发表于 2015-1-13 17:29:02
里面有ReadMe说明:
1. open working time template.xlsx, add additional eployees if necessary,and make sure the name is matched with Time Cards.xls
2. If employees left the company, only hide the columns, do not delete.
3. open Working time.exe, the default max cards number is 150, if it's bigger than 150, please ask engineer to support.
4. Copy new 1_attlog.dat file to the same folder as working time.exe
4. Workday to rest.txt means holiday, don't need to work, please change it if necessary
5. Weekend to work.txt means weekend need to work, please change it if necessary
6. Please make sure working time template.xlsx, 1_attlog.dat, Workday to rest.txt and Weekend to work.txt are available in the same folder. |
