#include <iom16v.h>
#define uint unsigned int
#define nop() NOP()
#define xtal 8
#define Set_CS() DDRD |= (1<<4);PORTD |= (1<<4)
#define Set_SID() DDRD |= (1<<5);PORTD |= (1<<5)
#define Set_SCLK() DDRD |= (1<<6);PORTD |= (1<<6)
#define Set_BL() DDRD |= (1<<7);PORTD |= (1<<7)
#define Clr_CS() DDRD |= (1<<4);PORTD &=~(1<<4)
#define Clr_SID() DDRD |= (1<<5);PORTD &=~(1<<5)
#define Clr_SCLK() DDRD |= (1<<6);PORTD &=~(1<<6)
#define Clr_BL() DDRD |= (1<<7);PORTD |= (1<<7)
#define LCDb_FUNCTION 0x38 // 液晶模式为8位,2行,5*8字符
#define LCDb_BASCMD 0x30 // 基本指令集
#define LCDb_CLS 0x01 // 清屏
#define LCDb_HOME 0x02 // 地址返回原点,不改变DDRAM内容
#define LCDb_ENTRY 0x06 // 设定输入模式,光标加,屏幕不移动
#define LCDb_C2L 0x10 // 光标左移
#define LCDb_C2R 0x14 // 光标右移
#define LCDb_D2L 0x18 // 屏幕左移
#define LCDb_D2R 0x1C // 屏幕又移
#define LCDb_ON 0x0C // 打开显示
#define LCDb_OFF 0x08 // 关闭显示
void Delay(uint ms); //延时子程序
void W_1byte(uchar RW, uchar RS, uchar W_data);
void Write_8bits(uint W_bits);
void LCD_Init(void);
void LCD_INT(void);
void LCD_disp (uchar *row_line1, uchar *row_line2,uchar *row_line3,uchar *row_line4);
uchar Dis_1[]={"数控可调直流电源"};
uchar Dis_2[]={"SET:"};
uchar Dis_3[]={"实时电压:"};
uchar Dis_4[]={"实时电流:"};
float SETV = 5.00; //如何把这个数显示到SET后面?
float SETI = 4.00; //如何把这个数显示到SET后面?
float redV,redI; //如何把这个数显示到实时电压和电流后面?
void LCD_INT(void)
Clr_CS();
Clr_SID();
Clr_SCLK();
Clr_BL();
LCD_Init();
uchar i = 0;
W_1byte(0,0,0x80); //显示的地址0x80
for(i=0;row_line1[i]!='\0';i++)
W_1byte(0,1,row_line1[i]);
W_1byte(0,0,0x90); //显示的地址0x90
for(i=0;row_line2[i]!='\0';i++)
W_1byte(0,1,row_line2[i]);
W_1byte(0,0,0x88); //显示的地址0x88
for(i=0;row_line3[i]!='\0';i++)
W_1byte(0,1,row_line3[i]);
W_1byte(0,0,0x98); //显示的地址0x98
for(i=0;row_line4[i]!='\0';i++)
W_1byte(0,1,row_line4[i]);
void LCD_single_disp(uchar single_row, uchar single_line, uchar *single_data)
uchar j,a,i;
switch(single_row)
case 1:
{a=0x80;break;}
case 2:
{a=0x90;break;}
case 3:
{a=0x88;break;}
case 4:
{a=0x98;break;}
for(j=single_line;j>=2;j--)
a++;
W_1byte(0,0,a); //显示的地址0x88
for(i=0; single_data[i]!='\0';i++)
W_1byte(0,1,single_data[i]);
LCD_INT();
LCD_single_disp(1,1,Dis_1);
LCD_single_disp(2,1,Dis_2);
LCD_single_disp(3,1,Dis_3);
LCD_single_disp(4,1,Dis_4);
void LCD_Init(void)
uchar cmd;
cmd=0x30; //功能设置 8 位数据,基本指令
W_1byte(0,0,cmd);
Delay(2);
cmd=0x0C; //显示状态 ON,游标OFF,反白OFF
W_1byte(0,0,cmd); //写指令
Delay(2);
cmd=0x01; //清除显示
Delay(2);
cmd=0x02; //地址归位
Delay(2);
cmd=0x80; //设置DDRAM 地址
Delay(2); //延时
函 数 名:W_1byte
入口参数:RW、RS、W_data
出口参数:无
函数作用:写一个字节的数据到12864 液晶,包括指令和数据
说 明:RW=1,从液晶读数据到MCU;RW=0,写一个数据到液晶;
(一般RW 都设为0,即只向液晶写数据,不读数据)
RS=1,写入的是数据;RS=0,写入的是指令;
一般模式:RW=0,RS=1;写数据
RW=0,RS=0;写指令
uint H_data,L_data,S_ID = 0xf8; //11111RWRS0
if(RW == 0)
S_ID &=~ 0x04;
else //if(RW==1)
S_ID |= 0X04;
if(RS == 0)
S_ID &=~ 0x02;
else //if(RS==1)
S_ID |= 0X02;
H_data = W_data;
H_data &= 0xf0; //屏蔽低4 位的数据
L_data = W_data; //xxxx0000 格式
L_data &= 0x0f; //屏蔽高4 位的数据
L_data <<= 4; //xxxx0000 格式
Set_CS();
Write_8bits(S_ID); //发送S_ID
Write_8bits(H_data); //发送H_data
Write_8bits(L_data); //发送L_data
Clr_CS();
函 数 名:Write_8bits
入口参数:W_bits
函数作用:负责串行输出8 个bit 位
说 明:
uint i,Temp_data;
for(i=0; i<8; i++)
Temp_data = W_bits;
Temp_data <<= i;
if((Temp_data&0x80)==0) //bit7 is zero
Clr_SID();
Set_SCLK();
Clr_SCLK();
Clr_SID();
else //bit7 is one
Set_SID();
Set_SCLK();
Clr_SCLK();
Clr_SID();
函 数 名:Delay
入口参数:ms
出口参数:无
建立日期:2007 年3 月3 日
修改日期:
函数作用:毫秒级的延时程序,当晶振为12Mhz 时,xtal=12;
说 明:
void Delay(uint ms)
uint i;
while(ms--)
for(i=1;i<(uint)(xtal*143-2);i++)
以上是参照别人的代码改的
如何实现显示?
这部分该如何分 ,或者有更好的办法请 大神支招 ,本人小白 做电源电路仿好了 程序卡了
