如题。代码如下。
主函数:
#include <iom16v.h>
#include <macros.h>
#include "lcd12864.h"
Lcd_Init();
Lcd_Str(1,5,"是否调整参数?");
.C文件
unsigned char N[]={"0123456789"};
//const prog_uchar img[]={};//定义128*64的图像
void delay_lcd_us(unsigned int xus)/*us延时函数 8*0.125=1us*/
int i,j;
for(j=0;j<8;j++)
for (i=0;i<xus;i++)
NOP();
void delay_lcd_ms(unsigned int xms)/*ms延时函数*/
while(xms--)
unsigned int j;
for(j=1;j<=1332;j++);
LCD送命令子函数
unsigned char Read_data(void)
unsigned char i,dat;
unsigned char temp1=0,temp2=0;
CS_off;
SID_off;
CS_on;
dat=0xfc;
for(i=0;i<8;i++)
if((dat&0x80)==0x80) SID_on;
if((dat&0x80)==0x00) SID_off;
SCLK_off;
SCLK_on;
dat<<=1;
for(i=0;i<8;i++)
temp1<<=1;
DATA_IN_lcd;
//Lcd_Data_Ddr|=~RW;
if(LCD_READ_DATA==1)
temp1|=0x01;
temp1&=0xfe;
DATA_OUT_lcd;
SCLK_off;
SCLK_on;
for(i=0;i<8;i++)
temp2<<=1;
DATA_IN_lcd;
//Lcd_Data_Ddr|=~BIT(RW);
temp2|=0x01;
else temp2&=0xfe;
DATA_OUT_lcd;
SCLK_off;
SCLK_on;
//CS_off; SID_on;SCLK_off;
return ((temp1&0xf0)+(temp2>>4));
void BUSY(void)
while((Read_data()&0x80)==0x80);
void Write_com(unsigned char lcd_com) //LCD送命令子函数
BUSY();
CS_off;
SID_off;
CS_on;
dat=0xf8;//写命令
for(i=0;i<8;i++)
SCLK_off;
SCLK_on;
dat<<=1;
dat=(lcd_com&0xf0);
for(i=0;i<8;i++)//写高四位
SCLK_off;
SCLK_on;
dat<<=1;
dat=(lcd_com&0x0f);
dat<<=4;
for(i=0;i<8;i++)//写低四位
SCLK_off;
SCLK_on;
dat<<=1;
void Write_data(unsigned char lcd_com) //LCD送显示数据子函数
BUSY();
CS_off;
SID_off;
CS_on;
dat=0xfa;//写数据
for(i=0;i<8;i++)
SCLK_off;
SCLK_on;
dat<<=1;
dat=(lcd_com&0xf0);
SCLK_off;
SCLK_on;
dat<<=1;
dat=(lcd_com&0x0f);
dat<<=4;
SCLK_off;
SCLK_on;
dat<<=1;
/***********初始化************/
void Lcd_Init(void)
//JTAG_Set(JTAG_SWD_DISABLE);//关闭JTAG和SWD
//RCC->APB2ENR|=1<<2; //使能PORTC时钟
//SetPin(myGPIOA,myPIN1,GPIO_Out_PP|GPIO_50MHZ);
//SetPin(myGPIOA,myPIN2,GPIO_Out_PP|GPIO_50MHZ);
//SetPin(myGPIOA,myPIN3,GPIO_Out_PP|GPIO_50MHZ);
Lcd_Data_Ddr|=RS|RW|E;
SCLK_off;
Write_com(0x30);
delay_lcd_ms(10);
Write_com(0x30);
delay_lcd_ms(15);
Write_com(0x0c);
delay_lcd_ms(15);
Write_com(0x0c); //开显示,不显示光标
delay_lcd_ms(15);
Write_com(0x06); //写一个字符后地址指针自动加1
delay_lcd_ms(15);
Write_com(0x01); //清屏
delay_lcd_ms(20);
/***************清屏命令*********************/
void Lcd_Clear(void)
Write_com(0x01);
delay_lcd_ms(10);
/******************显示图片***************
void Disp_Img(unsigned char *img)
unsigned int j=0;
unsigned char x,y,i;
Write_com(0x34);
for(i=0;i<9;i+=8)
for(y=0;y<32;y++)
for(x=0;x<8;x++)
Write_com(y+0x80); //行地址
Write_com(x+0x80+i); //列地址
Write_data(pgm_read_byte(&img[j++]));
Write_com(0x36); //扩充指令集
Write_com(0x30);
//画点函数
void Lcd_DrawPoint(unsigned char x,unsigned char y,unsigned char sty)
unsigned char i,j;
unsigned char t1,t2;
y=63-y;//从下面向上为0-63
i=x/16;
j=x%16;
if(x/8%2==0){
t1=BUF[16*y+x/8];
t2=BUF[16*y+x/8+1]; }
else{
t1=BUF[16*y+x/8-1];
t2=BUF[16*y+x/8]; }
Write_com(0x34);
Write_com(0x36);
if(y<32)
Write_com(i+0x80); //列地址
Write_com(y-32+0x80); //行地址
Write_com(i+0x88); //列地址
if(j<8)
if(sty==1)
t1|=(0x80>>j);
else if(sty==0) t1&=(~(0x80>>j));
Write_data(t1);
Write_data(t2);
if(sty==1)
t2|=(0x80>>(j-8));
else if(sty==0) t2&=~(0x80>>(j-8));
Write_data(t1);
Write_data(t2);
Write_com(0x30);
if(x/8%2==0)
BUF[16*y+x/8]=t1;
BUF[16*y+x/8+1]=t2; }
BUF[16*y+x/8-1]=t1;
BUF[16*y+x/8]=t2; }
/****************清整个GDRAM空间*****************/
void LCD_ClearGDRAM(void)
unsigned char x,y;
for(y=0;y<64;y++)
for(x=0;x<16;x++)
Write_com(0x34);
Write_com(x+0x80); //列地址
Write_com(0x30);
Write_data(0x00);
Write_data(0x00);
/*********************显示位置*********************/
void Lcd_Loc(unsigned char x,unsigned char y)
switch(x)
case 1:Write_com(0x80+y-1);break;
case 2:Write_com(0x90+y-1);break;
case 3:Write_com(0x88+y-1);break;
case 4:Write_com(0x98+y-1);break;
/*************************显示汉字**********************/
void Lcd_Str(unsigned char x,unsigned char y, unsigned char *str)
unsigned char a=y;
Lcd_Loc(x,y);
while(*str)
Write_data(*str);
a++;
if(a-1==16)
a=1;
Lcd_Loc(++x,1);
str++;
delay_lcd_ms(1);
/******************显示数字(最多五位,除后两位外非零保留)************************/
void Lcd_Num(unsigned char x,unsigned char y,long signed int Data)
unsigned int G,S,B,Q,W; //个、十、百、千、万
Lcd_Loc(x,y);
if(Data<0)
Data=-Data;
Write_data('-');
W=Data/10000;
Q=Data%10000/1000;
B=Data%10000%1000/100;
S=Data%10000%1000%100/10;
G=Data%10000%1000%100%10;
if(W!=0) {
Write_data(N[W]);
Write_data(N[Q]);
Write_data(N[B]);
Write_data(N[S]);
Write_data(N[G]);
if(W==0&&Q!=0)
Write_data(N[Q]);
Write_data(N[B]);
Write_data(N[S]);
Write_data(N[G]);
// Write_data(' ');
if(W==0&&Q==0&&B!=0)
Write_data(N[B]);
Write_data(N[S]);
Write_data(N[G]);
// Write_data(' ');
// Write_data(' ');
if(W==0&&Q==0&&B==0&&S!=0)
Write_data(N[S]);
Write_data(N[G]);
// Write_data(' ');
// Write_data(' ');
// Write_data(' ');
if(W==0&&Q==0&&B==0&&S==0)
Write_data(N[S]);
Write_data(N[G]);
// Write_data(' ');
// Write_data(' ');
// Write_data(' ');
/**************************显示浮点数(浮点数小于1000,保留两位小数)*********************/
//999.99
void Lcd_Float(unsigned char x,unsigned char y,float Data)
long a;
unsigned int B,S,G,SF,BF;//百、十、个、十分、百分位
// unsigned int QF;
Lcd_Loc(x,y);
if(Data<0)
Data=-Data;
Write_data('-');
a=Data*1000;
B=a/100000;
S=a%100000/10000;
G=a%100000%10000/1000;
SF=a%100000%10000%1000/100;
BF=a%100000%10000%1000%100/10;
// QF=a%100000%10000%1000%100%10;
if(B!=0)
Write_data(N[B]);
Write_data(N[S]);
Write_data(N[G]);
Write_data('.');
Write_data(N[SF]);
Write_data(N[BF]);
// Write_data(N[QF]);
if(B==0&&S!=0)
Write_data(N[S]);
Write_data(N[G]);
Write_data('.');
Write_data(N[SF]);
Write_data(N[BF]);
Write_data(' ');
if(B==0&&S==0)
Write_data(N[G]);
Write_data('.');
Write_data(N[SF]);
Write_data(N[BF]);
Write_data(' ');
Write_data(' ');
/*****************自定义一个字符代码********************
****unsigned char x : 显示行坐标
****unsigned char y : 显示列坐标
****unsigned char N : 定义的第N个字符
****unsigned char *zk : 定义的字符点阵数组
void Lcd_Def(unsigned char x,unsigned char y,unsigned char N,unsigned char *zk)
int i;
Write_com(0x30);
switch(N)
case 1:Write_com(0x40);break;//第一个字符的位置为0x40
case 2:Write_com(0x50);break;//第二个字符的位置为0x50
case 3:Write_com(0x60);break;//第三个字符的位置为0x60
case 4:Write_com(0x70);break;//第四个字符的位置为0x70
for(i=0;i<16;i++)
Write_data(zk[i*2]);
Write_data(zk[i*2+1]);
Lcd_Loc(x,y);
Write_data(0x00);
switch(N)
case 1:Write_data(0x00);break; //第一个自定义显示字符编码为:0x00
case 2:Write_data(0x02);break; //第二个自定义显示字符编码为:0x02
case 3:Write_data(0x04);break; //第三个自定义显示字符编码为:0x04
case 4:Write_data(0x06);break; //第四个自定义显示字符编码为:0x06
.h文件
/******12864带中文字库显示器-串行方式********/
#ifndef __LCD12864_H
#define __LCD12864_H
#define RS PAout(1)
#define RW PAout(2)
#define E PAout(3)
#include <iom16v.h>
#include <macros.h>
#define Lcd_Data_Port PORTA
#define Lcd_Data_Pin PINA
#define Lcd_Data_Ddr DDRA
#define RS BIT(1)
#define RW BIT(2)
#define E BIT(3)
#define CS_on {Lcd_Data_Ddr|=RS;Lcd_Data_Port|=RS;}
#define CS_off {Lcd_Data_Ddr|=RS;Lcd_Data_Port|=~RS;}
#define SID_on {Lcd_Data_Ddr|=RW;Lcd_Data_Port|=RW;}
#define SID_off {Lcd_Data_Ddr|=RW;Lcd_Data_Port|=~RW;}
#define SCLK_on {Lcd_Data_Ddr|=E;Lcd_Data_Port|=E;}
#define SCLK_off {Lcd_Data_Ddr|=E;Lcd_Data_Port|=~E;}
#define DATA_IN_lcd SetPin(myGPIOA,myPIN2,GPIO_IPDU);
#define DATA_OUT_lcd {SetPin(myGPIOA,myPIN2,GPIO_Out_PP|GPIO_50MHZ);myGPIO_SetBit(myGPIOA,myPIN2);}
#define LCD_READ_DATA PAin(2)
//8M环境下
#define DATA_IN_lcd Lcd_Data_Ddr|=~RW
#define DATA_OUT_lcd {(Lcd_Data_Ddr|=RW);(Lcd_Data_Port|=RW);}
#define LCD_READ_DATA (Lcd_Data_Pin&RW)
//#define LCD_W 128
//#define LCD_H 64
void delay_lcd_us(unsigned int xus);
void delay_lcd_ms(unsigned int xms);
void BUSY(void);
void Write_com(unsigned char cmdcode);
void Write_data(unsigned char DispData);
unsigned char Read_data(void);
void Lcd_Init(void);
void Lcd_Clear(void);
void LCD_ClearGDRAM(void);
void Lcd_Loc(unsigned char x,unsigned char y);
void Lcd_Str(unsigned char x,unsigned char y,unsigned char *str);
void Lcd_Num(unsigned char x,unsigned char y,long signed int Data);
void Lcd_Float(unsigned char x,unsigned char y,float Data);
void Disp_Img(unsigned char *img);
void Lcd_Def(unsigned char x,unsigned char y,unsigned char N,unsigned char *zk);
void Lcd_DrawPoint(unsigned char x,unsigned char y,unsigned char sty);
