAR)
- i = 20;
- LCD_write_String(2,10,g_time[i],2);
- j = YEAR%100;
- LCD_write_String(2,12,g_time[j],2);
- Time_LAST[0] = YEAR;
- if(Time_LAST[1] != MONTH)
- i = MONTH;
- LCD_write_String(2,15,g_time[i],2);
- Time_LAST[1] = MONTH;
- if(Time_LAST[2] != DATE)
- i = DATE;
- LCD_write_String(2,18,g_time[i],2);
- Time_LAST[2] = DATE;
- return 0;
- //启用MCGIRCLK时钟,输出时钟频率在31.25Khz ~ 4Mhz
- PORTC_PCR3 = PORT_PCR_MUX(0x5);
- SIM_SOPT2 = SIM_SOPT2_CLKOUTSEL(clock); //复用PTC3为CLKOUT,观测输出时钟波形
- MCG_C1 |= MCG_C1_IRCLKEN_MASK|MCG_C1_IREFSTEN_MASK;
- MCG_C2 &= ~MCG_C2_IRCS_MASK;
- void Clock_OnTimer()
- unsigned char Days = 31;
- if (DSEC >= 1000)
- DSEC = 0;
- SECOND++;
- } //1秒一次
- if (SECOND >= 60)
- SECOND = 0;
- MINUTE++;
- } //60秒一次
- if (MINUTE >= 60)
- MINUTE = 0;
- HOUR++;
- } //60分一次
- if (HOUR >= 24)
- HOUR = 0;
- DATE++;
- if (MONTH == 2) //处理润年2月份问题
- if (YEAR % 4 == 0)
- Days = 29; //逢4润
- else
- Days = 28;
- if (YEAR % 400 == 0)
- Days = 28; //逢400不润
- else
- Days = MONTH_Table[MONTH - 1]; //正常月份,查表得到当月天数
- } //24小时一次
- if (DATE > Days) {
- DATE = 1;
- MONTH++;
- } //一个月一次
- if (MONTH > 12)
- MONTH = 1;
- YEAR++;
- } //一年一次
复制代码 |
