发表于 2015-7-7 10:44:15
Hi, 您好!
TCP cubic registered
NET: Registered protocol family 17
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
ieee80211: 802.11 data/management/control stack, git-1.1.13
ieee80211: Copyright (C) 2004-2005 Intel Corporation <jketreno@linux.intel.com>
registered taskstats version 1
musb_hdrc: version 6.0, musb-dma, host, debug=-1
musb_hdrc: setup fifo_mode 0
musb_hdrc: USB Host mode controller at c2820000 using PIO, IRQ 9
musb_hdrc musb_hdrc: MUSB HDRC host driver
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 2.6.28.3 musb-hcd
usb usb1: SerialNumber: musb_hdrc
asm9260_rtc asm9260_rtc: setting system clock to 1970-01-01 00:00:00 UTC (0)
VFS: Mounted root (cramfs filesystem) readonly.
Freeing init memory: 124K
usb 1-1: new high speed USB device using musb_hdrc and address 2
usb 1-1: configuration #1 chosen from 1 choice
usb 1-1: new config #1 exceeds power limit by 12mA
usb 1-1: New USB device found, idVendor=0bda, idProduct=8176
usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1: Product: 802.11n WLAN Adapter
usb 1-1: Manufacturer: Realtek
usb 1-1: SerialNumber: 00e04c000001
usb 1-1: 500mA is over 488mA budget for port 1!
hub 1-0:1.0: 12mA over power budget!
mount yaffs2 on /mnt/yaffs2
yaffs: dev is 32505859 name is "mtdblock3" rw
yaffs: passed flags ""
Processing /etc/profile...
Set search library path in /etc/profile
Set user path in /etc/profile
Done
从上面的打印信息可以看出,在上电的时候,板子需要识别 Realtek的信息, 如果没有识别,需要检查硬件, 及 rawImage内核的编译选项 是否支持相关设备。
如果以上正常,
则需检查rtl8188的驱动编译是否正常。 |
