在MSP430 Launchpad(开发板便宜) MSP430G2452上调试 可以使用 可以修改传感器的测量分辨率
- //********************************File Information*******************************
- //** File Name: Sht10.c
- //** Platform: MSP430 LaunchPad MSP430G2452
- //** System Function: Sht10 Sensirion Inc driver code
- //** Created by: ding
- //** Created date: 2014-09-15
- //** Version: Demo V1.0
- //硬件连线-接口定义:
- //SCK: -->P1.5 //定义通讯时钟端口
- //SDA: -->P1.6 //定义通讯数据端口
- #include <msp430g2452.h>//Library
- #include <intrinsics.h> //__no_operation();
- //#include <math.h> //Library
- //#include <stdio.h> //printf();
- //宏定义,延时函数,参数为1时相应延时分别为1us和1ms
- #define CPU_F (double)1000000
- #define delay_us(x) __delay_cycles((long)(CPU_F * (double)x/1000000.0))
- #define delay_ms(x) __delay_cycles((long)(CPU_F * (double)x/1000.0))
- #define uint unsigned int
- #define uchar unsigned char
- #define ulong unsigned long
- //adr command r/w
- #define STATUS_REG_W 0x06 //000 0011 0 //写状态寄存器
- #define STATUS_REG_R 0x07 //000 0011 1 //读状态寄存器
- #define MEASURE_TEMP 0x03 //000 0001 1 //温度测量
- #define MEASURE_HUMI 0x05 //000 0010 1 //湿度测量
- #define RESET 0x1e //000 1111 0 //软复位
- #define bitselect 0x01 //选择温度与湿度的低位读
- #define noACK 0 //没有返回ACK
- #define ACK 1 //返回ACK
- #define HUMIDITY 2
- #define TEMPERATURE 1
- #define SCK BIT5 //P1.5
- #define SDA BIT6 //P1.6
- #define SCK_H P1OUT|=SCK //高
- #define SCK_L P1OUT&=~SCK //低
- #define SDA_H P1OUT|=SDA //高
- #define SDA_L P1OUT&=~SDA //低
- typedef union //定义了两个共用体
- unsigned int i;
- float f;
- }value;
- **Function Name: S_Init
- **Description: 初始化
- **Input Parameters: no
- **Output Parameters: no
- void S_Init()
- P1SEL&=~(SCK+SDA);
- P1DIR|=SCK;
- P1DIR&=~SDA;
- //BCSCTL1=(XT2OFF+RSEL2); //关闭XT2,1MHz DOC
- //DCOCTL=DCO2; //设定DCO频率为1MHz
- **Function Name: S_Transstart
- **Description: start时序
- ** generates a transmission start
- ** _____ ________
- ** DATA: |_______|
- ** ___ ___
- ** SCK : ___| |___| |______
- void S_Transstart()
- P1DIR|=SDA;
- SDA_H;SCK_L;
- __no_operation();
- SCK_H;
- __no_operation();
- SDA_L;
- __no_operation();
- SCK_L;
- __no_operation();
- __no_operation();
- __no_operation();
- SCK_H;
- __no_operation();
- SDA_H;
- __no_operation();
- SCK_L;
- P1DIR&=~SDA;
- **Function Name: S_WriteByte
- **Description: 写函数
- char S_WriteByte(unsigned char value)
- // writes a byte on the Sensibus and checks the acknowledge
- unsigned char i,error=0;
- P1DIR|=SDA;
- for(i=0x80;i>0;i/=2) //shift bit for masking
- if(i&value) SDA_H; //masking value with i , write to SENSI-BUS
- else SDA_L;
- SCK_H; //clk for SENSI-BUS
- __no_operation();__no_operation();__no_operation();//pulswith approx. 5 us
- SCK_L;
- SDA_H; //release DATA-line
- P1DIR&=~SDA; //Change SDA to be input 0:input 1:ouput
- SCK_H; //clk #9 for ack
- error=P1IN; //check ack (DATA will be pulled down by SHT11)
- error&=SDA;
- P1DIR|=SDA; //Change SDA to be output 0:input 1:ouput
- SCK_L;
- if(error)
- return 1; //error=1 in case of no acknowledge
- return 0;
- **Function Name: S_ReadByte
- **Description: 读函数
- **Input Parameters: ack--->reads a byte form the Sensibus and gives an acknowledge in case of "ack=1"
- char S_ReadByte(unsigned char ack)
- // reads a byte form the Sensibus and gives an acknowledge in case of "ack=1"
- unsigned char i,val=0;
- if(P1IN&SDA)
- val=(val|i); //read bit
- SCK_L;
- if(ack) //in case of "ack==1" pull down DATA-Line
- SDA_L;
- else
- SDA_H;
- SCK_L;
- P1DIR&=~SDA; //Change SDA to be output 0:input 1:ouput
- return val;
- **Function Name: S_Connectionreset
- **Description: 连接复位函数
- ** communication reset: DATA-line=1 and at least 9 SCK cycles followed by transstart
- ** _____________________________________________________ ________
- ** _ _ _ _ _ _ _ _ _ ___ ___
- ** SCK : __| |__| |__| |__| |__| |__| |__| |__| |__| |______| |___| |______
- void S_Connectionreset()
- unsigned char ClkCnt;
- P1DIR|=SDA; //Change SDA to be input 0:input 1:ouput
- SDA_H;SCK_L; //Initial state
- for(ClkCnt=0;ClkCnt<9;ClkCnt++) //9 SCK cycles
- SCK_H;
- SCK_L;
- S_Transstart(); //transmission start
- **Function Name: S_Softreset
- **Description: 软件复位函数 resets the sensor by a softreset
- char S_Softreset()
- unsigned char error=0;
- S_Connectionreset(); //reset communication
- error+=S_WriteByte(RESET); //send RESET-command to sensor
- return error; //error=1 in case of no response form the sensor
- **Function Name: S_WriteStatusReg
- **Description: 写状态寄存器
- **Input Parameters: *p_value
- char S_WriteStatusReg(unsigned char *p_value)
- error+=S_WriteByte(STATUS_REG_W); //send command to sensor
- error+=S_WriteByte(*p_value); //send value of status register
- return error; //error>=1 in case of no response form the sensor
- **Function Name: S_Mearsure
- **Description: 读时序 makes a measurement (humidity/temperature) with checksum
- **Input Parameters: *p_value ,*p_checknum ,mode
- unsigned char S_Measure(unsigned char *p_value, unsigned char *p_checksum, unsigned char mode)
- unsigned error=0;
- unsigned int i;
- switch(mode)
- { //send command to sensor
- case TEMPERATURE: error+=S_WriteByte(MEASURE_TEMP); break;
- case HUMIDITY: error+=S_WriteByte(MEASURE_HUMI); break;
- for(i=0;i<65535;i++) if((P1IN&SDA)==0) break; //wait until sensor has finished the measurement
- if(P1IN&SDA) error+=1; //or timeout (~2 sec.) is reached
- *(p_value)=S_ReadByte(ACK); //read the first byte (MSB) 高8位
- *(p_value+1)=S_ReadByte(ACK); //read the second byte (LSB)低8位
- *p_checksum=S_ReadByte(noACK); //read checksum
- return error;
- **Function Name: S_Calculate
- **Description: 计算
- **Input Parameters: humi [Ticks] (12 bit) 默认
- ** temp [Ticks] (14 bit) 默认
- **Output Parameters: humi [%RH]
- ** temp [℃]
- void S_Calculate(unsigned int *p_humidity ,unsigned int *p_temperature)
- //’1’ = 8bit 湿度 / 12bit 温度分辨率 -->可修改分辨率
- //’0’ = 12bit 湿度 / 14bit 温度.分辨率 -->默认选择
- //12bit 湿度 / 14bit 温度.分辨率
- const float C1=-2.0468; // for 12 Bit 湿度转换参数
- const float C2=0.0367; // for 12 Bit 湿度转换参数
- const float C3=-0.0000015955; // for 12 Bit 湿度转换参数
- const float D1=-39.6; // for 14 Bit @ 3V 温度
- const float D2=0.01; // for 14 Bit @ 3V 温度
- const float T1=0.01; // for 12 bit 湿度信号的温度补偿
- const float T2=0.00008; // for 12 bit 湿度信号的温度补偿
- //8bit 湿度 / 12bit 温度分辨率
- const float C1=-2.0468; // for 8 Bit 湿度转换参数
- const float C2=+0.5872; // for 8 Bit 湿度转换参数
- const float C3=-0.00040845; // for 8 Bit 湿度转换参数
- const float D1=-39.6; // for 12 Bit @ 3V 温度
- const float D2=+0.04; // for 12 Bit @ 3V 温度
- const float T1=0.01; // for 8 bit 湿度信号的温度补偿
- const float T2=0.00128; // for 8 bit 湿度信号的温度补偿
- float rh=*p_humidity; // rh: Humidity [Ticks] 12 Bit
- float t=*p_temperature; // t: Temperature [Ticks] 14 Bit
- float rh_lin; // rh_lin: Humidity linear
- float rh_true; // rh_true: Temperature compensated humidity
- float t_C; // t_C : Temperature [℃]
- t_C=t*D2+D1; //calc. temperature from ticks to [℃]
- rh_lin=C3*rh*rh + C2*rh + C1; //calc. humidity from ticks to [%RH]
- rh_true=(t_C-25)*(T1+T2*rh)+rh_lin; //calc. temperature compensated humidity [%RH]
- if(rh_true>100)rh_true=100; //cut if the value is outside of
- if(rh_true<0.1)rh_true=0.1; //the physical possible range
- *p_temperature = (uint)t_C; //return temperature [℃]
- *p_humidity = (uint)rh_true; //return humidity[%RH]
- //**Function Name: calc_dewpoint
- //**Description: 露点
- float Calc_Dewpoint(float h,float t)
- // calculates dew point
- // input: humidity [%RH], temperature [℃]
- // output: dew point [℃]
- { float logEx,dew_point;
- logEx=0.66077+7.5*t/(237.3+t)+(log10(h)-2);
- dew_point = (logEx - 0.66077)*237.3/(0.66077+7.5-logEx);
- return dew_point;
- **Function Name: 主函数
- void main()
- // sample program that shows how to use SHT11 functions
- // 1. connection reset
- // 2. measure humidity [ticks](12 bit) and temperature [ticks](14 bit)
- // 3. calculate humidity [%RH] and temperature [℃]
- // 4. calculate dew point [℃]
- // 5. print temperature, humidity, dew point
- value humi_val,temp_val;
- //float dew_point; //露点
- unsigned char error,checksum;
- //unsigned int temphigh,templow,humilow;
- unsigned int temphigh,templow,humihigh,humilow;
- //unsigned int Reg_Resolution=0x01;
- WDTCTL=WDTPW+WDTHOLD; //Stop watchdog timer
- S_Init(); //初始化
- S_Connectionreset(); //连接复位
- //S_WriteStatusReg((unsigned char *)&Reg_Resolution);//修改测量分辨率:8bit湿度 / 12bit温度
- while(1)
- error=0;
- error+=S_Measure((unsigned char*) &humi_val.i,&checksum,HUMIDITY); //measure humidity
- error+=S_Measure((unsigned char*) &temp_val.i,&checksum,TEMPERATURE); //measure temperature
- if(error!=0)
- S_Connectionreset(); //in case of an error: connection reset
- else
- //Note:修改分辨率需要传感器重新上下电才可生效
- //-------------测量分辨率:8bit湿度 / 12bit温度----------------//
- //8bit humidity MSB=0x0000,00000(invalid) LSB=0xmmmm,mmmm(valid)
- //humilow=(humi_val.i&0xff00);
- //humi_val.i=humilow>>8; //Humidity
- //12bit temperature MSB=0x0000,mmmm( 4bits valid) LSB=0xmmmm,mmmm(valid)
- //temphigh=((temp_val.i&0x0f)<<8);
- //templow=((temp_val.i&0xff00)>>8);
- //temp_val.i=temphigh+templow;//Temperature
- //-------------测量分辨率:12bit湿度 / 14bit温度----------------//
- //12bit humidity MSB=0x0000,mmmm(4bits valid) LSB=0xmmmm,mmmm(valid)
- humihigh=((humi_val.i&0x0f)<<8);
- humilow=((humi_val.i&0xff00)>>8);
- humi_val.i=humihigh+humilow;//Humidity
- //14bit temperature MSB=0x00mm,mmmm( 6bit valid) LSB=0xmmmm,mmmm(valid)
- temphigh=((temp_val.i&0x3f)<<8);
- templow=((temp_val.i&0xff00)>>8);
- temp_val.i=temphigh+templow;//Temperature
- S_Calculate(&humi_val.i,&temp_val.i); //calculate humidity, temperature
- //dew_point=Calc_Dewpoint(humi_val.i,temp_val.i); //calculate dew point
- //printf("temp:%5.1fC humi:%5.1f%% dew point:%5.1fC\n",temp_val.i,humi_val.i,dew_point);
- //----------wait approx. 0.8s to avoid heating up SHTxx------------------------------
- for (uint i=0;i<40000;i++);//(be sure that the compiler doesn't eliminate this line!)
复制代码 |
