发表于 2014-6-4 17:47:20
* adc.c
* Created: 2011-8-18 13:09:27
* Author: Administrator
#include <avr/io.h>
#include <avr/interrupt.h>
#include "config.h"
#include "adc.h"
// global variables
//! Software flag used to indicate when
/// the a2d conversion is complete.
//volatile unsigned char a2dCompleteFlag;
// functions
// initialize a2d converter因所用程序需快速采样所以预先设置好通道
void a2dInit(void)
sbi(ADCSRA, ADEN); // enable ADC (turn on ADC power)
cbi(ADCSRA, ADIF); // default to single sample convert mode
sbi(SFIOR,ADTS1),sbi(SFIOR,ADTS0);//定时器/ 计数器0 比较匹配
a2dSetPrescaler(ADC_PRESCALE); // 设置分频
a2dSetReference(ADC_REFERENCE); // 设置参考电压
a2dSetChannel(ADC_CH_ADC0); //预先设置通道0
sbi(ADMUX, ADLAR); // set to left-adjusted result 左对齐,只要8位精度仅需读ADCH
sbi(ADCSRA, ADIE); // enable ADC interrupts
sbi(ADCSRA,ADATE); //自动触发使能
//a2dCompleteFlag = FALSE; // clear conversion complete flag
sei(); // turn on interrupts (if not already on)
// turn off a2d converter
void a2dOff(void)
cbi(ADCSRA, ADIE); // disable ADC interrupts
cbi(ADCSRA, ADEN); // disable ADC (turn off ADC power)
// configure A2D converter clock division (prescaling)
void a2dSetPrescaler(unsigned char prescale)
outb(ADCSRA, ((inb(ADCSRA) & ~ADC_PRESCALE_MASK) | prescale));
// configure A2D converter voltage reference
void a2dSetReference(unsigned char ref)
outb(ADMUX, ((inb(ADMUX) & ~ADC_REFERENCE_MASK) | (ref<<6)));
// sets the a2d input channel
void a2dSetChannel(unsigned char ch)
//关闭内部上拉电阻,设置端口为输入
cbi(PORTA,ch);
cbi(DDRA,ch);
outb(ADMUX, (inb(ADMUX) & ~ADC_MUX_MASK) | (ch & ADC_MUX_MASK)); // set channel
//// start a conversion on the current a2d input channel
//void a2dStartConvert(void)
//sbi(ADCSR, ADIF); // clear hardware "conversion complete" flag
//sbi(ADCSR, ADSC); // start conversion
//// return TRUE if conversion is complete
//u08 a2dIsComplete(void)
//return bit_is_set(ADCSR, ADSC);
//// Perform a 10-bit conversion
//// starts conversion, waits until conversion is done, and returns result
//unsigned short a2dConvert10bit(unsigned char ch)
//outb(ADMUX, (inb(ADMUX) & ~ADC_MUX_MASK) | (ch & ADC_MUX_MASK)); // set channel
////while(!a2dCompleteFlag); // wait until conversion complete
////while( bit_is_clear(ADCSR, ADIF) ); // wait until conversion complete
//while( bit_is_set(ADCSR, ADSC) ); // wait until conversion complete
//// CAUTION: MUST READ ADCL BEFORE ADCH!!!
//return (inb(ADCL) | (inb(ADCH)<<8)); // read ADC (full 10 bits);
// Perform a 8-bit conversion.
uint8_t a2dConvert8bit(void)
sbi(ADCSRA, ADIF); // clear hardware "conversion complete" flag
sbi(ADCSRA, ADSC); // start conversion
while(!(ADCSRA&(1<<ADSC))); //等待转换完成
uint8_t i=ADCH;
return (i); // 因初始化时已设置结果左对齐,只读ADCH即可
//! Interrupt handler for ADC complete interrupt.
//ISR(ADC_vect)
//// set the a2d conversion flag to indicate "complete"
//a2dCompleteFlag = TRUE;
