这是MCF52259开发板上写的一个演示485通信的例子。实现的功能很简单,就是通过485收到一个字节就立马再通过485发出去
@ Nicrosystem Freescale coldfire MCF52259 Development Board
@ NSCF52259-R1
@ author:bluehacker
@ date:2009-12-01
#include "uart.h"
uint8 uart_init(uint8 channel,uint32 sysClockKhz,uint32 baudRate)
uint16 ubgs;
if(channel>2)
return 1;//error
set_gpio_uart(channel);
* Reset Transmitter
MCF_UART_UCR(channel) = MCF_UART_UCR_RESET_TX;
* Reset Receiver
MCF_UART_UCR(channel) = MCF_UART_UCR_RESET_RX;
* Reset Mode Register
MCF_UART_UCR(channel) = MCF_UART_UCR_RESET_MR;
* No parity, 8-bits per character
MCF_UART_UMR(channel) = (0
| MCF_UART_UMR_PM_NONE
| MCF_UART_UMR_BC_8 );
* No echo or loopback, 1 stop bit
| MCF_UART_UMR_CM_NORMAL
| MCF_UART_UMR_SB_STOP_BITS_1);
* Set Rx and Tx baud by SYSTEM CLOCK
MCF_UART_UCSR(channel) = (0
| MCF_UART_UCSR_RCS_SYS_CLK
| MCF_UART_UCSR_TCS_SYS_CLK);
* Mask all UART interrupts
MCF_UART_UIMR(channel) = 0;
* Calculate baud settings
ubgs = (uint16)((sysClockKhz * 1000)/(baudRate * 32));
MCF_UART_UBG1(channel) = (uint8)((ubgs & 0xFF00) >> 8);
MCF_UART_UBG2(channel) = (uint8)(ubgs & 0x00FF);
* Enable receiver and transmitter
MCF_UART_UCR(channel) = (0
| MCF_UART_UCR_TX_ENABLED
| MCF_UART_UCR_RX_ENABLED);
return 0;//success
void set_gpio_uart(uint8 channel)
switch(channel)
case 0:
MCF_GPIO_PUAPAR|=MCF_GPIO_PUAPAR_UTXD0_UTXD0 |
MCF_GPIO_PUAPAR_URXD0_URXD0 |MCF_GPIO_PUAPAR_URTS0_URTS0 |
MCF_GPIO_PUAPAR_UCTS0_UCTS0 ;
case 1:
MCF_GPIO_PUBPAR|=MCF_GPIO_PUBPAR_UTXD1_UTXD1 |
MCF_GPIO_PUBPAR_URXD1_URXD1 ;
case 2:
MCF_GPIO_PUCPAR|=MCF_GPIO_PUCPAR_UTXD2_UTXD2 |
MCF_GPIO_PUCPAR_URXD2_URXD2 ;
default:
* Wait for a character to be received on the specified UART
* Return Values:
* the received character
char uart_getchar (uint8 channel)
/* Wait until character has been received */
while (!(MCF_UART_USR(channel) & MCF_UART_USR_RXRDY))
return (char)MCF_UART_URB(channel);
* Wait for space in the UART Tx FIFO and then send a character
void uart_putchar (uint8 channel, char ch)
/* Wait until space is available in the FIFO */
while (!(MCF_UART_USR(channel) & MCF_UART_USR_TXRDY))
/* Send the character */
MCF_UART_UTB(channel) = (uint8)ch;
* send a string using poll mode
void uart_putstr(uint8 channel, char *str)
while(*str!=0)
uart_putchar(channel,*str++);
//main.c
@ NSCF52259-R1
@ author:bluehacker
@ date:2009-12-01
* main implementation: use this sample to create your own application
#include "support_common.h" /* include peripheral declarations and more */
#if (CONSOLE_IO_SUPPORT || ENABLE_UART_SUPPORT)
/* Standard IO is only possible if Console or UART support is enabled. */
#include
#include "uart.h"
#include "delay.h"
void rs485_init(uint32 baudRate)
MCF_GPIO_PUCPAR &=0x3f;
MCF_GPIO_DDRUC|=MCF_GPIO_DDRUC_DDRUC3 ;
MCF_GPIO_PORTUC&=~MCF_GPIO_PORTUC_PORTUC3 ;
uart_init(1,80000,baudRate);
char rs485_getchar()
return uart_getchar(1);
void rs485_putchar(char ch)
MCF_GPIO_PORTUC|=MCF_GPIO_PORTUC_PORTUC3 ;
uart_putchar(1,ch);
while (!(MCF_UART_USR(1) & MCF_UART_USR_TXEMP))
int main(void)
int counter = 0;
char c=0;
printf("Hello World in C from MCF52259 derivative on MCF52259 board\n\r");
fflush(stdout);
pit_init(0);
rs485_init(9600);
for(;;) {
counter++;
//rs485_putchar(c);
c=rs485_getchar();
delay_ms(80000,0,10);
rs485_putchar(c);
