/* basic driver for ad7798 and ad7799, not all functions supported
assumes a spi driver exists, and "spi_transfer" takes
and returns a byte. */
#define AD7799_STATUS_RDY 0x80
#define AD7799_STATUS_ERROR 0x40
#define AD7799_STATUS_NOREF 0x20
#define AD7799_STATUS_IS_AD7799 0x08
#define AD7799_STATUS_CHAN_MASK 0x07
static uint8_t ad7799_init_status;
#define AD7799_STATUS_REG 0x0
#define AD7799_MODE_REG 0x1
#define AD7799_CONFIG_REG 0x2
#define AD7799_DATA_REG 0x3
#define AD7799_ID_REG 0x4
#define AD7799_IO_REG 0x5
#define AD7799_OFFSET_REG 0x6
#define AD7799_SCALE_REG 0x7
static void ad7799_reset(void)
int i;
for(i = 0; i<4; i++)
spi_transfer(0xff);
/* helper request function */
static inline void ad7799_comm(uint8_t reg, uint8_t read, uint8_t cont)
spi_transfer((read ? 0x40 : 0x00) | (reg << 3) | (cont ? 0x04 : 0x00));
/* return the contents of the OFFSET register */
int32_t ad7799_read_offset(void)
ad7799_comm(AD7799_OFFSET_REG, 1, 0);
int32_t val = 0;
if(ad7799_init_status & AD7799_STATUS_IS_AD7799)
val |= (int32_t)spi_transfer(0) << 16;
val |= (int32_t)spi_transfer(0) << 8;
val |= (int32_t)spi_transfer(0);
return val;
/* return the contents of the FULL-SCALE register */
int32_t ad7799_read_scale(void)
ad7799_comm(AD7799_SCALE_REG, 1, 0);
int32_t val = 0;
return val;
uint8_t ad7799_status(void)
ad7799_comm(AD7799_STATUS_REG, 1, 0);
return spi_transfer(0);
/* Setting the mode, pick one for mode and rate,
psw is either zero or non-zero */
enum { AD7799_CONTINUOUS_CONVERSION_MODE = 0, AD7799_SINGLE_CONVERSION_MODE,
AD7799_IDLE_MODE, AD7799_POWERDOWN_MODE, AD7799_INTERNAL_OFFSET_CAL_MODE,
AD7799_INTERNAL_SCALE_CAL_MODE, AD7799_SYSTEM_OFFSET_CAL_MODE,
AD7799_SYSTEM_SCALE_CAL_MODE};
enum { AD7799_470_HZ = 1, AD7799_242_HZ, AD7799_123_HZ, AD7799_62_HZ,
AD7799_50_HZ, AD7799_39_HZ, AD7799_33_2_HZ, AD7799_19_6_HZ,
AD7799_16_7_1_HZ, AD7799_16_7_2_HZ, AD7799_12_5_HZ, AD7799_10_HZ,
AD7799_8_33_HZ, AD7799_6_25_HZ, AD7799_4_17_HZ };
void ad7799_set_mode(uint8_t mode, uint8_t psw, uint8_t rate)
ad7799_comm(AD7799_MODE_REG, 0, 0);
spi_transfer(mode << 5 | (psw ? 0x10 : 0x00));
spi_transfer(rate);
/* setting config, pick gain and chan from below,
the rest are either zero or non-zero */
enum { AD7799_1_GAIN, AD7799_2_GAIN, AD7799_4_GAIN, AD7799_8_GAIN,
AD7799_16_GAIN, AD7799_32_GAIN, AD7799_64_GAIN, AD7799_128_GAIN };
enum { AD7799_AIN1_CHAN, AD7799_AIN2_CHAN, AD7799_AIN3_CHAN,
AD7799_AIN11_CHAN, AD7799_AVDD_CHAN };
void ad7799_write_config(uint8_t burnout, uint8_t unipolar, uint8_t gain,
uint8_t ref_det, uint8_t buf, uint8_t chan)
ad7799_comm(AD7799_CONFIG_REG, 0, 1);
spi_transfer((burnout ? 0x40 : 0x00) | (unipolar ? 0x20 : 0x00) | gain);
spi_transfer((ref_det ? 0x20 : 0x00) | (buf ? 0x10 : 0x00) | chan);
/* determine if data is ready to be read, could also be
implemented by reading the status register */
int8_t ad7799_data_ready(void)
return !(PINB & _BV(DD_MISO));
/* request a read from the data register */
void ad7799_request_data(uint8_t continuous)
ad7799_comm(AD7799_DATA_REG, 1, continuous);
/* read from data register, it should be previously requested
from ad7799_request_data, the value is signed */
int32_t ad7799_read_data(void)
uint32_t val = 0;
if(ad7799_init_status & AD7799_STATUS_IS_AD7799) {
val = spi_transfer(0);
val <<= 8;
val |= spi_transfer(0);
val <<= 8;
return val - 0x800000;
return val - 0x8000;
void ad7799_calibrate()
int32_t off = ad7799_read_offset();
printf("offset: 0x%lx\n", off);
/* cal */
ad7799_set_mode(AD7799_INTERNAL_OFFSET_CAL_MODE, 0, AD7799_16_7_1_HZ);
while(!ad7799_data_ready());
void ad7799_init()
ad7799_reset();
ad7799_init_status = ad7799_status();
