回复: 8
有人使用过C8051F300的SMBUS模拟I2C从机么?
发表于 2014-11-12 11:09:09 | 显示全部楼层 |阅读模式
LZ现在模拟I2C从机,现在写入数据的时候,第2位到第8位的数据不能正常写入,其他位都是正常。
发表于 2014-11-16 11:14:55 | 显示全部楼层
可的啊,你是不是地址没配对?
 楼主| 发表于 2014-11-16 14:12:23 | 显示全部楼层
dzymushi 发表于 2014-11-16 11:14
可的啊,你是不是地址没配对?
没明白,地址没配对是什么错误。
是指在写入数据的时候对应的地址写错了么?
可是这八位在写的时候数据完全没有写进去。应该不是这个吧。
发表于 2014-11-16 16:43:07 | 显示全部楼层
void Timer3_ISR (void) interrupt 14
   SMB0CF &= ~0x80;                    // Disable SMBus
   SMB0CF |= 0x80;                     // Re-enable SMBus
   TMR3CN &= ~0x80;                    // Clear Timer3 interrupt-pending flag
void PORT_Init (void)
   P0MDOUT = 0x00;                     // All P0 pins open-drain output
   XBR0 = XBR0|0x04;                        // Enable SMBus pins
   XBR1 = XBR0|0x40;                        // Enable crossbar and weak pull-ups
   P0 = 0xFF;
void smbusInit (void)
   PCA0MD &= ~0x40;                    // WDTE = 0 (Disable watchdog
                                       // timer)
   OSCICN = 0x83;           //选择内部时钟,分频系数是1
   OSCICN |= 0x03;                     // Set internal oscillator to highest
                                       // setting of 24500000
   PORT_Init();                        // Initialize Crossbar and GPIO
   //Timer1_Init();                      // Configure Timer1 for use
                                       // with SMBus baud rate
   //Timer3_Init ();                     // Configure Timer3 for use with
                                       // SCL low timeout detect
   SMBus_Init ();                      // Configure and enable SMBus
   EIE1 |= 0x01;                       // Enable the SMBus interrupt
   EA = 1;                             // Global interrupt enable
void SMBus_ISR (void) interrupt 7
   if (ARBLOST == 0)
      switch (SMB0CN & 0xF0)           // Decode the SMBus status vector
         // Slave Receiver: Start+Address received,收到起始信号和从机地址
         case  SMB_SRADD:
            STA = 0;                   // Clear STA bit
            if((SMB0DAT&0xFE) == (SLAVE_ADDR&0xFE)) // 地址过滤
                    {                          // If the received address matches,
                       ACK = 1;                // ACK the received slave address
                       if((SMB0DAT&0x01) == READ) // If the transfer is a master READ,
                        //smbDataRead(smbData[0],smbData[1]);
                                                SMB0DAT = smbRecData;
                                                LED_SMB = ~LED_SMB;
                                                //smbIndex=0;
            else                       // If received slave address does not
                    {                          // match,
                       ACK = 0;                // NACK received address
         // Slave Receiver: Data received,从机接收到数据
         case  SMB_SRDB:
                           smbData[smbIndex]=SMB0DAT;
                           smbIndex++;
               if(smbIndex>=NUM_BYTES_RD)//3位收全了
                                  //LED_SMB1 = ~LED_SMB1;
                                  smbIndex =0;
                                  smbReady=1;
                                  sendMsgRequest =1;
                                  //smbRecData = smbRecData|0x01;
                           ACK = 1;                // ACK received data
                        //        if(1==smbDataWrite(smbData[0],smbData[1]))
                        //           SMB0DAT = smbRecData;
         // Slave Receiver: Stop received while either a Slave Receiver or
         // Slave Transmitter,从机复位或者结束通信
         case  SMB_SRSTO:
            STO = 0;                   // STO must be cleared by software when a STOP is detected as a slave
         case  SMB_STDB: //从机发送完一个字节
            if (ACK == 1)              // If Master ACK's, send the next byte
             SMB0DAT = 0xaa;
         // Slave Transmitter: Arbitration lost, Stop detected
         // This state will only be entered on a bus error condition.
         // In normal operation, the slave is no longer sending data or has
         // data pending when a STOP is received from the master, so the TXMODE
         // bit is cleared and the slave goes to the SRSTO state.
         case  SMB_STSTO:  //丢失,直接复位
         default: //其他情况直接复位
            SMB0CF &= ~0x80;           // Reset communication
            SMB0CF |= 0x80;
            STA = 0;
            STO = 0;
            ACK = 0;
   // ARBLOST = 1, Abort failed transfer
      STA = 0;
      STO = 0;
      ACK = 0;
   SI = 0;                             // Clear SMBus interrupt flag
发表于 2016-8-24 00:15:08 | 显示全部楼层
喔,我现在用C8051F340,smbus寄存器跟C8051F300一样,没有地址寄存器SMB0ADR。我也想实现两片C8051F340的SMBUS的主从通信,不知道楼主是否已经调通。
出20入34汤圆
发表于 2021-7-17 10:34:47 | 显示全部楼层
楼主现在调的怎么样了?
发表于 2021-7-17 11:41:28 | 显示全部楼层
yjamdfhqjs 发表于 2021-7-17 10:34
楼主现在调的怎么样了?
用硬件I2C做slave 从机,不更香吗?
如果非得要软件做,也是可以滴,只是比较麻烦一些。
出20入34汤圆
发表于 2021-7-17 12:48:40 | 显示全部楼层
如果非得要软件做,也是可以滴,只是比较麻烦一些。 ...
你弄过吗 我两个都没做过
发表于 2021-7-17 13:18:16 | 显示全部楼层
yjamdfhqjs 发表于 2021-7-17 12:48
你弄过吗 我两个都没做过
是的,都做过。
GMT+8, 2024-9-1 06:57
