Download link
有问题反馈,
Tips:后果自负
- Release notes for EAGLE 6.6.0
- * Miscellaneous:
- - Member value of UL_ATTRIBUTE now always returns the attribute's value
- (also if it's from an instance, where the value is always inherited from the
- part attribute).
- - Added missing documentation on member xrefpart of UL_SCHEMATIC object.
- - If a ULP is started from a wire context menu, the wire's selection state
- (first, second or both endpoints) can now be queried in the ULP with ingroup().
- - Improved messages for ULP function neterror() in case of SSL error(s).
- Added a note on SSL errors to ULP net functions in help.
- - Improved help of TEXT regarding the vector font setting.
- - Added SET parameter Option.UnpopulatedMarkScaling to allow scaling down
- the mark of not populated parts in the current assembly variant.
- - Allow upper/lowercase renaming of an assembly variant.
- - Display of a warning with cancel option before a drawing from an older
- version (before version 6) gets overwritten.
- - Added new ULP function sleep().
- - Library update: Information to the user about devicesets that are used in
- schematic but can't be found in the corresponding update library.
- - Added a restriction note in help on ingroup() in relation with userdefined
- context menus.
- - Update in help for maximum sizes related to pads, smds, vias, wires,
- polygons and holes from 0.51602 inch to 200 mm and for board size from
- 1600x1600mm to 4000x4000mm.
- - Added a note in help on XML attribute order on ULP functions for XML.
- - New ULP Felicitas_PCBSim.ulp which creates an interface to PCBSim,
- a simulation tool for signal integrity analysis.
- - If an assembly variant is being defined for a part with library attribute
- 'VALUE' the variant value is now set according to this attribute.
- - New ULP EagleIDFExporter.ulp. It allows the export of an EAGLE board
- to 3D IDF format for further processing in a 3D CAD system. See also
- EagleIDFExporterInstructions.pdf in doc folder.
- * Bugfixes:
- - REPLACE with devices containing attribute VALUE: Update of part value
- accordingly for all cases.
- - Avoid misinterpretation of cutout polygons in packages as arbitrary pad shape.
- - Fix for mouse support for WACOM tablet driver.
- - Fix for swallowing of backslashes in TEXT command invoked from command line.
- - Fix for erroneous changing of dimension endpoints in MOVE command if selected
- by ctrl-click.
- - Fixed possible ignoring of prerouted segments by the autorouter (with possible
- DRC errors).
- - Fixed unjustified message about supply layers if updating drawings of an
- older EAGLE version.
- - Avoid duplicate contact references in the signal if connecting an implicitly
- connected power pin to this net explicitly.
- - Fixed handling of oversized description lines in the XML drawing file.
- - Fixed an occasional hangup of ULP dialogs if an additional confirmation
- dialog has been canceled.
- - Fix for using the proper net class while subtracting wires of pads with
- "Arbitrary Pad Shapes" from polygons.
- - Fixed missing message about insufficient number of contacts if adding a symbol.
- There was a problem if multiple contacts were connected to the same pin.
- - Fixed CUT (COPY) in schematic if a ULP used setgroup() on other sheets.
- - Fix for occasionally not displayed images in HTML descriptions.
- - Fixed loss of parameters for Autorouter default optimize passes if updating
- files to version 6.
- - Ensuring proper update for values of assembly variants after
- CHANGE PACKAGE/TECHNOLOGY in case of parts without user value by adapting
- it to the corresponding device name.
- - Fix for inconsistency after library update if a new device attribute
- collides with an existing schematic attribute.
- - Fixed skipping polygon wires with zero length but different curve values
- while loading drawings.
- - ULP function dlgRealEdit: Corrected warning if valid range is violated.
- - Fix for context menu function 'Open Device' for instances and elements in
- case of special package variant names.
- - Fix for erroneous inconsistency warning after creation of a board from schematic
- if the current assembly variant is not the default one.
- - Fixed unintended execution of the 'if' statement in ULPs if there was already
- an exit() in the 'if' condition.
- - Fix for showing a signal in rectangle mode (command 'SHOW @') if it only
- consists of a contact reference to a pad or SMD.
- - Fixed SPLIT on polygon wires; under certain conditions a wire could change
- to zero length and corrupt the polygon.
- - Fix for inconsistency after library update with existing assembly variants
- for device change from 'Value Off' to 'Value On' or name changes of the
- package variant or technology.
复制代码 |
