发表于 2014-8-26 14:39:07
__ __ _ _
| \/ | __ _ _ ____ _____| | |
| |\/| |/ _` | '__\ \ / / _ \ | |
| | | | (_| | | \ V / __/ | |
|_| |_|\__,_|_| \_/ \___|_|_|
_ _ ____ _
| | | | | __ ) ___ ___ | |_
| | | |___| _ \ / _ \ / _ \| __|
| |_| |___| |_) | (_) | (_) | |_
\___/ |____/ \___/ \___/ \__| ** LOADER **
** MARVELL BOARD: DB-88F6282A-BP LE
U-Boot 1.1.4 (Aug 5 2014 - 15:01:55) Marvell version: 2013_Q1.1
U-Boot code: 00600000 -> 0067FFF0 BSS: -> 006CD340
Soc: 88F6282 A1 CPU running @ 1200Mhz L2 running @ 400Mhz
SysClock = 400Mhz , TClock = 200Mhz
DRAM (DDR3) CAS Latency = 6 tRP = 6 tRAS = 15 tRCD=6
DRAM CS[0] base 0x00000000 size 256MB
DRAM CS[1] base 0x10000000 size 256MB
DRAM Total size 512MB 16bit width
Addresses 8M - 0M are saved for the U-Boot usage.
Mem malloc Initialization (8M - 7M): Done
*** Warning - bad CRC, using default environment
Flash: 0 kB
CPU : Marvell Feroceon (Rev 1)
Streaming disabled
Write allocate disabled
USB 0: host mode
PEX 0: interface detected no Link.
PEX 1: interface detected no Link.
MMC: MRVL_MMC: 0
Net: egiga0 [PRIME]
Hit any key to stop autoboot: 0
Using egiga0 device
TFTP from server 10.4.52.7; our IP address is 10.4.52.165
Filename 'uImage'.
Load address: 0x2000000
Loading: T T T T T T T T T T
Retry count exceeded; starting again
## Booting image at 02000000 ...
Image Name: Linux-2.6.35.14-g5e03802-dirty
Created: 2014-08-18 6:33:29 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3125032 Bytes = 3 MB
Load Address: 00008000
Entry Point: 00008000
Verifying Checksum ... Bad Data CRC
Unknown command '<NULL>' - try 'help'
Marvell>> tftpboot 0x3000000 uImage
Using egiga0 device
Filename 'uImage'.
Load address: 0x3000000
Loading: #################################################################
done
Bytes transferred = 3125096 (2faf68 hex)
Marvell>> bootm 0x3000000
## Booting image at 03000000 ...
Verifying Checksum ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
<5>Linux version 2.6.35.14-g5e03802-dirty (marvell_soc@user1-Tecal-RH2285) (gcc
version 4.4.5 20100614 (prerelease) (FSF GNU GCC branch-4.4.5. Marvell GCC 2010q
4-113) ) #1 Mon Aug 18 14:33:25 CST 2014
CPU: Feroceon 88FR131 [56251311] revision 1 (ARMv5TE), cr=00053977
CPU: VIVT data cache, VIVT instruction cache
Machine: Feroceon-KW
Using UBoot passing parameters structure
Memory policy: ECC disabled, Data cache writeback
<7>On node 0 totalpages: 131072
<7>free_area_init_node: node 0, pgdat c05dd6d4, node_mem_map c0600000
<7> Normal zone: 1024 pages used for memmap
<7> Normal zone: 0 pages reserved
<7> Normal zone: 130048 pages, LIFO batch:31
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
<5>Kernel command line: console=ttyS0,115200 mtdparts=spi_flash:0xc0000@0(uboot)
ro,0xf00000@0x100000(root) root=/dev/nfs rw nfsroot=10.4.52.7:/srv/ubuntu ip=10.
4.52.165:10.4.52.7:::DB88FXX81:eth0:none mv_net_config=(00:11:88:0f:62:81,0:1:2:
3),mtu=1500 mv_phone_config=dev[0]:fxs,dev[1]:fxo video=dovefb:lcd0:640x480-16@6
0 clcd.lcd0_enable=0
<6>PID hash table entries: 2048 (order: 1, 8192 bytes)
<6>Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>Memory: 256MB 256MB = 512MB total
<5>Memory: 513664k/513664k available, 10624k reserved, 0K highmem
<5>Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xe0800000 - 0xe8000000 ( 120 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.init : 0xc0008000 - 0xc002c000 ( 144 kB)
.text : 0xc002c000 - 0xc058e000 (5512 kB)
.data : 0xc05ae000 - 0xc05df6a0 ( 198 kB)
<3>slabp->inuse = 0x00000800, cachep->num = 0x00000028
<2>kernel BUG at mm/slab.c:3063!
<1>Unable to handle kernel NULL pointer dereference at virtual address 00000000
<1>pgd = c0004000
<1>[00000000] *pgd=00000000
<0>Internal error: Oops: 805 [#1]
<0>last sysfs file:
<d>Modules linked in:
CPU: 0 Not tainted (2.6.35.14-g5e03802-dirty #1)
PC is at __bug+0x18/0x24
LR is at __bug+0x14/0x24
pc : [<c0030388>] lr : [<c0030384>] psr: 600000d3
sp : c05aff08 ip : 0000079a fp : 00000001
r10: c0024a38 r9 : c0024a30 r8 : dfc00000
r7 : 00000001 r6 : c0024a28 r5 : c0024ac4 r4 : c05bb080
r3 : 00000000 r2 : c05afefc r1 : c050f4c8 r0 : 00000024
Flags: nZCv IRQs off FIQs off Mode SVC_32 ISA ARM Segment kernel
Control: 0005397f Table: 00004000 DAC: 00000017
<0>Process swapper (pid: 0, stack limit = 0xc05ae270)
<0>Stack: (0xc05aff08 to 0xc05b0000)
<0>ff00: c05bb080 c00d27a0 00000000 00000000 00008000 00000020
<0>ff20: 00000200 c05ae000 800000d3 c05bb080 00008000 00000020 00000000 c0521745
<0>ff40: 00000000 c00d261c c05ae000 00042000 00000020 c05bb070 00000020 c00d3308
<0>ff60: ffe00000 00000002 e0800000 00000000 00000078 c0000000 e0000000 0000026b
<0>ff80: bf000000 c05bb070 c0024a28 00000000 c05affb4 c05bb09c 56251311 00000028
<0>ffa0: 00000000 c0010b7c 00000000 c05bb09c c05b1c40 00000040 c00244dc c05df800
<0>ffc0: c00244dc c00244d8 c05b1c40 00021b48 00021b14 c000898c c000862c 00000000
<0>ffe0: 00000000 c00244dc 00000000 00053975 c05dfb14 00008034 00000000 00000000
[<c0030388>] (__bug+0x18/0x24) from [<c00d27a0>] (cache_alloc_refill+0x140/0x52c
[<c00d27a0>] (cache_alloc_refill+0x140/0x52c) from [<c00d261c>] (kmem_cache_allo
c+0x54/0x98)
[<c00d261c>] (kmem_cache_alloc+0x54/0x98) from [<c00d3308>] (kmem_cache_create+0
x210/0x490)
[<c00d3308>] (kmem_cache_create+0x210/0x490) from [<c0010b7c>] (kmem_cache_init+
0x164/0x2ec)
[<c0010b7c>] (kmem_cache_init+0x164/0x2ec) from [<c000898c>] (start_kernel+0x11c
/0x268)
[<c000898c>] (start_kernel+0x11c/0x268) from [<00008034>] (0x8034)
<0>Code: e1a01000 e59f000c eb106fd7 e3a03000 (e5833000)
<4>---[ end trace 1b75b31a2719ed1c ]---
<0>Kernel panic - not syncing: Attempted to kill the idle task!
[<c0032a60>] (unwind_backtrace+0x0/0xf0) from [<c044c260>] (panic+0x54/0xd8)
[<c044c260>] (panic+0x54/0xd8) from [<c0080d74>] (do_exit+0x70/0x5e8)
[<c0080d74>] (do_exit+0x70/0x5e8) from [<c0030884>] (die+0x19c/0x1c8)
[<c0030884>] (die+0x19c/0x1c8) from [<c0033848>] (__do_kernel_fault+0x64/0x84)
[<c0033848>] (__do_kernel_fault+0x64/0x84) from [<c0033ae8>] (do_page_fault+0x28
0/0x2a0)
[<c0033ae8>] (do_page_fault+0x280/0x2a0) from [<c002c2c8>] (do_DataAbort+0x34/0x
94)
[<c002c2c8>] (do_DataAbort+0x34/0x94) from [<c002ca2c>] (__dabt_svc+0x4c/0x60)
Exception stack(0xc05afec0 to 0xc05aff08)
fec0: 00000024 c050f4c8 c05afefc 00000000 c05bb080 c0024ac4 c0024a28 00000001
fee0: dfc00000 c0024a30 c0024a38 00000001 0000079a c05aff08 c0030384 c0030388
ff00: 600000d3 ffffffff
[<c002ca2c>] (__dabt_svc+0x4c/0x60) from [<c0030388>] (__bug+0x18/0x24)
c+0x54/0x98)
x210/0x490)
0x164/0x2ec)
/0x268)
