发表于 2014-12-26 20:57:37
最新的启动信息如下:
自己一个人搞真是太苦逼了!感谢前辈们,以后还要多多学习,路还很长。。。
U-Boot SPL 2014.07 (Dec 26 2014 - 20:40:04)
Enable clock domain - 44e0000c
Enable clock domain - 44e00008
Enable clock domain - 44e00004
Enable clock domain - 44e00000
Enable clock domain - 44e00400
Enable clock domain - 44e000d0
Enable clock domain - 44e00804
Enable clock domain - 44e00148
Enable clock domain - 44e00534
Enable clock module - 44e000e0
Enable clock module - 44e00060
Enable clock module - 44e00064
Enable clock module - 44e0040c
Enable clock module - 44e000dc
Enable clock module - 44e00120
Enable clock module - 44e00408
Enable clock module - 44e00404
Enable clock module - 44e00080
Enable clock module - 44e00030
Enable clock module - 44e00040
Enable clock module - 44e0003c
Enable clock module - 44e000f4
Enable clock module - 44e004b8
Enable clock module - 44e000ac
Enable clock module - 44e000b0
Enable clock module - 44e000b4
Enable clock module - 44e00048
Enable clock module - 44e00014
Enable clock module - 44e0004c
Enable clock module - 44e00800
Enable clock module - 44e0001c
Enable clock module - 44e000d0
Enable clock module - 44e00028
Enable clock module - 44e00018
>>spl:board_init_r()
musb-hdrc:ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
musb-hdrc: hw_ep 0shared, max 64
musb-hdrc: hw_ep 1tx, max 512
musb-hdrc: hw_ep 1rx, max 512
musb-hdrc: hw_ep 2tx, max 512
musb-hdrc: hw_ep 2rx, max 512
musb-hdrc: hw_ep 3tx, max 512
musb-hdrc: hw_ep 3rx, max 512
musb-hdrc: hw_ep 4tx, max 512
musb-hdrc: hw_ep 4rx, max 512
musb-hdrc: hw_ep 5tx, max 512
musb-hdrc: hw_ep 5rx, max 512
musb-hdrc: hw_ep 6tx, max 512
musb-hdrc: hw_ep 6rx, max 512
musb-hdrc: hw_ep 7tx, max 512
musb-hdrc: hw_ep 7rx, max 512
musb-hdrc: hw_ep 8tx, max 512
musb-hdrc: hw_ep 8rx, max 512
musb-hdrc: hw_ep 9tx, max 512
musb-hdrc: hw_ep 9rx, max 512
musb-hdrc: hw_ep 10tx, max 256
musb-hdrc: hw_ep 10rx, max 64
musb-hdrc: hw_ep 11tx, max 256
musb-hdrc: hw_ep 11rx, max 64
musb-hdrc: hw_ep 12tx, max 256
musb-hdrc: hw_ep 12rx, max 64
musb-hdrc: hw_ep 13shared, max 4096
musb-hdrc: hw_ep 14shared, max 1024
musb-hdrc: hw_ep 15shared, max 1024
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
***************M_800****************
boot device - 8
mmc_init: 0, time 73
boot mode - FAT
reading u-boot.img
VFAT Support enabled
FAT32, fat_sect: 32, fatlength: 1112
Rootdir begins at cluster: 2, sector: 2256, offset: 11a000
Data begins at: 2254
Sector size: 512, cluster size: 1
FAT read sect=2256, clust_size=1, DIRENTSPERBLOCK=16
RootMismatch: |mlo||
RootName: u-boot.img, start: 0xc3, size: 0x80930
Filesize: 526640 bytes
64 bytes
gc - clustnum: 195, startsect: 2449
Size: 526640, got: 64
spl: payload image: U-Bo load addr: 0x807fffc0 size: 526640
reading u-boot.img
526640 bytes
gc - clustnum: 7421, startsect: 9675
Size: 526640, got: 526640
Jumping to U-Boot
image entry point: 0x80800000
initcall: 8084abd4
U-Boot 2014.07 (Dec 26 2014 - 20:40:04)
initcall: 80806534
U-Boot code: 80800000 -> 80874C04 BSS: -> 810C0DA8
initcall: 80806268
initcall: 80806644
I2C: ready
initcall: 8080662c
DRAM: initcall: 80800cec
initcall: 808066e8
Monitor len: 008C0DA8
Ram size: 08000000
Ram top: 88000000
initcall: 808062a0
initcall: 808064dc
TLB table from 87ff0000 to 87ff4000
initcall: 808062b8
initcall: 808062c8
initcall: 80806490
Reserving 8963k for U-Boot at: 8772f000
initcall: 80806460
Reserving 16512k for malloc() at: 8670f000
initcall: 808065e8
Reserving 80 Bytes for Board Info at: 8670efb0
initcall: 808062d0
initcall: 8080642c
Reserving 184 Bytes for Global Data at: 8670eef8
initcall: 808063c8
initcall: 808062e4
initcall: 80806318
initcall: 80806564
RAM Configuration:
Bank #0: 80000000 128 MiB
DRAM: 128 MiB
initcall: 808063ac
New Stack Pointer is: 8670eed0
initcall: 80806328
initcall: 80806358
Relocation Offset is: 06f2f000
Relocating to 8772f000, new gd at 8670eef8, sp at 8670eed0
initcall: 877357bc
initcall: 877358f8
initcall: 808068e8
dram_bank_mmu_setup: bank: 0
initcall: 808003d4
initcall: 808067c4
initcall: 808068d8
initcall: 808068bc
Now running in RAM - U-Boot at: 8772f000
initcall: 808067ec
initcall: 80806898
initcall: 808067a4
initcall: 808067f4
initcall: 80806938
NAND: nand: selected OMAP_ECC_BCH8_CODE_HW
0 MiB
initcall: 80806918
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
initcall: 80806868
*** Warning - readenv() failed, using default environment
Destroy Hash Table: 8779f9c4 table = 00000000
Create Hash Table: N=512
INSERT: table 8779f9c4, filled 1/521 rv 8671137c ==> name="bootcmd" value="run findfdt; run mmcboot;setenv mmcdev 1; setenv bootpart 1:2; run mmcboot;run nandboot;"
INSERT: table 8779f9c4, filled 2/521 rv 86711bd8 ==> name="bootdelay" value="1"
INSERT: table 8779f9c4, filled 3/521 rv 86710f58 ==> name="baudrate" value="115200"
INSERT: table 8779f9c4, filled 4/521 rv 86710774 ==> name="arch" value="arm"
INSERT: table 8779f9c4, filled 5/521 rv 86711f70 ==> name="cpu" value="armv7"
INSERT: table 8779f9c4, filled 6/521 rv 86711728 ==> name="board" value="am335x"
INSERT: table 8779f9c4, filled 7/521 rv 86710a30 ==> name="board_name" value="am335x"
INSERT: table 8779f9c4, filled 8/521 rv 86711ffc ==> name="vendor" value="ti"
INSERT: table 8779f9c4, filled 9/521 rv 867125c4 ==> name="soc" value="am33xx"
INSERT: table 8779f9c4, filled 10/521 rv 86711a5c ==> name="loadaddr" value="0x81000000"
INSERT: table 8779f9c4, filled 11/521 rv 867113e0 ==> name="kernel_addr_r" value="0x81000000"
INSERT: table 8779f9c4, filled 12/521 rv 86711d7c ==> name="fdtaddr" value="0x84000000"
INSERT: table 8779f9c4, filled 13/521 rv 86710d3c ==> name="fdt_addr_r" value="0x84000000"
INSERT: table 8779f9c4, filled 14/521 rv 86711bc4 ==> name="rdaddr" value="0x84080000"
INSERT: table 8779f9c4, filled 15/521 rv 86712100 ==> name="ramdisk_addr_r" value="0x84080000"
INSERT: table 8779f9c4, filled 16/521 rv 867103b4 ==> name="bootm_size" value="0x1000000"
INSERT: table 8779f9c4, filled 17/521 rv 86712650 ==> name="splashimage" value="0x85000000"
INSERT: table 8779f9c4, filled 18/521 rv 86710ee0 ==> name="boot_fdt" value="try"
INSERT: table 8779f9c4, filled 19/521 rv 86712768 ==> name="bootpart" value="0:2"
INSERT: table 8779f9c4, filled 20/521 rv 86710350 ==> name="bootdir" value="/boot"
INSERT: table 8779f9c4, filled 21/521 rv 8671169c ==> name="bootfile" value="uImage"
INSERT: table 8779f9c4, filled 22/521 rv 8671187c ==> name="fdtfile" value="undefined"
INSERT: table 8779f9c4, filled 23/521 rv 86712588 ==> name="console" value="ttyO0,115200n8"
INSERT: table 8779f9c4, filled 24/521 rv 86711f84 ==> name="partitions" value="uuid_disk=${uuid_gpt_disk};name=rootfs,start=2MiB,size=-,uuid=${uuid_gpt_rootfs}"
DELETE CANDIDATE: "optargs"
hdelete: DELETE key "optargs"
DELETE ERROR ##############################
INSERT: table 8779f9c4, filled 25/521 rv 86710878 ==> name="mmcdev" value="0"
INSERT: table 8779f9c4, filled 26/521 rv 86711db8 ==> name="mmcroot" value="/dev/mmcblk0p2 rw"
INSERT: table 8779f9c4, filled 27/521 rv 86711584 ==> name="mmcrootfstype" value="ext3 rootwait"
INSERT: table 8779f9c4, filled 28/521 rv 86711cb4 ==> name="rootpath" value="/export/rootfs"
INSERT: table 8779f9c4, filled 29/521 rv 86711e30 ==> name="nfsopts" value="nolock"
INSERT: table 8779f9c4, filled 30/521 rv 867126c8 ==> name="static_ip" value="${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off"
INSERT: table 8779f9c4, filled 31/521 rv 86710b98 ==> name="ramroot" value="/dev/ram0 rw"
INSERT: table 8779f9c4, filled 32/521 rv 86710364 ==> name="ramrootfstype" value="ext2"
INSERT: table 8779f9c4, filled 33/521 rv 86711e6c ==> name="ip_method" value="none"
INSERT: table 8779f9c4, filled 34/521 rv 86711534 ==> name="mmcargs" value="setenv bootargs console=${console} ${optargs} root=${mmcroot} rootfstype=${mmcrootfstype}"
INSERT: table 8779f9c4, filled 35/521 rv 86711c28 ==> name="ip" value="${ip_method}"
INSERT: table 8779f9c4, filled 36/521 rv 86711fd4 ==> name="spiroot" value="/dev/mtdblock4 rw"
INSERT: table 8779f9c4, filled 37/521 rv 867117a0 ==> name="spirootfstype" value="jffs2"
INSERT: table 8779f9c4, filled 38/521 rv 86712448 ==> name="spisrcaddr" value="0xe0000"
INSERT: table 8779f9c4, filled 39/521 rv 86711c8c ==> name="spiimgsize" value="0x362000"
INSERT: table 8779f9c4, filled 40/521 rv 867124ac ==> name="spibusno" value="0"
INSERT: table 8779f9c4, filled 41/521 rv 86711750 ==> name="spiargs" value="setenv bootargs console=${console} ${optargs} root=${spiroot} rootfstype=${spirootfstype}"
INSERT: table 8779f9c4, filled 42/521 rv 867119a8 ==> name="netargs" value="setenv bootargs console=${console} ${optargs} root=/dev/nfs nfsroot=${serverip}:${rootpath},${nfsopts} rw ip=dhcp"
INSERT: table 8779f9c4, filled 43/521 rv 86711fc0 ==> name="bootenv" value="uEnv.txt"
INSERT: table 8779f9c4, filled 44/521 rv 86710558 ==> name="loadbootenv" value="load mmc ${mmcdev} ${loadaddr} ${bootenv}"
INSERT: table 8779f9c4, filled 45/521 rv 86710bac ==> name="importbootenv" value="echo Importing environment from mmc ...; env import -t $loadaddr $filesize"
INSERT: table 8779f9c4, filled 46/521 rv 86710314 ==> name="ramargs" value="setenv bootargs console=${console} ${optargs} root=${ramroot} rootfstype=${ramrootfstype}"
INSERT: table 8779f9c4, filled 47/521 rv 867105f8 ==> name="loadramdisk" value="load mmc ${mmcdev} ${rdaddr} ramdisk.gz"
INSERT: table 8779f9c4, filled 48/521 rv 86711d04 ==> name="loadimage" value="load mmc ${mmcdev} ${loadaddr} ${bootfile}"
INSERT: table 8779f9c4, filled 49/521 rv 8671209c ==> name="loadfdt" value="load mmc ${mmcdev} ${fdtaddr} ${fdtfile}"
INSERT: table 8779f9c4, filled 50/521 rv 86712a4c ==> name="mmcloados" value="run mmcargs; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if run loadfdt; then bootm ${loadaddr} - ${fdtaddr}; else if test ${boot_fdt} = try; then bootm ${loadaddr}; else echo WARN: Cannot load the DT; fi; fi; else bootm ${loadaddr}; fi;"
INSERT: table 8779f9c4, filled 51/521 rv 86712b64 ==> name="mmcboot" value="mmc dev ${mmcdev}; if mmc rescan; then echo SD/MMC found on device ${mmcdev};if run loadbootenv; then echo Loaded environment from ${bootenv};run importbootenv;fi;if test -n $uenvcmd; then echo Running uenvcmd ...;run uenvcmd;fi;if run loadimage; then run mmcloados;fi;fi;"
INSERT: table 8779f9c4, filled 52/521 rv 8671286c ==> name="spiboot" value="echo Booting from spi ...; run spiargs; sf probe ${spibusno}:0; sf read ${loadaddr} ${spisrcaddr} ${spiimgsize}; bootz ${loadaddr}"
INSERT: table 8779f9c4, filled 53/521 rv 86712ac4 ==> name="netboot" value="echo Booting from network ...; setenv autoload no; dhcp; tftp ${loadaddr} ${bootfile}; tftp ${fdtaddr} ${fdtfile}; run netargs; bootz ${loadaddr} - ${fdtaddr}"
INSERT: table 8779f9c4, filled 54/521 rv 86711430 ==> name="ramboot" value="echo Booting from ramdisk ...; run ramargs; bootz ${loadaddr} ${rdaddr} ${fdtaddr}"
INSERT: table 8779f9c4, filled 55/521 rv 867105a8 ==> name="findfdt" value="if test $board_name = A335BONE; then setenv fdtfile am335x-bone.dtb; fi; if test $board_name = A335BNLT; then setenv fdtfile am335x-boneblack.dtb; fi; if test $board_name = A33515BB; then setenv fdtfile am335x-evm.dtb; fi; if test $board_name = A335X_SK; then setenv fdtfile am335x-evmsk.dtb; fi; if test $fdtfile = undefined; then echo WARNING: Could not determine device tree to use; fi; "
INSERT: table 8779f9c4, filled 56/521 rv 867116ec ==> name="mtdids" value="nand0=omap2-nand.0"
INSERT: table 8779f9c4, filled 57/521 rv 86711da4 ==> name="mtdparts" value="mtdparts=omap2-nand.0:128k(SPL),128k(SPL.backup1),128k(SPL.backup2),128k(SPL.backup3),1792k(u-boot),128k(u-boot-spl-os),128k(u-boot-env),5m(kernel),-(rootfs)"
INSERT: table 8779f9c4, filled 58/521 rv 86710ef4 ==> name="nandargs" value="setenv bootargs console=${console} ${optargs} root=${nandroot} rootfstype=${nandrootfstype}"
INSERT: table 8779f9c4, filled 59/521 rv 86711d18 ==> name="nandroot" value="ubi0:rootfs rw ubi.mtd=7,2048"
INSERT: table 8779f9c4, filled 60/521 rv 867110fc ==> name="nandrootfstype" value="ubifs rootwait=1"
INSERT: table 8779f9c4, filled 61/521 rv 867103c8 ==> name="nandboot" value="echo Booting from nand ...; run nandargs; nand read ${fdtaddr} u-boot-spl-os; nand read ${loadaddr} kernel; bootz ${loadaddr} - ${fdtaddr}"
INSERT: table 8779f9c4, filled 62/521 rv 86711228 ==> name="dfu_alt_info_emmc" value="rawemmc mmc 0 3751936"
INSERT: table 8779f9c4, filled 63/521 rv 86711bec ==> name="dfu_alt_info_mmc" value="boot part 0 1;rootfs part 0 2;MLO fat 0 1;MLO.raw mmc 0x100 0x100;u-boot.img.raw mmc 0x300 0x400;spl-os-args.raw mmc 0x80 0x80;spl-os-image.raw mmc 0x900 0x2000;spl-os-args fat 0 1;spl-os-image fat 0 1;u-boot.img fat 0 1;uEnv.txt fat 0 1"
INSERT: table 8779f9c4, filled 64/521 rv 86710c74 ==> name="dfu_alt_info_ram" value="kernel ram 0x80200000 0xD80000;fdt ram 0x80F80000 0x80000;ramdisk ram 0x81000000 0x4000000"
INSERT: table 8779f9c4, filled 65/521 rv 867125b0 ==> name="dfu_alt_info_nand" value="SPL part 0 1;SPL.backup1 part 0 2;SPL.backup2 part 0 3;SPL.backup3 part 0 4;u-boot part 0 5;u-boot-spl-os part 0 6;kernel part 0 8;rootfs part 0 9"
INSERT: free(data = 8670f2d8)
INSERT: done
initcall: 808067ac
initcall: 8081fecc
[LCD] Initializing LCD frambuffer at 86000000
LCD setup ...
[LCD] Using LCD frambuffer at 86000000
LCD 800, 480, 5
[LCD] LCD size 87747f34
[LCD] Drawing the logo...
RootMismatch: |u-boot.img||
Rootvfatname: |uimage|
RootMismatch: |uimage|uimage|
RootMismatch: |uimage||
RootName: logo.bmp, start: 0x22a9, size: 0x177038
Filesize: 1536056 bytes
1536056 bytes
gc - clustnum: 8873, startsect: 11127
Size: 1536056, got: 1536056
1536056 bytes read in 164 ms (8.9 MiB/s)
Initial value for argc=3
Final value for argc=3
the bmp: 800 x 480 with 32 bmp_bpix
Display-bmp: 800 x 480 with 0 colors
initcall: 80806858
initcall: 8081b9fc
initcall: 80800dac
initcall: 808012d8
initcall: 80806848
initcall: 80806828
initcall: 808003f8
initcall: 80806808
Net: <ethaddr> not set. Validating first E-fuse MAC
Phy not found
PHY status read failed
cpsw connected to Generic PHY
cpsw, usb_ether
initcall: 808067fc
### main_loop entered: bootdelay=1
### main_loop: bootcmd="run findfdt; run mmcboot;setenv mmcdev 1; setenv bootpart 1:2; run mmcboot;run nandboot;"
Hit any key to stop autoboot: 0
test(4): 'A335X_SK' '=' 'A335BONE': returns 1
Command failed, result=1test(4): 'A335X_SK' '=' 'A335BNLT': returns 1
Command failed, result=1test(4): 'A335X_SK' '=' 'A33515BB': returns 1
Command failed, result=1test(4): 'A335X_SK' '=' 'A335X_SK': returns 0
test(4): 'am335x-evmsk.dtb' '=' 'undefined': returns 1
Command failed, result=1Command failed, result=1mmc_init: 0, time 73
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
reading uEnv.txt
RootMismatch: |logo.bmp||
RootDentname == NULL - 15
** Unable to read file uEnv.txt **
Command failed, result=1Command failed, result=1Command failed, result=1reading uImage
RootName: uimage, start: 0x466, size: 0x312c08
Filesize: 3222536 bytes
3222536 bytes
gc - clustnum: 1126, startsect: 3380
Size: 3222536, got: 3222536
3222536 bytes read in 267 ms (11.5 MiB/s)
Initial value for argc=7
Final value for argc=7
test(4): 'try' '=' 'yes': returns 1
Command failed, result=1test(4): 'try' '=' 'try': returns 0
reading am335x-evmsk.dtb
** Unable to read file am335x-evmsk.dtb **
Command failed, result=1Command failed, result=1test(4): 'try' '=' 'try': returns 0
## Current stack ends at 0x8670e7f0 * kernel: cmdline image address = 0x81000000
## Booting kernel from Legacy Image at 81000000 ...
Image Name: Linux-3.2.0
Created: 2014-12-25 13:24:50 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3222472 Bytes = 3.1 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
kernel data at 0x81000040, len = 0x00312bc8 (3222472)
## No init Ramdisk
ramdisk start = 0x00000000, ramdisk end = 0x00000000
## No Flattened Device Tree
Loading Kernel Image ... OK
kernel loaded at 0x80008000, end = 0x8031abc8
using: ATAGS
## Transferring control to Linux (at address 80008000)...
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Linux version 3.2.0 (root@bogon) (gcc version 4.5.1 (ctng-1.8.1-FA) ) #16 Thu Dec 25 21:24:42 CST 2014
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: am335xevm
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] AM335X ES2.1 (sgx neon )
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 128MB = 128MB total
[ 0.000000] Memory: 123224k/123224k available, 7848k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xc8800000 - 0xff000000 ( 872 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc8000000 ( 128 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc05b1000 (5796 kB)
[ 0.000000] .init : 0xc05b1000 - 0xc05ed000 ( 240 kB)
[ 0.000000] .data : 0xc05ee000 - 0xc0657470 ( 422 kB)
[ 0.000000] .bss : 0xc0657494 - 0xc0686224 ( 188 kB)
[ 0.000000] NR_IRQS:396
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz
[ 0.000000] omap_dm_timer_switch_src: Switching to HW default clocksource(sys_clkin_ck) for timer1, this may impact timekeeping in low power state
[ 0.000000] OMAP clocksource: GPTIMER1 at 24000000 Hz
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000187] Calibrating delay loop... 795.44 BogoMIPS (lpj=3977216)
[ 0.087381] pid_max: default: 32768 minimum: 301
[ 0.087489] Security Framework initialized
[ 0.087582] Mount-cache hash table entries: 512
[ 0.087943] CPU: Testing write buffer coherency: ok
[ 0.088639] devtmpfs: initialized
[ 0.108146] omap_hwmod: pruss: failed to hardreset
[ 0.109212] print_constraints: dummy:
[ 0.109543] NET: Registered protocol family 16
[ 0.111557] OMAP GPIO hardware version 0.1
[ 0.113964] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.115665] omap_i2c.1: alias fck already exists
[ 0.116216] The board is a AM335x Starter Kit.
[ 0.116579] omap_hsmmc.0: alias fck already exists
[ 0.117113] da8xx_lcdc.0: alias fck already exists
[ 0.118151] davinci-mcasp.1: alias fck already exists
[ 0.118973] omap_i2c.2: alias fck already exists
[ 0.119872] _regulator_get: l3_main.0 supply vdd_core not found, using dummy regulator
[ 0.119960] am335x_opp_update: physical regulator not present for core(-22)
[ 0.120199] registered am33xx_sr device
[ 0.120507] omap2_mcspi.1: alias fck already exists
[ 0.120724] omap2_mcspi.2: alias fck already exists
[ 0.121625] edma.0: alias fck already exists
[ 0.121645] edma.0: alias fck already exists
[ 0.121663] edma.0: alias fck already exists
[ 0.146726] bio: create slab <bio-0> at 0
[ 0.148864] SCSI subsystem initialized
[ 0.150736] usbcore: registered new interface driver usbfs
[ 0.151025] usbcore: registered new interface driver hub
[ 0.151212] usbcore: registered new device driver usb
[ 0.151509] registerd cppi-dma Intr @ IRQ 17
[ 0.151522] Cppi41 Init Done Qmgr-base(c887a000) dma-base(c8878000)
[ 0.151531] Cppi41 Init Done
[ 0.151556] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3
[ 0.151835] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1
[ 0.152929] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
[ 0.153533] tps65910 1-002d: could not be detected
[ 0.167390] omap_i2c omap_i2c.2: bus 2 rev2.4.0 at 100 kHz
[ 0.169199] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 0.170329] Switching to clocksource gp timer
[ 0.187079] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 0.187272] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
[ 0.187574] MUSB0 controller's USBSS revision = 4ea20800
[ 0.187606] musb0: Enabled SW babble control
[ 0.188486] musb-hdrc musb-hdrc.0: USB OTG mode controller at c883c000 using DMA, IRQ 18
[ 0.188638] musb-hdrc musb-hdrc.1: dma type: dma-cppi41
[ 0.188922] MUSB1 controller's USBSS revision = 4ea20800
[ 0.188947] musb1: Enabled SW babble control
[ 0.189352] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 0.189437] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 0.189568] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.189581] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.189594] usb usb1: Product: MUSB HDRC host driver
[ 0.189603] usb usb1: Manufacturer: Linux 3.2.0 musb-hcd
[ 0.189613] usb usb1: SerialNumber: musb-hdrc.1
[ 0.190508] hub 1-0:1.0: USB hub found
[ 0.190545] hub 1-0:1.0: 1 port detected
[ 0.191111] musb-hdrc musb-hdrc.1: USB Host mode controller at c883e800 using DMA, IRQ 19
[ 0.191523] NET: Registered protocol family 2
[ 0.191712] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.191999] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.192080] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.192128] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.192139] TCP reno registered
[ 0.192150] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.192171] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.192332] NET: Registered protocol family 1
[ 0.192576] RPC: Registered named UNIX socket transport module.
[ 0.192588] RPC: Registered udp transport module.
[ 0.192596] RPC: Registered tcp transport module.
[ 0.192604] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.192805] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.193024] omap-gpmc omap-gpmc: GPMC revision 6.0
[ 0.193042] Registering NAND on CS0
[ 0.200346] VFS: Disk quotas dquot_6.5.2
[ 0.200481] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.201005] msgmni has been set to 240
[ 0.204004] alg: No test for stdrng (krng)
[ 0.204691] io scheduler noop registered
[ 0.204705] io scheduler deadline registered
[ 0.204771] io scheduler cfq registered (default)
[ 0.206047] da8xx_lcdc da8xx_lcdc.0: GLCD: Found NHD-4.3-ATXI#-T-1 panel
[ 0.213270] Console: switching to colour frame buffer device 60x34
[ 0.218215] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[ 0.874181] console [ttyO0] enabled
[ 0.878529] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[ 0.886401] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[ 0.894229] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[ 0.902057] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[ 0.909851] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[ 0.918210] omap4_rng omap4_rng: OMAP4 Random Number Generator ver. 2.00
[ 0.934558] brd: module loaded
[ 0.942682] loop: module loaded
[ 0.946033] tsl2550 2-0039: standard operating mode
[ 0.951394] tsl2550: probe of 2-0039 failed with error -121
[ 0.957436] i2c-core: driver [tsl2550] using legacy suspend method
[ 0.963918] i2c-core: driver [tsl2550] using legacy resume method
[ 0.972699] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 0.979641] m25p80 spi2.0: unrecognized JEDEC id ffffff
[ 0.985661] omap2-nand driver initializing
[ 0.990518] ONFI flash detected
[ 0.993923] ONFI param page 0 valid
[ 0.997572] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xda (Micron MT29F2G08ABAEAWP)
[ 1.006155] Creating 8 MTD partitions on "omap2-nand.0":
[ 1.011737] 0x000000000000-0x000000020000 : "SPL"
[ 1.018145] 0x000000020000-0x000000040000 : "SPL.backup1"
[ 1.025170] 0x000000040000-0x000000060000 : "SPL.backup2"
[ 1.032181] 0x000000060000-0x000000080000 : "SPL.backup3"
[ 1.039133] 0x000000080000-0x000000260000 : "U-Boot"
[ 1.046540] 0x000000260000-0x000000280000 : "U-Boot Env"
[ 1.053420] 0x000000280000-0x000000780000 : "Kernel"
[ 1.061927] 0x000000780000-0x000010000000 : "File System"
[ 1.171442] OneNAND driver initializing
[ 1.176815] CAN device driver interface
[ 1.180865] CAN bus driver for Bosch D_CAN controller 1.0
[ 1.230393] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[ 1.236858] davinci_mdio davinci_mdio.0: detected phy mask fffffffd
[ 1.340357] davinci_mdio davinci_mdio.0: timed out waiting for user access
[ 1.347798] davinci_mdio: probe of davinci_mdio.0 failed with error -5
[ 1.354979] usbcore: registered new interface driver zd1201
[ 1.361002] usbcore: registered new interface driver cdc_ether
[ 1.367235] usbcore: registered new interface driver cdc_eem
[ 1.373302] usbcore: registered new interface driver dm9601
[ 1.379168] cdc_ncm: 04-Aug-2011
[ 1.382708] usbcore: registered new interface driver cdc_ncm
[ 1.388620] Initializing USB Mass Storage driver...
[ 1.393935] usbcore: registered new interface driver usb-storage
[ 1.400215] USB Mass Storage support registered.
[ 1.405593] mousedev: PS/2 mouse device common for all mice
[ 1.412359] input: ti-tsc as /devices/platform/omap/ti_tscadc/tsc/input/input0
[ 1.421075] omap_rtc am33xx-rtc: rtc core: registered am33xx-rtc as rtc0
[ 1.428303] i2c /dev entries driver
[ 1.432637] Linux video capture interface: v2.00
[ 1.437768] usbcore: registered new interface driver uvcvideo
[ 1.443799] USB Video Class driver (1.1.1)
[ 1.448341] lm75: probe of 2-0048 failed with error -121
[ 1.591327] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.597844] _regulator_get: deviceless supply vdd_mpu not found, using dummy regulator
[ 1.606565] cpuidle: using governor ladder
[ 1.611323] cpuidle: using governor menu
[ 1.618417] omap4_aes_mod_init: loading AM33X AES driver
[ 1.624144] omap4-aes omap4-aes: AM33X AES hw accel rev: 3.02
[ 1.630879] omap4_aes_probe: probe() done
[ 1.635300] omap4_sham_mod_init: loading AM33X SHA/MD5 driver
[ 1.641456] omap4-sham omap4-sham: AM33X SHA/MD5 hw accel rev: 4.03
[ 1.656092] omap4_sham_probe: probe() done
[ 1.665918] usbcore: registered new interface driver usbhid
[ 1.671784] usbhid: USB HID core driver
[ 1.676506] tiadc tiadc: attached adc driver
[ 1.681842] usbcore: registered new interface driver snd-usb-audio
[ 1.690230] _regulator_get: 1-001b supply IOVDD not found, using dummy regulator
[ 1.698059] _regulator_get: 1-001b supply DVDD not found, using dummy regulator
[ 1.705742] _regulator_get: 1-001b supply AVDD not found, using dummy regulator
[ 1.713440] _regulator_get: 1-001b supply DRVDD not found, using dummy regulator
[ 1.723759] asoc: tlv320aic3x-hifi <-> davinci-mcasp.1 mapping ok
[ 1.731725] ALSA device list:
[ 1.734859] #0: AM335X EVM
[ 1.737864] oprofile: hardware counters not available
[ 1.743167] oprofile: using timer interrupt.
[ 1.747649] nf_conntrack version 0.5.0 (1925 buckets, 7700 max)
[ 1.754291] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.759942] TCP cubic registered
[ 1.763348] NET: Registered protocol family 17
[ 1.768004] can: controller area network core (rev 20090105 abi 8)
[ 1.774557] NET: Registered protocol family 29
[ 1.779199] can: raw protocol (rev 20090105)
[ 1.783675] can: broadcast manager protocol (rev 20090105 t)
[ 1.789635] Registering the dns_resolver key type
[ 1.794636] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 1.802668] ThumbEE CPU extension supported.
[ 1.807191] mux: Failed to setup hwmod io irq -22
[ 1.812750] Power Management for AM33XX family
[ 1.817602] Trying to load am335x-pm-firmware.bin (60 secs timeout)
[ 1.824311] Copied the M3 firmware to UMEM
[ 1.828666] Cortex M3 Firmware Version = 0x181
[ 1.833510] _regulator_get: deviceless supply vdd_core not found, using dummy regulator
[ 1.841966] smartreflex smartreflex: am33xx_sr_probe: cannot determine opp
[ 1.849165] smartreflex: probe of smartreflex failed with error -22
[ 1.856298] sr_init: platform driver register failed
[ 1.866096] clock: disabling unused clocks to save power
[ 1.881451] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 1.892101] Detected MACID=7c:66:9d:54:69:d9
[ 1.897430] mmc0: new high speed SD card at address 0002
[ 1.903588] cpsw: Detected MACID = 7c:66:9d:54:69:db
[ 1.909786] mmcblk0: mmc0:0002 00000 1.86 GiB
[ 1.916459] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 1.923841] mmcblk0: p1 p2
[ 1.928011] omap_rtc am33xx-rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 1.949403] kjournald starting. Commit interval 5 seconds
[ 1.955203] EXT3-fs (mmcblk0p2): warning: maximal mount count reached, running e2fsck is recommended
[ 1.972900] EXT3-fs (mmcblk0p2): using internal journal
[ 1.978367] EXT3-fs (mmcblk0p2): recovery complete
[ 1.983392] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
[ 1.990636] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 2.000694] devtmpfs: mounted
[ 2.004193] Freeing init memory: 240K
/bin/sh: can't access tty; job control tur/ # [ 5.24 |
