看参数很好的样子。。。
DE-5000 Handheld LCR Meter Basic Specifications
(See datasheet for full specifications)
Parameters measured:
Ls / Lp / Cs / Cp / Rs / Rp / DCR with D/Q/Θ/ESR measurement
Automatic L-C-R selection
Accuracy:
As good as 0.3% See datasheet for more info
Selectable test model:
Series or Parallel
Display:
Backlit 20,000/2,000 LCR Meter count
Input connection:
Accepts normal or shrouded banana plugs 2-Wire plus separate Guard
Automated LCR ranges:
L: 20.000 μH -- 2000 H
C: 200.00 pF -- 20.00 mF
R: 20.000 Ω -- 200.0 MΩ
DCR: 200.00 Ω -- 200.0 MΩ
Selectable test frequencies:
100 Hz / 120 Hz / 1 kHz / 10 kHz / 100 kHz
Measurement rate:
1.2/second nominal
Available tolerances for sorting function:
±0.25% ±5% ±0.5% ±10% ±1% ±20% ±2% -20/+80%
Response time:
Approx. 1 second/DUT
Temperature coefficient:
