发表于 2014-12-17 14:34:57
`define RADIAN_16
/* Bit accuracy for sin and cos
The X and Y values are computed using a `XY_BITS + sign bit accuracy. The format is assumed to be U(1,15) + sign bit
However, the CORDIC algorythm really doesn't care.
`define XY_BITS 16
/* Bit accuracy for theta
The angle can be represented in either degree or radians. This define determines the number of bits used to represent the
angle. Going to a higher number of bits would allow more iterations thus improving accuracy. 16 bits is enough for
most applications.
`define THETA_BITS 16
/* Iteration accuracy
This is the number of times the algorithm will iterate. For pipelined options, this is the number of stages.
This number is <= the number of bits used in the angles
`define ITERATIONS 16
`define ITERATION_BITS 4 // 2^ITERATION_BITS = ITERATIONS
/* Implementation options
The CORDIC core can be realized in one of three methods:
ITERATE: This option builds a single ROTATOR. The user provides the arguments and gives the core ITERATIONS
clock cycles to get the result. A signal named init is instantiated to load the input values. It uses the
least amount of LUTs
PIPELINE: This option can take a new input on every clock and gives results ITERATIONS clock cycles later. It uses the
most amount of LUTS.
COMBINATORIAL: This option gives a result in a single clock cycle at the expense of very deep logic levels. The
combinatorial implementation runs at about 10 mhz while the iterative ones run at about 125 in a
Lattice ECP2 device.
//`define ITERATE
`define PIPELINE
//`define COMBINATORIAL
/* CORDIC function
The CORDIC core works in one of two methods: VECTOR and ROTATE.
VECTOR: This mode seeks to reduce the Y values and is used to compute an angle given a point.
Enter the sin and cos of the desired angle and the core calculates the angle. This
mode computes ARCTAN.
ROTATE: This mode seeks to reduce the angle. It can be used to compute the sin and cos of a given angle
//`define VECTOR // computes the arctan and square root
`define ROTATE // computes sin cos
/* CORDIC GAIN
The CORDIC algorithm has an associated gain that is:
CORDIC_gain = for (i=0;i<n;i++) An = An*SQRT(1+(1/2^2i)
This quickly converges to ~ 1.647 as i goes to infinity.
For 16 bit numbers in the U(1,15) the value is 17'd53955
*** NOTE *** If you change the number representations
you will have to recompute these values.
`define CORDIC_GAIN 17'd53955 //
`define CORDIC_1 17'd19896 // CORDIC inverse
//==================== DO NOT EDIT BELOW THIS LINE ======================
`ifdef PIPELINE
`define GENERATE_LOOP
`endif
`ifdef COMBINATORIAL
`endif
/* Signed shifter
This module does an arbitrary right shift to implement'
the 1/2^i function on signed numbers
module signed_shifter ( //移位模块
input wire [`ITERATION_BITS-1:0] i,
input wire signed [`XY_BITS:0] D,
output reg signed [`XY_BITS:0] Q );
integer j;
always @ *
begin
Q = D;
for(j=0;j<i;j=j+1)
Q = (Q >> 1) | (D[`XY_BITS] << `XY_BITS);
end
endmodule
/* Rotator
This module is the heart of the CORDIC computer and implements the CORDIC algorithm.
Input values x_i, y_i, and z_i are micro computed based on the iteration step
and the arctan of that step. See the description of the CORDIC algorithm for details.
module rotator ( //旋转模块,调用上面的移位模块。
input wire clk,
input wire rst,
`ifdef ITERATE
input wire init,
input wire [`ITERATION_BITS:0] iteration,
input wire signed [`THETA_BITS:0] tangle,
`endif
input wire signed [`XY_BITS:0] x_i,
input wire signed [`XY_BITS:0] y_i,
input wire signed [`THETA_BITS:0] z_i,
output wire signed [`XY_BITS:0] x_o,
output wire signed [`XY_BITS:0] y_o,
output wire signed [`THETA_BITS:0] z_o
`ifdef GENERATE_LOOP
parameter integer iteration = 0;
parameter signed [`THETA_BITS:0] tangle = 0;
`endif
reg signed [`XY_BITS:0] x_1;
reg signed [`XY_BITS:0] y_1;
reg signed [`THETA_BITS:0] z_1;
wire signed [`XY_BITS:0] x_i_shifted;
wire signed [`XY_BITS:0] y_i_shifted;
signed_shifter x_shifter(iteration,x_i,x_i_shifted);
signed_shifter y_shifter(iteration,y_i,y_i_shifted);
always @ *
`endif
`ifdef ITERATE
always @ (posedge clk)
`endif
`ifdef PIPELINE
`endif
if (rst) begin
x_1 <= 0;
y_1 <= 0;
z_1 <= 0;
end else begin
`ifdef ITERATE
if (init) begin
x_1 <= x_i;
y_1 <= y_i;
z_1 <= z_i;
end else
`endif
`ifdef ROTATE //旋转模式
if (z_i < 0) begin
`endif
`ifdef VECTOR //向量模式
if (y_i > 0) begin // 根据>0,<0选择加减
`endif
x_1 <= x_i + y_i_shifted; //shifter(y_1,i); //(y_1 >> i);
y_1 <= y_i - x_i_shifted; //shifter(x_1,i); //(x_1 >> i);
z_1 <= z_i + tangle;
end else begin
x_1 <= x_i - y_i_shifted; //shifter(y_1,i); //(y_1 >> i);
y_1 <= y_i + x_i_shifted; //shifter(x_1,i); //(x_1 >> i);
z_1 <= z_i - tangle;
end
end
assign x_o = x_1;
assign y_o = y_1;
assign z_o = z_1;
endmodule
CORDIC
module cordic (
input wire clk,
input wire rst,
`ifdef ITERATE
input wire init,
`endif
input wire signed [`THETA_BITS:0] theta_i,
output wire signed [`THETA_BITS:0] theta_o
`ifdef VALID_FLAG
,input wire valid_in, output wire valid_out
`endif
`ifdef RADIAN_16
arctan table in radian format 16 bit + sign bit.
function [`THETA_BITS:0] tanangle;
input [3:0] i;
begin
case (i)
4'b0000: tanangle = 17'd25735 ; // 1/1 弧度为单位, 反正切1,再乘以位宽
4'b0001: tanangle = 17'd15192; // 1/2 弧度为单位, 反正切0.5,再乘以位宽
4'b0010: tanangle = 17'd8027; // 1/4
4'b0011: tanangle = 17'd4075; // 1/8 。。。。
4'b0100: tanangle = 17'd2045; // 1/16
4'b0101: tanangle = 17'd1024; // 1/32
4'b0110: tanangle = 17'd512; // 1/64
4'b0111: tanangle = 17'd256; // 1/128
4'b1000: tanangle = 17'd128; // 1/256
4'b1001: tanangle = 17'd64; // 1/512
4'b1010: tanangle = 17'd32; // 1/1024
4'b1011: tanangle = 17'd16; // 1/2048
4'b1100: tanangle = 17'd8; // 1/4096
4'b1101: tanangle = 17'd4; // 1/8192
4'b1110: tanangle = 17'd2; // 1/16k
4'b1111: tanangle = 17'd1; // 1/32k
endcase
end
endfunction
`endif
`ifdef DEGREE_8_8
arctan table in degree U(8,8) format 16 bits + sign bit
input [3:0] i;
begin
case (i)
0: tanangle = 17'd11520; // theta = 45.000000 单位为°, 反正切1,再乘以位宽
1: tanangle = 17'd6800; // theta = 22.500000 反正切0.5,再乘以位宽
2: tanangle = 17'd3593; // theta = 11.250000 反正切0.25,再乘以位宽
3: tanangle = 17'd1824; // theta = 5.625000 。。。。
4: tanangle = 17'd915; // theta = 2.812500
5: tanangle = 17'd458; // theta = 1.406250
6: tanangle = 17'd229; // theta = 0.703125
7: tanangle = 17'd114; // theta = 0.351562
8: tanangle = 17'd57; // theta = 0.175781
9: tanangle = 17'd28; // theta = 0.087891
10: tanangle = 17'd14; // theta = 0.043945
11: tanangle = 17'd7; // theta = 0.021973
12: tanangle = 17'd3; // theta = 0.010986
13: tanangle = 17'd1; // theta = 0.005493
14: tanangle = 17'd0; // theta = 0.002747
15: tanangle = 17'd0; // theta = 0.001373
endcase
end
endfunction
`endif
wire signed [`XY_BITS:0] x [`ITERATIONS-1:0];
wire signed [`XY_BITS:0] y [`ITERATIONS-1:0];
wire signed [`THETA_BITS:0] z [`ITERATIONS-1:0];
assign x[0] = x_i;
assign y[0] = y_i;
assign z[0] = theta_i;
assign x_o = x[`ITERATIONS-1];
assign y_o = y[`ITERATIONS-1];
assign theta_o = z[`ITERATIONS-1];
`endif // GENERATE_LOOP
`ifdef VALID_FLAG
wire [`ITERATIONS-1:0] v;
assign valid_out v[`ITERATIONS-1];
always @ (posedge clk or posedge rst)
if (rst) v <= 0;
else begin
v <= v << 1;
v[0] <= valid_in;
end
`endif
genvar i;
generate for(i=0;i<`ITERATIONS-1;i=i+1)
begin:inst
rotator U (clk,rst,x,y,z,x[i+1],y[i+1],z[i+1]);
defparam U.iteration = i;
defparam U.tangle = tanangle(i);
end
endgenerate
`endif
`ifdef ITERATE
reg [`ITERATION_BITS:0] iteration;
wire signed [`XY_BITS:0] x,y,z;
assign x = init ? x_i : x_o;
assign y = init ? y_i : y_o; //这里把上次的迭代结果传给下一次的x,y
assign z = init ? theta_i : theta_o;
always @ (posedge clk or posedge init)
if (init) iteration <= 0;
else iteration <= iteration + 1; //迭代循环
rotator U (clk,rst,init,iteration,tanangle(iteration),x,y,z,x_o,y_o,theta_o);
`endif
endmodule |
