Kinetis Design Studio v1.1.1 - Now Available大家有试用的吗?在下面讨论吧.
http://www.freescale.com/webapp/ ... _IDE&tid=vanKDS
The Kinetis Design Studio IDE is a complimentary integrated development environment for Kinetis MCUs that enables robust editing, compiling and debugging of your designs. Based on free, open-source software including Eclipse, GNU Compiler Collection (GCC), GNU Debugger (GDB), and others, the Kinetis Design Studio IDE offers designers a simple development tool with no code-size limitations. Furthermore, Processor Expert software enables your design with its knowledge base and helps create powerful applications with a few mouse clicks.
The Kinetis Design Studio is offered for free, and support for it is provided through the Freescale Kinetis Design Studio Community Forum.
Features
Eclipse Kepler 4.3
Host operating systems:
Windows® 7/8 (32 and 64-bit)
Linux® (Ubuntu, Redhat, Centos)
GDB debugger with support for the following debug interface hardware:
SEGGER J-Link (w/SEGGER GDB Server)
P&E Multilink (w/P&E GDB Server)
CMSIS-DAP (w/OpenOCD GDB and OpenSDA embedded circuit)
Command Line (CL) debugging with GDB and OpenOCD TCL
Support for additional downloadable Eclipse plug-ins including RTOS-awareness (including MQX™ and FreeRTOS)
Project wizard to create bare metal, Kinetis SDK and Processor Expert software projects
Processor Expert software with support for Kinetis SDK
Languages supported: Assembly, C and C++ (all with no code size restrictions)
Libraries included: newlib 1.19 and newlib-nano 1.0
Industry standard Eclipse Framework with CDT for C/C++
Kinetis SDK peripheral drivers and CMSIS compliant startup code
GNU ARM® Eclipse plugins for managed make projects
Make file projects
ARM GNU gcc build tools (4.8)
Support for MQX project creation and MQX kernel awareness (available as MQX download)
Open for any Eclipse plugins either from the Eclipse ecosystem or from partners
Freescale Community Support
又出新版本的了. 希望解决以前的不少问题. |
