自己做了个MT7620N核心板玩,结果ralink的uboot调不过去了。看Log DDR2貌似已经检过了,大小也识别正确,就是代码重定向到DDR后没输出了……
往有经验的朋友给点思路,多谢啦~~ DDR2颗粒为K4T51163。
我的Log,自己加了调试信息:
U-Boot 1.1.3 (Dec 17 2014 - 21:10:07)
Board: Petrel Test Platform R0A DRAM:
get_ram_size: Start verifing memory
--> Retrieving addr=0x80000004
--> Retrieving addr=0x80000008
--> Retrieving addr=0x80000010
--> Retrieving addr=0x80000020
--> Retrieving addr=0x80000040
--> Retrieving addr=0x80000080
--> Retrieving addr=0x80000100
--> Retrieving addr=0x80000200
--> Retrieving addr=0x80000400
--> Retrieving addr=0x80000800
--> Retrieving addr=0x80001000
--> Retrieving addr=0x80002000
--> Retrieving addr=0x80004000
--> Retrieving addr=0x80008000
--> Retrieving addr=0x80010000
--> Retrieving addr=0x80020000
--> Retrieving addr=0x80040000
--> Retrieving addr=0x80080000
--> Retrieving addr=0x80100000
--> Retrieving addr=0x80200000
--> Retrieving addr=0x80400000
--> Retrieving addr=0x80800000
--> Retrieving addr=0x81000000
--> Retrieving addr=0x82000000
Return Real size =67108864 !!
64 MB
rt2880 uboot v0.00e04 05/25/2006
SERIAL_CLOCK_DIVISOR =16
kaiker,,CONFIG_BAUDRATE =115200
SDRAM SIZE:04000000
Top of RAM usable for U-Boot at: 84000000
Reserving 275k for U-Boot at: 83fb8000
Reserving 260k for malloc() at: 83f77000
Reserving 44 Bytes for Board Info at: 83f76fd4
Reserving 36 Bytes for Global Data at: 83f76fb0
Reserving 128k for boot params() at: 83f56fb0
Stack Pointer at: 83f56f98
relocate_code Pointer at: 83fb8000
(死在这里……)
附上别人板子正常的Log,没加调试信息的:
U-Boot 1.1.3 (Feb 15 2014 - 19:45:10)
Board: Ralink SOC AP DRAM: 64 MB
relocate_code Pointer at: 83fb4000
enable ephy clock...done. rf reg 29 = 5
SSC disabled.
spi_wait_nsec: 29
spi device id: c2 20 18 c2 20 (2018c220)
find flash: MX25L12805D
raspi_read: from:30000 len:1000
*** Warning - bad CRC, using default environment
Drogoo UBoot Version: 4.1.2.0
Ralink ASIC (Port5<->None)
DRAM component: 512 Mbits DDR, width 16
DRAM bus: 16 bit
Total memory: 64 MBytes
Flash component: SPI Flash
Date:Feb 15 2014 Time:19:45:10
icache: sets:512, ways:4, linesz:32 ,total:65536
dcache: sets:256, ways:4, linesz:32 ,total:32768
##### The CPU freq = 580 MHZ ####
estimate memory size =64 Mbytes
Please choose the operation:
1: Load system code to SDRAM via TFTP.
2: Load system code then write to Flash via TFTP.
3: Boot system code via Flash (default).
4: Entr boot command line interface.
7: Load Boot Loader code then write to Flash via Serial.
9: Load Boot Loader code then write to Flash via TFTP. |
