发表于 2014-6-30 14:01:46
* @brief Get one packet from the FIFO.
* If @e sensors does not contain a particular sensor, disregard the data
* returned to that pointer.
* \n @e sensors can contain a combination of the following flags:
* \n INV_X_GYRO, INV_Y_GYRO, INV_Z_GYRO
* \n INV_XYZ_GYRO
* \n INV_XYZ_ACCEL
* \n INV_WXYZ_QUAT
* \n If the FIFO has no new data, @e sensors will be zero.
* \n If the FIFO is disabled, @e sensors will be zero and this function will
* return a non-zero error code.
* @param[out] gyro Gyro data in hardware units.
* @param[out] accel Accel data in hardware units.
* @param[out] quat 3-axis quaternion data in hardware units.
* @param[out] timestamp Timestamp in milliseconds.
* @param[out] sensors Mask of sensors read from FIFO.
* @param[out] more Number of remaining packets.
* @return 0 if successful.
int dmp_read_fifo(short *gyro, short *accel, long *quat,
unsigned long *timestamp, short *sensors, unsigned char *more) |
