发表于 2014-5-6 17:42:43
MPU6050的也贴下好了。
#include "anbt_mpu6050.h"
extern unsigned char anbt_ak8975_mag_data_buffer[6];
void ANBT_MPU6050_Init(void)
AnBT_Uart1_Send_String("M-6,Init MPU6050 Device.",24);
ANBT_MPU6050_PWM_CFG_FUN(); //圆点博士:设置内部时钟
ANBT_MPU6050_EXIT_SLEEP_FUN(); //圆点博士:退出休眠模式
ANBT_MPU6050_GYRO_CFG_FUN(); //圆点博士:设置陀螺仪量程
ANBT_MPU6050_ACCEL_CFG_FUN(); //圆点博士:设置加速度量程
ANBT_MPU6050_USER_CTRL_FUN();
ANBT_MPU6050_I2CBYPASS_CFG_FUN(); //圆点博士:设置电磁读写模式
ANBT_MPU6050_INT_CFG_FUN();
void ANBT_SEND_CHIP_IDs_FUN(u8 mpu6050_gyro_id,u8 hmc5883l_mag_id,u8 ak8975_mag_id)
unsigned char chip_id[3];
unsigned char data_type,checksum,i;
AnBT_Uart1_Send_String("M-7,Send chip IDs.",18);
chip_id[0]=mpu6050_gyro_id;
chip_id[1]=hmc5883l_mag_id;
chip_id[2]=ak8975_mag_id;
data_type=0xA0;
checksum=data_type;
for(i=0;i<3;i++) checksum+=chip_id[i];
checksum&=0xff;
checksum=~checksum;
checksum++;
AnBT_Uart1_Send_Char(':');
AnBT_Uart1_Send_Num(data_type);
for(i=0;i<3;i++) AnBT_Uart1_Send_Num(chip_id[i]);
AnBT_Uart1_Send_Num(checksum);
AnBT_Uart1_Send_Char('/');
AnBT_Uart1_Send_Char(13); //圆点博士:发送回车字符
u8 ANBT_MPU6050_GYRO_WHOAMI_FUN(void)
u8 anbt_mpu6050_gyro_id;
ANBT_I2C_START();
ANBT_I2C_SendByte(ANBT_MPU6050_GYRO_ADDR); //圆点博士:发送陀螺仪写地址
ANBT_I2C_SendByte(ANBT_MPU6050_GYRO_WHOAMI_ADDR); //圆点博士:发送陀螺仪ID地址
ANBT_I2C_START();
ANBT_I2C_SendByte(ANBT_MPU6050_GYRO_ADDR+1); //圆点博士:发送陀螺仪读地址
anbt_mpu6050_gyro_id=ANBT_I2C_ReceiveByte(); //圆点博士:读出陀螺仪ID
ANBT_I2C_STOP();
return anbt_mpu6050_gyro_id;
u8 ANBT_MPU6050_READ_REG_FUN(u8 anbt_mpu6050_dev_addr,u8 anbt_mpu6050_reg_addr)
u8 anbt_mpu6050_reg;
ANBT_I2C_START();
ANBT_I2C_SendByte(anbt_mpu6050_dev_addr); //圆点博士:发送陀螺仪写地址
ANBT_I2C_SendByte(anbt_mpu6050_reg_addr); //圆点博士:发送陀螺仪寄存器地址
ANBT_I2C_START();
ANBT_I2C_SendByte(anbt_mpu6050_dev_addr+1); //圆点博士:发送陀螺仪读地址
anbt_mpu6050_reg=ANBT_I2C_ReceiveByte(); //圆点博士:读出陀螺仪寄存器值
ANBT_I2C_STOP();
return anbt_mpu6050_reg;
void ANBT_MPU6050_PWM_CFG_FUN(void)
ANBT_I2C_START();
ANBT_I2C_SendByte(ANBT_MPU6050_PWR_MGMT_1_ADDR); //圆点博士:发送陀螺仪PWM地址
ANBT_I2C_SendByte(ANBT_MPU6050_PWR_MGMT_1_VALUE); //圆点博士:发送陀螺仪PWM值
ANBT_I2C_STOP();
void ANBT_MPU6050_GYRO_CFG_FUN(void)
ANBT_I2C_START();
ANBT_I2C_SendByte(ANBT_MPU6050_GYRO_CFG_ADDR); //圆点博士:发送陀螺仪PWM地址
ANBT_I2C_SendByte(ANBT_MPU6050_GYRO_CFG_VALUE); //圆点博士:发送陀螺仪PWM值
ANBT_I2C_STOP();
void ANBT_MPU6050_ACCEL_CFG_FUN(void)
ANBT_I2C_START();
ANBT_I2C_SendByte(ANBT_MPU6050_ACCEL_CFG_ADDR); //圆点博士:发送陀螺仪PWM地址
ANBT_I2C_SendByte(ANBT_MPU6050_ACCEL_CFG_VALUE); //圆点博士:发送陀螺仪PWM值
ANBT_I2C_STOP();
void ANBT_MPU6050_EXIT_SLEEP_FUN(void)
ANBT_I2C_START();
ANBT_I2C_SendByte(ANBT_MPU6050_EXIT_SLEEP_VALUE); //圆点博士:发送陀螺仪PWM值
ANBT_I2C_STOP();
void ANBT_MPU6050_USER_CTRL_FUN(void)
ANBT_I2C_START();
ANBT_I2C_SendByte(ANBT_MPU6050_USER_CTRL_ADDR); //圆点博士:发送陀螺仪PWM地址
ANBT_I2C_SendByte(ANBT_MPU6050_USER_CTRL_VALUE); //圆点博士:发送陀螺仪PWM值
ANBT_I2C_STOP();
void ANBT_MPU6050_I2CBYPASS_CFG_FUN(void)
ANBT_I2C_START();
ANBT_I2C_SendByte(ANBT_MPU6050_I2CBYPASS_CFG_ADDR); //圆点博士:发送陀螺仪PWM地址
ANBT_I2C_SendByte(ANBT_MPU6050_I2CBYPASS_CFG_VALUE); //圆点博士:发送陀螺仪PWM值
ANBT_I2C_STOP();
void ANBT_MPU6050_INT_CFG_FUN(void)
ANBT_I2C_START();
ANBT_I2C_SendByte(ANBT_MPU6050_INT_CFG_ADDR); //圆点博士:发送陀螺仪PWM地址
ANBT_I2C_SendByte(ANBT_MPU6050_INT_CFG_VALUE); //圆点博士:发送陀螺仪PWM值
ANBT_I2C_STOP();
void ANBT_MPU6050_GYRO_READ_FUN(u8 *mpu6050_gyro_data_buffer)
if(!ANBT_MPU6050_INT_STATE)
ANBT_I2C_START();
ANBT_I2C_SendByte(ANBT_MPU6050_ACCEL_DATA_ADDR); //圆点博士:发送陀螺仪寄存器地址
ANBT_I2C_START();
ANBT_I2C_Receive14Bytes(mpu6050_gyro_data_buffer); //圆点博士:读出陀螺仪寄存器值
ANBT_I2C_STOP();
void ANBT_MPU6050_SEND_DATA_FUN(u8 *mpu6050_gyro_data_buffer)
data_type=0xA1;
checksum=data_type;
for(i=0;i<14;i++) checksum+=mpu6050_gyro_data_buffer[i];
checksum&=0xff;
checksum=~checksum;
checksum++;
for(i=0;i<14;i++) AnBT_Uart1_Send_Num(mpu6050_gyro_data_buffer[i]);
