发表于 2014-12-31 11:50:46
- HTTP CLIENT FOR RAW LWIP
- (c) 2008-2009 Noyens Kenneth
- PUBLIC VERSION V0.2 16/05/2009
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU LESSER GENERAL PUBLIC LICENSE Version 2.1 as published by
- the Free Software Foundation.
- This program is distributed in the hope that it will be useful,
- but WITHOUT ANY WARRANTY; without even the implied warranty of
- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- GNU Lesser General Public License for more details.
- You should have received a copy of the GNU General Public License
- along with this program; if not, write to the
- Free Software Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
- #include <stdlib.h>
- #include <string.h>
- #include "webclient.h"
- #include "utils/ustdlib.h"
- // Close a PCB(connection)
- void hc_clearpcb(struct tcp_pcb *pcb)
- if(pcb != NULL)
- // Close the TCP connection
- tcp_close(pcb);
- // Function that lwip calls for handling recv'd data
- err_t hc_recv(void *arg, struct tcp_pcb *pcb, struct pbuf *p, err_t err)
- struct hc_state *state = arg;
- char * page = NULL;
- struct pbuf * temp_p;
- hc_errormsg errormsg = GEN_ERROR;
- int i;
- if((err == ERR_OK) && (p != NULL))
- tcp_recved(pcb, p->tot_len);
- // Add payload (p) to state
- temp_p = p;
- while(temp_p != NULL)
- state->RecvData = realloc(state->RecvData, temp_p->len + state->Len + 1);
- // CHECK 'OUT OF MEM'
- if(state->RecvData == NULL)
- // OUT OF MEMORY
- (*state->ReturnPage)(state->Num, OUT_MEM, NULL, 0);
- return(ERR_OK);
- strncpy(state->RecvData + state->Len, temp_p->payload, temp_p->len);
- state->RecvData[temp_p->len + state->Len] = '\0';
- state->Len += temp_p->len;
- temp_p = temp_p->next;
- // Removing payloads
- while(p != NULL)
- temp_p = p->next;
- pbuf_free(p);
- p = temp_p;
- // NULL packet == CONNECTION IS CLOSED(by remote host)
- else if((err == ERR_OK) && (p == NULL))
- // Simple code for checking 200 OK
- for(i=0; i < state->Len; i++)
- if(errormsg == GEN_ERROR)
- // Check for 200 OK
- if((*(state->RecvData+i) == '2') && (*(state->RecvData+ ++i) == '0') && (*(state->RecvData+ ++i) == '0')) errormsg = OK;
- if(*(state->RecvData+i) == '\n') errormsg = NOT_FOUND;
- else
- // Remove headers
- if((*(state->RecvData+i) == '\r') && (*(state->RecvData+ ++i) == '\n') && (*(state->RecvData+ ++i) == '\r') && (*(state->RecvData + ++i) == '\n'))
- i++;
- page = malloc(strlen(state->RecvData+i));
- strcpy(page, state->RecvData+i);
- break;
- if(errormsg == OK)
- // Put recv data to ---> p->ReturnPage
- (*state->ReturnPage)(state->Num, OK, page, state->Len);
- else
- // 200 OK not found Return NOT_FOUND (WARNING: NOT_FOUND COULD ALSO BE 5xx SERVER ERROR, ...)
- (*state->ReturnPage)(state->Num, errormsg, NULL, 0);
- // Clear the PCB
- hc_clearpcb(pcb);
- // free the memory containing state
- free(state->RecvData);
- free(state);
- return(ERR_OK);
- // Function that lwip calls when there is an error
- static void hc_error(void *arg, err_t err)
- // pcb already deallocated
- // Call return function
- // TO-DO: Check err_t err for out_mem, ...
- (*state->ReturnPage)(state->Num, GEN_ERROR, NULL, 0);
- free(state->PostVars);
- free(state->Page);
- free(state);
- // Function that lwip calls when the connection is idle
- // Here we can kill connections that have stayed idle for too long
- static err_t hc_poll(void *arg, struct tcp_pcb *pcb)
- state->ConnectionTimeout++;
- if(state->ConnectionTimeout > 20)
- // Close the connection
- tcp_abort(pcb);
- // Give err msg to callback function
- (*state->ReturnPage)(state->Num, TIMEOUT, NULL, 0);
- return(ERR_OK);
- // lwip calls this function when the remote host has successfully received data (ack)
- static err_t hc_sent(void *arg, struct tcp_pcb *pcb, u16_t len)
- // Reset connection timeout
- state->ConnectionTimeout = 0;
- return(ERR_OK);
- // lwip calls this function when the connection is established
- static err_t hc_connected(void *arg, struct tcp_pcb *pcb, err_t err)
- char * headers;
- // error?
- if(err != ERR_OK)
- hc_clearpcb(pcb);
- // Free wc state
- free(state);
- return(ERR_OK);
- // Define Headers
- if(state->PostVars == NULL)
- // GET headers (without page)(+ \0) = 19
- headers = malloc(19 + strlen(state->Page));
- usprintf(headers,"GET /%s HTTP/1.0\r\n\r\n", state->Page);
- else
- // POST headers (without PostVars or Page)(+ \0) = 91
- // Content-length: %d <== ??? (max 10)
- headers = malloc(91 + strlen(state->PostVars) + strlen(state->Page) + 10);
- usprintf(headers, "POST /%s HTTP/1.0\r\nContent-type: application/x-www-form-urlencoded\r\nContent-length: %d\r\n\r\n%s\r\n\r\n", state->Page, strlen(state->PostVars), state->PostVars);
- // Check if we are nut running out of memory
- if(headers == NULL)
- hc_clearpcb(pcb);
- // Free wc state
- free(state);
- return(ERR_OK);
- // Setup the TCP receive function
- tcp_recv(pcb, hc_recv);
- // Setup the TCP error function
- tcp_err(pcb, hc_error);
- // Setup the TCP polling function/interval //TCP_POLL IS NOT CORRECT DEFINED @ DOC!!!
- tcp_poll(pcb, hc_poll, 10);
- // Setup the TCP sent callback function
- tcp_sent(pcb, hc_sent);
- // Send data
- tcp_write(pcb, headers, strlen(headers), 1);
- tcp_output(pcb);
- // remove headers
- free(headers);
- free(state->PostVars); // postvars are send, so we don't need them anymore
- free(state->Page); // page is requested, so we don't need it anymore
- return(ERR_OK);
- // Public function for request a webpage (REMOTEIP, ...
- int hc_open(struct ip_addr remoteIP, char *Page, char *PostVars, void (* returnpage)(u8_t, hc_errormsg, char *, u16_t))
- struct tcp_pcb *pcb = NULL;
- struct hc_state *state;
- static u8_t num = 0;
- // local port
- u16_t port= 4545;
- // Get a place for a new webclient state in the memory
- state = malloc(sizeof(struct hc_state));
- // Create a new PCB (PROTOCOL CONTROL BLOCK)
- pcb = tcp_new();
- if(pcb == NULL || state == NULL)
- //UARTprintf("hc_open: Not enough memory for pcb or state\n");
- //Not enough memory
- return 0;
- // Define webclient state vars
- num++;
- state->Num = num;
- state->RecvData = NULL;
- state->Len = 0;
- state->ReturnPage = returnpage;
- // Make place for PostVars & Page
- if(PostVars != NULL) state->PostVars = malloc(strlen(PostVars) +1);
- state->Page = malloc(strlen(Page) +1);
- // Check for "out of memory"
- if(state->Page == NULL || (state->PostVars == NULL && PostVars != NULL))
- free(state);
- tcp_close(pcb);
- return 0;
- // Place allocated copy data
- strcpy(state->Page, Page);
- if(PostVars != NULL) strcpy(state->PostVars, PostVars);
- // Bind to local IP & local port
- while(tcp_bind(pcb, IP_ADDR_ANY, port) != ERR_OK)
- // Local port in use, use port+1
- port++;
- // Use conn -> argument(s)
- tcp_arg(pcb, state);
- // Open connect (SEND SYN)
- tcp_connect(pcb, &remoteIP, 80, hc_connected);
- return num;
复制代码 |
