发表于 2014-7-3 12:24:13
PIC18F95J94
nanoWatt XLP technology
Deep sleep current is 60 nA typical
WDT : 650 nA @ 2V typical
RTCC: 650 nA @ 32 Khz, 2V typical
Vbat allows lowest power consumption on back up battery
Multiple, Switchable Clock Modes for Optimum Performance and Power Management
USB 2.0 full speed compliant with on chip transceiver
480 segments of LCD display.
60 X 8 commons
Drives LCD panel in Sleep mode
Internal charge pump for LCD
64Mhz and upto 16 MIPS performance
Four 16 bit timers/counters
Seven Capture/Compare/PWM (CCP)
Three Enhanced Capture/Compare/PWM (ECCP)
Two Master Synchronous Serial Port (MSSP) feature SPI and I2C
Four UART with IrDA
10/12 bit ADC with 24 channel resolution
Three Rail-to-Rail Enhanced Analog Comparators
Charge Time Measurement Unit (CTMU) for touch and measurements
Operating voltage 2.0V – 3.6V |
