-- GPIO
* @addtogroup GPIO_Peripheral GPIO
*/ /** GPIO - Peripheral register structure */
typedef struct GPIO_MemMap {
uint32_t PDOR; /**< Port Data Output Register, offset: 0x0 */
uint32_t PSOR; /**< Port Set Output Register, offset: 0x4 */
uint32_t PCOR; /**< Port Clear Output Register, offset: 0x8 */
uint32_t PTOR; /**< Port Toggle Output Register, offset: 0xC */
uint32_t PDIR; /**< Port Data Input Register, offset: 0x10 */
uint32_t PDDR; /**< Port Data Direction Register, offset: 0x14 */
} volatile *GPIO_MemMapPtr;
-- GPIO - Register accessor macros
* @addtogroup GPIO_Register_Accessor_Macros GPIO - Register accessor macros
/* GPIO - Register accessors */
#define GPIO_PDOR_REG(base) ((base)->PDOR)
#define GPIO_PSOR_REG(base) ((base)->PSOR)
#define GPIO_PCOR_REG(base) ((base)->PCOR)
#define GPIO_PTOR_REG(base) ((base)->PTOR)
#define GPIO_PDIR_REG(base) ((base)->PDIR)
#define GPIO_PDDR_REG(base) ((base)->PDDR)
*/ /* end of group GPIO_Register_Accessor_Macros */
-- GPIO Register Masks
* @addtogroup GPIO_Register_Masks GPIO Register Masks
*/ /* PDOR Bit Fields */
#define GPIO_PDOR_PDO_MASK 0xFFFFFFFFu
#define GPIO_PDOR_PDO_SHIFT 0
#define GPIO_PDOR_PDO(x) (((uint32_t)(((uint32_t)(x))<<GPIO_PDOR_PDO_SHIFT))&GPIO_PDOR_PDO_MASK)
/* PSOR Bit Fields */
#define GPIO_PSOR_PTSO_MASK 0xFFFFFFFFu
#define GPIO_PSOR_PTSO_SHIFT 0
#define GPIO_PSOR_PTSO(x) (((uint32_t)(((uint32_t)(x))<<GPIO_PSOR_PTSO_SHIFT))&GPIO_PSOR_PTSO_MASK)
/* PCOR Bit Fields */
#define GPIO_PCOR_PTCO_MASK 0xFFFFFFFFu
#define GPIO_PCOR_PTCO_SHIFT 0
#define GPIO_PCOR_PTCO(x) (((uint32_t)(((uint32_t)(x))<<GPIO_PCOR_PTCO_SHIFT))&GPIO_PCOR_PTCO_MASK)
/* PTOR Bit Fields */
#define GPIO_PTOR_PTTO_MASK 0xFFFFFFFFu
#define GPIO_PTOR_PTTO_SHIFT 0
#define GPIO_PTOR_PTTO(x) (((uint32_t)(((uint32_t)(x))<<GPIO_PTOR_PTTO_SHIFT))&GPIO_PTOR_PTTO_MASK)
/* PDIR Bit Fields */
#define GPIO_PDIR_PDI_MASK 0xFFFFFFFFu
#define GPIO_PDIR_PDI_SHIFT 0
#define GPIO_PDIR_PDI(x) (((uint32_t)(((uint32_t)(x))<<GPIO_PDIR_PDI_SHIFT))&GPIO_PDIR_PDI_MASK)
/* PDDR Bit Fields */
#define GPIO_PDDR_PDD_MASK 0xFFFFFFFFu
#define GPIO_PDDR_PDD_SHIFT 0
#define GPIO_PDDR_PDD(x) (((uint32_t)(((uint32_t)(x))<<GPIO_PDDR_PDD_SHIFT))&GPIO_PDDR_PDD_MASK) /**
*/ /* end of group GPIO_Register_Masks */
/* GPIO - Peripheral instance base addresses */
/** Peripheral PTA base pointer */
#define PTA_BASE_PTR ((GPIO_MemMapPtr)0x400FF000u)
/** Peripheral PTB base pointer */
#define PTB_BASE_PTR ((GPIO_MemMapPtr)0x400FF040u)
/** Peripheral PTC base pointer */
#define PTC_BASE_PTR ((GPIO_MemMapPtr)0x400FF080u)
/** Peripheral PTD base pointer */
#define PTD_BASE_PTR ((GPIO_MemMapPtr)0x400FF0C0u)
/** Peripheral PTE base pointer */
#define PTE_BASE_PTR ((GPIO_MemMapPtr)0x400FF100u)
/* GPIO - Register instance definitions */
/* PTA */
#define GPIOA_PDOR GPIO_PDOR_REG(PTA_BASE_PTR)
#define GPIOA_PSOR GPIO_PSOR_REG(PTA_BASE_PTR)
#define GPIOA_PCOR GPIO_PCOR_REG(PTA_BASE_PTR)
#define GPIOA_PTOR GPIO_PTOR_REG(PTA_BASE_PTR)
#define GPIOA_PDIR GPIO_PDIR_REG(PTA_BASE_PTR)
#define GPIOA_PDDR GPIO_PDDR_REG(PTA_BASE_PTR)
/* PTB */
#define GPIOB_PDOR GPIO_PDOR_REG(PTB_BASE_PTR)
#define GPIOB_PSOR GPIO_PSOR_REG(PTB_BASE_PTR)
#define GPIOB_PCOR GPIO_PCOR_REG(PTB_BASE_PTR)
#define GPIOB_PTOR GPIO_PTOR_REG(PTB_BASE_PTR)
#define GPIOB_PDIR GPIO_PDIR_REG(PTB_BASE_PTR)
#define GPIOB_PDDR GPIO_PDDR_REG(PTB_BASE_PTR)
/* PTC */
#define GPIOC_PDOR GPIO_PDOR_REG(PTC_BASE_PTR)
#define GPIOC_PSOR GPIO_PSOR_REG(PTC_BASE_PTR)
#define GPIOC_PCOR GPIO_PCOR_REG(PTC_BASE_PTR)
#define GPIOC_PTOR GPIO_PTOR_REG(PTC_BASE_PTR)
#define GPIOC_PDIR GPIO_PDIR_REG(PTC_BASE_PTR)
#define GPIOC_PDDR GPIO_PDDR_REG(PTC_BASE_PTR)
/* PTD */
#define GPIOD_PDOR GPIO_PDOR_REG(PTD_BASE_PTR)
#define GPIOD_PSOR GPIO_PSOR_REG(PTD_BASE_PTR)
#define GPIOD_PCOR GPIO_PCOR_REG(PTD_BASE_PTR)
#define GPIOD_PTOR GPIO_PTOR_REG(PTD_BASE_PTR)
#define GPIOD_PDIR GPIO_PDIR_REG(PTD_BASE_PTR)
#define GPIOD_PDDR GPIO_PDDR_REG(PTD_BASE_PTR)
/* PTE */
#define GPIOE_PDOR GPIO_PDOR_REG(PTE_BASE_PTR)
#define GPIOE_PSOR GPIO_PSOR_REG(PTE_BASE_PTR)
#define GPIOE_PCOR GPIO_PCOR_REG(PTE_BASE_PTR)
#define GPIOE_PTOR GPIO_PTOR_REG(PTE_BASE_PTR)
#define GPIOE_PDIR GPIO_PDIR_REG(PTE_BASE_PTR)
#define GPIOE_PDDR GPIO_PDDR_REG(PTE_BASE_PTR)
*/ /* end of group GPIO_Peripheral */
上述代码是K60芯片的GPIO模块相关头文件定义,这里结合硬件手册 K60P100M100SF2RM 对该部分代码进行简要分析。
软件结构分析: 1、“struct GPIO_MemMap { }”:GPIO模块内存映射结构体,该结构体定义了一系列“GPIO端口控制寄存器”的名称,利用结构体本身的“平坦特性”与GPIO模块中实际寄存器的相对地址一一对应,实现结构体内部变量操作对物理地址操作的映射(这里只实现了相对映射,完全映射需要有绝对地址,下面会看到),各寄存器含义可结合注释以及K60P100M100SF2RM 文件54.2 Memory map and register definition章节。 2、“#define GPIO_PDOR_REG(base) ((base)->PDOR)”:GPIO模块内部控制寄存器变量宏定义,该宏定义接收结构体指针,返回寄存器变量 3、“#define GPIO_PDOR_PDO_MASK 0xFFFFFFFFu”:GPIO模块寄存器内部位域屏蔽码,根据硬件操作手册对端口各个寄存器的各个位域进行定义,详见K60P100M100SF2RM 文件54.2.1 Port Data Output Register(GPIOx_PDOR)章节。 4、“#define PTA_BASE_PTR ((GPIO_MemMapPtr)0x400FF000u)”:定义GPIO模块A端口的寄存器组基地址0x400FF000u,该CPU中对各个寄存器的配置本质上是对内存映射地址的配置。上面讲到逻辑操作对物理地址的映射问题时,只能实现相对映射,这里的绝对地址定义就是为实现地址绝对映射。GPIO_MemMapPtrr是GPIO寄存器组的强制类型转换,与结构体“structGPIO_MemMap { }”共同作用,表示基地址和偏移地址,这样就能通过结构体变量来操控该寄存器组中的任意硬件寄存器,对于其他GPIO定义也是类似。 5、“#define GPIOA_PDOR GPIO_PDOR_REG(PTA_BASE_PTR)”:各个GPIO端口的内部寄存器变量定义,便于后期使用,与硬件手册相关。 硬件特性分析: 1、关于各个寄存器的功能,可参见绿色注释和硬件手册。K60的GPIO模块与内核之间通过“零等待状态接口”来发挥引脚的最大性能,可以任意数据大小来操作GPIO寄存器。GPIOx_PDOR寄存器内容与引脚状态直接相关,如果想改变引脚状态可以给该寄存器赋值,但是K60的特殊之处在于并非直接操作该寄存器(它只是一个数据存放的场所而已),而是提供了“设置”、“清除”和“取反”三个寄存器,用来改变GPIOx_PDOR状态,这就是“零等待”的实现关键。通常情况下,设置寄存器位就要用到“位或”指令,清除寄存器位就要用到“位与”指令,该类指令的操作执行就需要消耗cpu时间(取数,位与,赋值),为了最大程度降低“操作延时”,直接通过“入口寄存器”操作数据(赋值),提高性能。 2、GPIO端口的数据操作也是受时钟时序影响的,从微观角度讲,作为输入口时当外部引脚电平变化并不会“瞬间”影响到GPIO输入寄存器的数值,只有当GPIO模块时钟边沿到来时,该状态改变才能体现到寄存器中。虽然这个时间非常短暂,但是并不能忽视它的存在,对于输出口也是如此。 3、关于GPIO操作还有很多选项需要配置,例如“端口上拉”、“滤波使能”、“滤波时钟”、“中断设置”、“端口复用”和“输出强度”等等,就需要设置SIM模块、中断模块、PORT模块等,共同实现GPIO的复杂功能。 4、如果GPIO配置成输入,则必须要打开PORT模块和中断模块中的相关信息;如果不需要输入功能,可以关闭这两个模块中的GPIO相关设置信息,达到节能的目的。如果GPIO配置成输出,则PORT模块和中断模块中的相关信息不需要打开,就可以配置引脚状态。
