- from PyQt4 import QtGui
- from PyQt4 import QtCore
- from PyQt4.QtCore import pyqtSlot
- from PyQt4.QtCore import QThread
- from PyQt4.QtGui import QMainWindow
- from Ui_SerialCom import Ui_MainWindow
- class SerialComThread(QThread):
- def __init__(self, parent=None):
- super(SerialComThread, self).__init__(parent)
- self.setTerminationEnabled(True)
- self.rxDataSignal = QtCore.pyqtSignal()
- def run(self):
- while True:
- self.rxDataSignal.emit()
- self.msleep(500)
- class SerialCom(QMainWindow, Ui_MainWindow):
- Constructor
- @param parent reference to the parent widget (QWidget)
- super().__init__(parent)
- self.comThread = SerialComThread()
- self.comThread.rxDataSignal.connect(self.on_comThread_rxDataSignal)
- self.comThread.start()
- @pyqtSlot()
- def on_comThread_rxDataSignal(self):
- pass
最近刚学PYTHON,想写个串口结果遇到上面的问题,一直无法解决,各位PYTHON高手帮忙看看!
具体的代码如上所示,并产生如上图所示的错误,但如果把self.rxDataSignal = QtCore.pyqtSignal()改成
类的静态属性则不会报错,比如这样写:
- rxDataSignal = QtCore.pyqtSignal()
- def run(self):
- while True:
- self.msleep(500)
