从最新的AD15.0中发现在可以利用WEBENCH® Design Center进行仿真——有关微博如下:
Announcement: FREE TI WEBENCH® Altium Connector Extension
Dan Fernsebner
, Jun 03, 2014
Hi Everyone,
I’m very pleased to announce the release of another great 3rd party extension for Altium Designer, the WEBENCH® Altium Connector.
The WEBENCH® Design Center and WEBENCH® Simulation Engine assist enormously with the development of power, lighting, filtering, clocking and sensing designs. Allowing you to generate, optimize and simulate designs, while making the necessary value-based tradeoffs to meet your design and supply chain requirements.
The free WEBENCH® Altium Connector provides both an interface to the online WEBENCH® Design Center and an offline interface to the WEBENCH® Simulation Engine, allowing the following:
Access WEBENCH® Design Center from Altium Designer and optimize your design.
Export that design from WEBENCH® to Altium Designer.
Simulate any circuit using the fast WEBENCH® Simulation Engine from Altium Designer.
Details about using this extensions can be found in Altium Techdocs, here and more about WEBENCH® from Texas Instruments can be found here. Below are installation and licensing instructions.
Kind Regards and Thanks,
Dan
Installation and Setup
The extension is visible to subscription customers from Altium Designer, DXP > Extensions and Updates > Purchased. A WEBENCH® license from Texas Instruments is required.
Installing License for WEBENCH® Simulation Engine:
When you run the WEBENCH simulation engine for first time on a design, it will ask for a node license.
Attach the logfile showing the WBSE license not found and send an email to wbse@ti.com for a license. This file is needed for generating a WEBENCH® Simulation Engine license.
Once license is received, rename the license file as "node_license" (if not already done) and place it in <WEBENCH Extension Installation Directory>\WBSE.
Usually you will find it in c:\ProgramData\Altium\Altium Designer {2F259E6B-E4FF-4EB4-9ABC-063D5507D841}\Extensions\WEBENCH\WBSE\node_license
You are ready to use the WEBENCH® Simulation Engine.
Note: The received license file may have some extension associated with it. The license file must be renamed to "node_license", removing any extension if present.
上面看起来很简单:
1.确保你的AD有能用的license ,这是在网上很多,破解的也行,试用的license 也罢,只要能用就OK.
2.正常运行AD15(AD14也可以):按如下操作
Add / remove modules can:
a) Run the installer again and choose to update an existing installation
b) of Altium Designer (DXP -> My Account -> Extensions & Updates -> Platform -> Configure)这里可以查看你是插件配置情况
c ) Extensions (Software Extensions, Hardware Devices) are installed and removed from the
Altium Designer (DXP -> My Account -> Extensions & Updates)——————):》在这里会发现有WEBENCH插件,点击安装。如果你是正式 altium客户,这个插件是从官方网下载的,如果你是吊丝这个插件应你在你的下载离线安装包里。确保联网。
装好后,reset DXP
3.打开 % ProgramData% \ Altium \ Altium Designer {<GUID>} \ WEBENCH \ WBSE \ Examples下的项目文件,如图你会发现惊喜:
4.能看见WEBENCH 在altium菜单。然后---》》》》Start the simulation WEBENCH。运行后会提示没有license ,这时点击打开错误提示,其实就是TI的个网页:http://webench.ti.com/appinfo/webench/scripts
申请成功后如下:
5.这时要用IT的账户登陆(没有自己申请一个),获取 simulation WEBENCH 的激活吗。获取激活码后,再回到AD15激活WEBENCH功能---如下图操作:
如上动画如示操作。再回到原来打开的WEBENCH的项目文件,可仿真运行,没提示错误。
