发表于 2014-8-18 10:03:22
拿去,不谢:
http://www.i2cdevlib.com/devices/mpu6050#registers
Motion Detection Control (MOT_DETECT_CTRL @ 0x69)
Register Bitfields
[5:4] ACCEL_ON_DELAY
[3:2] FF_COUNT
[1:0] MOT_COUNT
This register is used to add delay to the accelerometer power on time. It is also used to configure the Free Fall and Motion detection decrement rate.
The accelerometer data path provides samples to the sensor registers, Motion detection, Zero Motion detection, and Free Fall detection modules. The signal path contains filters which must be flushed on wake-up with new samples before the detection modules begin operations. The default wake-up delay, of 4ms can be lengthened by up to 3ms. This additional delay is specified in ACCEL_ON_DELAY in units of 1 LSB = 1 ms. The user may select any value above zero unless instructed otherwise by InvenSense. Please refer to Section 8 of the MPU-6000/MPU-6050 Product Specification document for further information regarding the detection modules.
Detection is registered by the Free Fall detection module or the Motion detection module after accelerometer measurements meet their respective threshold conditions over a specified number of samples. When the threshold conditions are met, the corresponding detection counter increments by 1. The user may control the rate at which the detection counter decrements when the threshold condition is not met by configuring FF_COUNT and MOT_COUNT. The decrement rate can be set according to the following table:
FF_COUNT or MOT_COUNT Counter Decrement
0 Reset
1 1
2 2
3 4
When FF_COUNT or MOT_COUNT are configured to 0 (reset), any non-qualifying sample will reset the corresponding counter to 0. For further information on Free Fall detection and Motion detection, please refer to Registers 29 to 32.
Bits 7 and 6 are reserved. |
