#include <iom16v.h>
#include <macros.h>
#define uint unsigned int
#pragma data:code
const table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d, 0x07,
0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0XFF};
void delay(uint ms)
uint i,j;
for(i=0;i<ms;i++)
for(j=0;j<1141;j++);
void show(uchar j,uchar k)
PORTA|=BIT(3);
PORTB=table[j];
PORTA&=~BIT(3);
PORTB=0XFF;
PORTB&=~BIT(k);
PORTA|=BIT(4);
PORTA&=~BIT(4);
delay(1);
uchar key_press()
uchar i;
DDRD=0XFF;
PORTD=0XF0;
DDRD=0X0F;
i=PIND;
if(i==0XF0)
DDRD=0XFF;
return 0;
DDRD=0XFF;
return 1;
uchar key_scan()
uchar key,i=0X7F,j;
delay(10);
if(key_press())
do
i=(i<<1|i>>7);
PORTD=i;
DDRD=0X0F;
key=PIND;
j=key&0XF0;
}while(j==0XF0);
while(key_press());
switch(key)
case 0xEE:
key=0x0;
case 0xDE:
key=0x1;
case 0xBE:
key=0x2;
case 0x7E:
key=0x3;
case 0xED:
key=0x4;
case 0xDD:
key=0x5;
case 0xBD:
key=0x6;
case 0x7D:
key=0x7;
case 0xEB:
key=0x8;
case 0xDB:
key=0x9;
case 0xBB:
key=0xA;
case 0x7B:
key=0xB;
case 0xE7:
key=0xC;
case 0xD7:
key=0xD;
case 0xB7:
key=0xE;
case 0x77:
key=0xF;
default:
key=16;
key=16;
return key;
void main()
uchar l;
DDRA|=0X18;// 0001 1000
DDRB=0XFF;
if(key_press())
l=key_scan();
show(l,0);
while(key_press());在程序中加这个是干什么的啊 ???有没有人跟我讲一下哈,关于矩阵键盘程序还有没有更加简便一点的写法啊?非常感谢 |
