发表于 2014-4-21 09:19:50
改正了一下,还是提示错误 不明白他说的意思
.\Obj\Project.sct(7): error: L6236E: No section matches selector - no section to be FIRST/LAST.
Not enough information to list image symbols.
Not enough information to list the image map.
Finished: 2 information, 0 warning and 1 error messages.
".\Obj\Project.axf" - 1 Error(s), 0 Warning(s).
错误指向了
LR_IROM1 0x1A000000 0x00080000 { ; load region size_region
ER_IROM1 0x1A000000 0x00080000 { ; load address = execution address
*.o (RESET, +First) //错误指向此处
*(InRoot$$Sections)
.ANY (+RO)
RW_IRAM1 0x10000000 0x00008000 { ; RW data
.ANY (+RW +ZI)
改正代码如下
- ; uC/OS-III
- ; The Real-Time Kernel
- ; (c) Copyright 2010; Micrium, Inc.; Weston, FL
- ; All rights reserved. Protected by international copyright laws.
- ; ARM Cortex-M4 Port
- ; File : OS_CPU_A.ASM
- ; Version : V3.01.2
- ; By : JJL
- ; BAN
- ; For : ARMv7 Cortex-M4
- ; Mode : Thumb-2 ISA
- ; Toolchain : IAR EWARM
- ; PUBLIC FUNCTIONS
- EXTERN OSRunning ; External references
- EXTERN OSPrioCur
- EXTERN OSPrioHighRdy
- EXTERN OSTCBCurPtr
- EXTERN OSTCBHighRdyPtr
- EXTERN OSIntExit
- EXTERN OSTaskSwHook
- EXTERN OS_CPU_ExceptStkBase
- EXPORT OSStartHighRdy ; Functions declared in this file
- EXPORT OSCtxSw
- EXPORT OSIntCtxSw
- EXPORT OS_CPU_PendSVHandler
- ;IF {FPU} != "SoftVFP"
- ;EXPORT OS_CPU_FP_Reg_Push
- ;EXPORT OS_CPU_FP_Reg_Pop
- ;ENDIF
- ;#ifdef __ARMVFP__
- ;EXTERN OS_CPU_FP_Reg_Push
- ;EXTERN OS_CPU_FP_Reg_Pop
- ;#endif
- ;PAGE
- ; EQUATES
- NVIC_INT_CTRL EQU 0xE000ED04 ; Interrupt control state register.
- NVIC_SYSPRI14 EQU 0xE000ED22 ; System priority register (priority 14).
- NVIC_PENDSV_PRI EQU 0xFF ; PendSV priority value (lowest).
- NVIC_PENDSVSET EQU 0x10000000 ; Value to trigger PendSV exception.
- ; CODE GENERATION DIRECTIVES
- AREA |.text|, CODE, READONLY, ALIGN=2
- THUMB
- REQUIRE8
- PRESERVE8
- ;PAGE
- ; FLOATING POINT REGISTERS PUSH
- ; void OS_CPU_FP_Reg_Push (CPU_STK *stkPtr)
- ; Note(s) : 1) This function saves S0-S31, and FPSCR registers of the Floating Point Unit.
- ; 2) Pseudo-code is:
- ; a) Get FPSCR register value;
- ; b) Push value on process stack;
- ; c) Push remaining regs S0-S31 on process stack;
- ; d) Update OSTCBCurPtr->StkPtr;
- OS_CPU_FP_Reg_Push
- MRS R1, PSP ; PSP is process stack pointer
- CBZ R1, OS_CPU_FP_nosave ; Skip FP register save the first time
- VMRS R1, FPSCR
- STR R1, [R0, #-4]!
- VSTMDB R0!, {S0-S31}
- LDR R1, =OSTCBCurPtr
- LDR R2, [R1]
- STR R0, [R2]
- OS_CPU_FP_nosave
- BX LR
- ;PAGE
- ; FLOATING POINT REGISTERS POP
- ; void OS_CPU_FP_Reg_Pop (CPU_STK *stkPtr)
- ; Note(s) : 1) This function restores S0-S31, and FPSCR registers of the Floating Point Unit.
- ; a) Restore regs S0-S31 of new process stack;
- ; b) Restore FPSCR reg value
- ; c) Update OSTCBHighRdyPtr->StkPtr pointer of new proces stack;
- OS_CPU_FP_Reg_Pop
- VLDMIA R0!, {S0-S31}
- LDMIA R0!, {R1}
- VMSR FPSCR, R1
- LDR R1, =OSTCBHighRdyPtr
- LDR R2, [R1]
- STR R0, [R2]
- BX LR
- ;#endif
- ;PAGE
- ; START MULTITASKING
- ; void OSStartHighRdy(void)
- ; Note(s) : 1) This function triggers a PendSV exception (essentially, causes a context switch) to cause
- ; the first task to start.
- ; 2) OSStartHighRdy() MUST:
- ; a) Setup PendSV exception priority to lowest;
- ; b) Set initial PSP to 0, to tell context switcher this is first run;
- ; c) Set the main stack to OS_CPU_ExceptStkBase
- ; d) Trigger PendSV exception;
- ; e) Enable interrupts (tasks will run with interrupts enabled).
- OSStartHighRdy
- LDR R0, =NVIC_SYSPRI14 ; Set the PendSV exception priority
- LDR R1, =NVIC_PENDSV_PRI
- STRB R1, [R0]
- MOVS R0, #0 ; Set the PSP to 0 for initial context switch call
- MSR PSP, R0
- LDR R0, =OS_CPU_ExceptStkBase ; Initialize the MSP to the OS_CPU_ExceptStkBase
- LDR R1, [R0]
- MSR MSP, R1
- LDR R0, =NVIC_INT_CTRL ; Trigger the PendSV exception (causes context switch)
- LDR R1, =NVIC_PENDSVSET
- STR R1, [R0]
- CPSIE I ; Enable interrupts at processor level
- OSStartHang
- B OSStartHang ; Should never get here
- ;PAGE
- ; PERFORM A CONTEXT SWITCH (From task level) - OSCtxSw()
- ; Note(s) : 1) OSCtxSw() is called when OS wants to perform a task context switch. This function
- ; triggers the PendSV exception which is where the real work is done.
- OSCtxSw
- STR R1, [R0]
- BX LR
- ;PAGE
- ; PERFORM A CONTEXT SWITCH (From interrupt level) - OSIntCtxSw()
- ; Note(s) : 1) OSIntCtxSw() is called by OSIntExit() when it determines a context switch is needed as
- ; the result of an interrupt. This function simply triggers a PendSV exception which will
- ; be handled when there are no more interrupts active and interrupts are enabled.
- OSIntCtxSw
- STR R1, [R0]
- BX LR
- ;PAGE
- ; HANDLE PendSV EXCEPTION
- ; void OS_CPU_PendSVHandler(void)
- ; Note(s) : 1) PendSV is used to cause a context switch. This is a recommended method for performing
- ; context switches with Cortex-M3. This is because the Cortex-M3 auto-saves half of the
- ; processor context on any exception, and restores same on return from exception. So only
- ; saving of R4-R11 is required and fixing up the stack pointers. Using the PendSV exception
- ; this way means that context saving and restoring is identical whether it is initiated from
- ; a thread or occurs due to an interrupt or exception.
- ; a) Get the process SP, if 0 then skip (goto d) the saving part (first context switch);
- ; b) Save remaining regs r4-r11 on process stack;
- ; c) Save the process SP in its TCB, OSTCBCurPtr->OSTCBStkPtr = SP;
- ; d) Call OSTaskSwHook();
- ; e) Get current high priority, OSPrioCur = OSPrioHighRdy;
- ; f) Get current ready thread TCB, OSTCBCurPtr = OSTCBHighRdyPtr;
- ; g) Get new process SP from TCB, SP = OSTCBHighRdyPtr->OSTCBStkPtr;
- ; h) Restore R4-R11 from new process stack;
- ; i) Perform exception return which will restore remaining context.
- ; 3) On entry into PendSV handler:
- ; a) The following have been saved on the process stack (by processor):
- ; xPSR, PC, LR, R12, R0-R3
- ; b) Processor mode is switched to Handler mode (from Thread mode)
- ; c) Stack is Main stack (switched from Process stack)
- ; d) OSTCBCurPtr points to the OS_TCB of the task to suspend
- ; OSTCBHighRdyPtr points to the OS_TCB of the task to resume
- ; 4) Since PendSV is set to lowest priority in the system (by OSStartHighRdy() above), we
- ; know that it will only be run when no other exception or interrupt is active, and
- ; therefore safe to assume that context being switched out was using the process stack (PSP).
- OS_CPU_PendSVHandler
- CPSID I ; Prevent interruption during context switch
- MRS R0, PSP ; PSP is process stack pointer
- CBZ R0, OS_CPU_PendSVHandler_nosave ; Skip register save the first time
- SUBS R0, R0, #0x20 ; Save remaining regs r4-11 on process stack
- STM R0, {R4-R11}
- LDR R1, =OSTCBCurPtr ; OSTCBCurPtr->OSTCBStkPtr = SP;
- LDR R1, [R1]
- STR R0, [R1] ; R0 is SP of process being switched out
- ; At this point, entire context of process has been saved
- OS_CPU_PendSVHandler_nosave
- PUSH {R14} ; Save LR exc_return value
- LDR R0, =OSTaskSwHook ; OSTaskSwHook();
- BLX R0
- POP {R14}
- LDR R0, =OSPrioCur ; OSPrioCur = OSPrioHighRdy;
- LDR R1, =OSPrioHighRdy
- LDRB R2, [R1]
- STRB R2, [R0]
- LDR R0, =OSTCBCurPtr ; OSTCBCurPtr = OSTCBHighRdyPtr;
- LDR R2, [R1]
- STR R2, [R0]
- LDR R0, [R2] ; R0 is new process SP; SP = OSTCBHighRdyPtr->StkPtr;
- LDM R0, {R4-R11} ; Restore r4-11 from new process stack
- ADDS R0, R0, #0x20
- MSR PSP, R0 ; Load PSP with new process SP
- ORR LR, LR, #0x04 ; Ensure exception return uses process stack
- CPSIE I
- BX LR ; Exception return will restore remaining context
- END
复制代码 |
