发表于 2014-8-14 01:10:12
我觉得卡尔曼滤波器就三个部分,
一是利用系统模型估计下一时刻的系统状态,
二是利用下一时刻的系统输出来估计下一时刻的系统状态,
三是给予这两个估计值一定的权重然后平均得出系统状态的最优值。
没看过卡尔曼滤波器的具体推导,所以我也不知道为什么这么做有用,但是的确有用。
关于QR值的说法,我的观点和LZ是一样的。
卡尔曼滤波器还有其他变种,比如扩展卡尔曼滤波器。传统卡尔曼滤波器要求系统是线性系统,扩展卡尔曼滤波器就没这个要求了。
还有其他几种不记得了,最近在研究状态机,没时间看这些。
附带一个用来计算姿态角的卡尔曼滤波器,多维的。
- %kalman 2014@L.
- clear;
- %define var
- ACC_LSB = 16384/9.8;
- GYR_LSB = 65.5/57.3;
- len = 1000;
- len2 = 300;
- ERROR = 1:len2;
- X_ACC = 1:len;
- Y_ACC = 1:len;
- Z_ACC = 1:len;
- X_GYRO = 1:len;
- Y_GYRO = 1:len;
- Z_GYRO = 1:len;
- theta_ANGLE = 1:len2;
- fal_ANGLE = 1:len2;
- pu_ANGLE = 1:len2;
- A = ones(4);
- X = [1, 0, 0, 0]';
- P = [1 1 1 1];
- P = diag(P);
- Q = [2e-5, 2e-5, 2e-5, 2e-5];
- Q = diag(Q);
- R = [5e-1,5e-1,5e-1];
- R = diag(R);
- I = [1 1 1 1];
- I = diag(I);
- H = ones(3, 4);
- h = ones(3, 3);
- t = 0.001;
- S = ones(3,1);
- T1 = ones(3,1);
- T2 = ones(3,1);
- T3 = ones(3,1);
- %read data file
- textData = importdata('/home/life/Code/ARM/STM32/F103/MPU6050/test.dat');
- %X_ACC
- for i = 1:len
- X_ACC(i) = textData(i,2)/ACC_LSB;
- end
- %Y_ACC
- for i = 1:len
- Y_ACC(i) = textData(i,3)/ACC_LSB;
- end
- %Z_ACC
- for i = 1:len
- Z_ACC(i) = textData(i,4)/ACC_LSB;
- end
- %X_GYRO
- for i = 1:len
- X_GYRO(i) = textData(i,5)/GYR_LSB;
- end
- %X_GYRO
- for i = 1:len
- Y_GYRO(i) = textData(i,6)/GYR_LSB;
- end
- %X_GYRO
- for i = 1:len
- Z_GYRO(i) = textData(i,7)/GYR_LSB;
- end
- %main loop
- for i = 1:len2
- %calculate A
- % A(1,1) = 1;
- % A(1,2) = exp(-t*X_GYRO(i));
- % A(1,3) = exp(-t*Y_GYRO(i));
- % A(1,4) = exp(-t*Z_GYRO(i));
- % A(2,1) = exp(t*X_GYRO(i));
- % A(2,2) = 1;
- % A(2,3) = exp(t*Z_GYRO(i));
- % A(2,4) = exp(t*Y_GYRO(i));
- % A(3,1) = exp(t*Y_GYRO(i));
- % A(3,2) = exp(-t*Z_GYRO(i));
- % A(3,3) = 1;
- % A(3,4) = exp(t*X_GYRO(i));
- % A(4,1) = exp(t*Z_GYRO(i));
- % A(4,4) = 1;
- % A(4,2) = exp(t*Y_GYRO(i));
- % A(4,3) = exp(-t*X_GYRO(i));
- %calculate s
- T1(1) = 0.5*(X_GYRO(3*i)+X_GYRO(3*i+1))*t;
- T1(2) = 0.5*(Y_GYRO(3*i)+Y_GYRO(3*i+1))*t;
- T1(3) = 0.5*(Y_GYRO(3*i)+Y_GYRO(3*i+1))*t;
- T2(1) = 0.5*(X_GYRO(3*i+1)+X_GYRO(3*i+2))*t;
- T2(2) = 0.5*(Y_GYRO(3*i+1)+Y_GYRO(3*i+2))*t;
- T2(3) = 0.5*(Z_GYRO(3*i+1)+Z_GYRO(3*i+2))*t;
- T3(1) = 0.5*(X_GYRO(3*i+2)+X_GYRO(3*i+3))*t;
- T3(2) = 0.5*(Y_GYRO(3*i+2)+Y_GYRO(3*i+3))*t;
- T3(3) = 0.5*(Z_GYRO(3*i+2)+Z_GYRO(3*i+3))*t;
- S = T1+T2+T3+(33/80)*cross(T1, T2)+(57/80)*cross(T2, (T3-T1));
- % q0 = cos(sqrt(S(1)^2 + S(2)^2 + S(3)^2));
- % q1 = (S(1)/sqrt(S(1)^2 + S(2)^2 + S(3)^2))*sin(S(1)/sqrt(S(1)^2 + S(2)^2 + S(3)^2));
- % q2 = (S(2)/sqrt(S(1)^2 + S(2)^2 + S(3)^2))*sin(S(2)/sqrt(S(1)^2 + S(2)^2 + S(3)^2));
- % q3 = (S(3)/sqrt(S(1)^2 + S(2)^2 + S(3)^2))*sin(S(3)/sqrt(S(1)^2 + S(2)^2 + S(3)^2));
- sx = S(1);
- sy = S(2);
- sz = S(3);
- % sx = X_GYRO(i)*t;
- % sy = Y_GYRO(i)*t;
- % sz = Z_GYRO(i)*t;
- s = 0.25*(sx^2+sy^2+sz^2);
- ac = 1-0.5*s+s^2/24;
- as = 0.5*(1 - s/6 + s^2/120);
- % A(1,1) = q0;
- % A(1,2) = -q1;
- % A(1,3) = -q2;
- % A(1,4) = -q3;
- % A(2,1) = q1;
- % A(2,2) = q0;
- % A(2,3) = -q3;
- % A(2,4) = q2;
- % A(3,1) = q2;
- % A(3,2) = q3;
- % A(3,3) = q0;
- % A(3,4) = -q1;
- % A(4,1) = q3;
- % A(4,2) = -q2;
- % A(4,3) = q1;
- % A(4,4) = q0;
- A(1,1) = ac;
- A(1,2) = -as*sx;
- A(1,3) = -as*sy;
- A(1,4) = -as*sz;
- A(2,1) = as*sx;
- A(2,2) = ac;
- A(2,3) = -as*sz;
- A(2,4) = as*sy;
- A(3,1) = as*sy;
- A(3,2) = as*sz;
- A(3,3) = ac;
- A(3,4) = -as*sx;
- A(4,1) = as*sz;
- A(4,2) = as*sy;
- A(4,3) = -as*sx;
- A(4,4) = ac;
- %q = sqrt(t*X_GYRO(i)^2+t*Y_GYRO(i)^2+t*Z_GYRO(i)^2);
- %R = [(1 - ((0.5*q)^2)/2), 0.5*X_GYRO(i), 0.5*Y_GYRO(i), 0.5*Z_GYRO(i)]';
- %A = A*R;
- %time updata
- X = A*X;
- P = A*P*A' + Q;
- %measure updata
- %[ ax*q0 + ay*q3 - az*q2, ax*q1 + ay*q2 + az*q3, ay*q1 - ax*q2 - az*q0, ay*q0 - ax*q3 + az*q1]
- %[ ay*q0 - ax*q3 + az*q1, ax*q2 - ay*q1 + az*q0, ax*q1 + ay*q2 + az*q3, az*q2 - ay*q3 - ax*q0]
- %[ ax*q2 - ay*q1 + az*q0, ax*q3 - ay*q0 - az*q1, ax*q0 + ay*q3 - az*q2, ax*q1 + ay*q2 + az*q3]
- %[ 2*q3*vz - 2*q4*vy, 2*q3*vy + 2*q4*vz, 2*q2*vy - 4*q3*vx + 2*q1*vz, 2*q2*vy - 4*q3*vx + 2*q1*vz]
- %[ 2*q4*vx - 2*q2*vz, 2*q3*vx - 4*q2*vy - 2*q1*vz, 2*q2*vx + 2*q4*vz, 2*q1*vx - 4*q4*vy + 2*q3*vz]
- %[ 2*q2*vy - 2*q3*vx, 2*q4*vx + 2*q1*vy - 4*q2*vz, 2*q4*vy - 2*q1*vx - 4*q3*vz, 2*q2*vx + 2*q3*vy]
- j = i;
- %calculate H
- H(1,1) = 2*X(3)*Z_ACC(j)-2*X(4)*Y_ACC(j);
- H(1,2) = 2*X(3)*Y_ACC(j)+2*X(4)*Z_ACC(j);
- H(1,3) = 2*X(2)*Y_ACC(j)-4*X(3)*X_ACC(j)+2*X(1)*Z_ACC(j);
- H(1,4) = 2*X(2)*Y_ACC(j)-4*X(3)*X_ACC(j)+2*X(1)*Z_ACC(j);
- H(2,1) = 2*X(4)*X_ACC(j)-2*X(2)*Z_ACC(j);
- H(2,2) = 2*X(3)*X_ACC(j)-4*X(2)*Y_ACC(j)-2*X(1)*Z_ACC(j);
- H(2,3) = 2*X(2)*X_ACC(j)+2*X(4)*Z_ACC(j);
- H(2,4) = 2*X(1)*X_ACC(j)-4*X(4)*Y_ACC(j)+2*X(3)*Z_ACC(j);
- H(3,1) = 2*X(2)*Y_ACC(j)-2*X(3)*X_ACC(j);
- H(3,2) = 2*X(4)*X_ACC(j)+2*X(1)*Y_ACC(j)-4*X(2)*Z_ACC(j);
- H(3,3) = 2*X(4)*Y_ACC(j)-2*X(1)*X_ACC(j)-4*X(3)*Z_ACC(j);
- H(3,4) = 2*X(2)*X_ACC(j)+2*X(3)*Y_ACC(j);
- % H(1,1) = 2*X(3)*Z_ACC(i)-2*X(4)*Y_ACC(i);
- % H(1,2) = 2*X(3)*Y_ACC(i)+2*X(4)*Z_ACC(i);
- % H(1,3) = 2*X(2)*Y_ACC(i)-4*X(3)*X_ACC(i)+2*X(1)*Z_ACC(i);
- % H(1,4) = 2*X(2)*Y_ACC(i)-4*X(3)*X_ACC(i)+2*X(1)*Z_ACC(i);
- % H(2,1) = 2*X(4)*X_ACC(i)-2*X(2)*Z_ACC(i);
- % H(2,2) = 2*X(3)*X_ACC(i)-4*X(2)*Y_ACC(i)-2*X(1)*Z_ACC(i);
- % H(2,3) = 2*X(2)*X_ACC(i)+2*X(4)*Z_ACC(i);
- % H(2,4) = 2*X(1)*X_ACC(i)-4*X(4)*Y_ACC(i)+2*X(3)*Z_ACC(i);
- % H(3,1) = 2*X(2)*Y_ACC(i)-2*X(3)*X_ACC(i);
- % H(3,2) = 2*X(4)*X_ACC(i)+2*X(1)*Y_ACC(i)-4*X(2)*Z_ACC(i);
- % H(3,3) = 2*X(4)*Y_ACC(i)-2*X(1)*X_ACC(i)-4*X(3)*Z_ACC(i);
- % H(3,4) = 2*X(2)*X_ACC(i)+2*X(3)*Y_ACC(i);
- % H(1,1) = X(1)*X_ACC(i)+X(4)*Y_ACC(i)-X(3)*Z_ACC(i);
- % H(1,2) = X(2)*X_ACC(i)+X(3)*Y_ACC(i)+X(4)*Z_ACC(i);
- % H(1,3) = X(2)*X_ACC(i)-X(3)*Y_ACC(i)-X(1)*Z_ACC(i);
- % H(1,4) = X(1)*X_ACC(i)-X(4)*Y_ACC(i)+X(2)*Z_ACC(i);
- % H(2,1) = X(1)*X_ACC(i)-X(4)*Y_ACC(i)+X(2)*Z_ACC(i);
- % H(2,2) = X(3)*X_ACC(i)-X(2)*Y_ACC(i)+X(1)*Z_ACC(i);
- % H(2,3) = X(2)*X_ACC(i)+X(3)*Y_ACC(i)+X(4)*Z_ACC(i);
- % H(2,4) = X(3)*X_ACC(i)-X(4)*Y_ACC(i)-X(1)*Z_ACC(i);
- % H(3,1) = X(3)*X_ACC(i)-X(2)*Y_ACC(i)+X(1)*Z_ACC(i);
- % H(3,2) = X(4)*X_ACC(i)-X(1)*Y_ACC(i)-X(2)*Z_ACC(i);
- % H(3,3) = X(1)*X_ACC(i)+X(4)*Y_ACC(i)-X(3)*Z_ACC(i);
- % H(3,4) = X(2)*X_ACC(i)+X(3)*Y_ACC(i)+X(4)*Z_ACC(i);
- %calculate h
- %[ q0^2 + q1^2 - q2^2 - q3^2, 2*q0*q3 + 2*q1*q2, 2*q1*q3 - 2*q0*q2]
- %[ 2*q1*q2 + 2*q0*q3, q0^2 - q1^2 + q2^2 - q3^2, 2*q0*q1 - 2*q2*q3]
- %[ 2*q0*q2 - 2*q1*q3, 2*q2*q3 + 2*q0*q1, q0^2 - q1^2 - q2^2 + q3^2]
- h(1,1) = X(1)^2 + X(2)^2 - X(3)^2 - X(4)^2;
- h(1,2) = 2*(X(1)*X(4) + X(2)*X(3));
- h(1,3) = 2*(X(2)*X(4) + X(1)*X(3));
- h(2,1) = 2*(X(2)*X(3) - X(1)*X(4));
- h(2,2) = X(1)^2 - X(2)^2 + X(3)^2 - X(4)^2;
- h(2,3) = 2*(X(1)*X(2) + X(3)*X(4));
- h(3,1) = 2*(X(1)*X(3) + X(2)*X(4));
- h(3,2) = 2*(X(3)*X(4) - X(1)*X(2));
- h(3,3) = X(1)^2 - X(2)^2 - X(3)^2 + X(4)^2;
- %H = 2*H;
- %calculate Kg
- Kg = P*H'/(H*P*H' + R);
- %calculate new X and P
- Z = [X_ACC(i), Y_ACC(i), Z_ACC(i)];
- Z = Z';
- X = X + Kg*(Z - H*X);
- P = (I - Kg*H)*P;
- ERROR(i) = 1- sqrt(X(1)^2+X(2)^2+X(3)^2+X(4)^2);
- X(1) = X(1)/sqrt(X(1)^2+X(2)^2+X(3)^2+X(4)^2);
- X(2) = X(2)/sqrt(X(1)^2+X(2)^2+X(3)^2+X(4)^2);
- X(3) = X(3)/sqrt(X(1)^2+X(2)^2+X(3)^2+X(4)^2);
- X(4) = X(4)/sqrt(X(1)^2+X(2)^2+X(3)^2+X(4)^2);
- theta_ANGLE(i) = asin(2*(X(2)*X(4)-X(1)*X(3)))*57.3;
- fal_ANGLE(i) = atan2(2*X(1)*X(2)+2*X(3)*X(4), X(1)^2-X(2)^2-X(3)^2+X(4)^2)*57.3;
- pu_ANGLE(i) = atan2(2*X(1)*X(4) +2*X(2)*X(3),X(1)^2+X(2)^2-X(3)^2-X(4)^2)*57.3;
- end
复制代码 |
