发表于 2014-4-13 18:11:25
是用verilog写的,产生2.5V的不错。50MV的不行,,估计50mv的干扰大过我要输出的,上代码了。。
//2.5V/7.5ms
//50mv/0.2ms
module Tra(CLK,RST_N,DA_SCLK1,DA_DIN1,DA_DIN2,DA_SYNC1,DA_SYNC2,DA_SCLK2,DA_data2);
input CLK;
input RST_N;
output DA_SCLK1;
output DA_SCLK2;
output DA_DIN1;
output DA_SYNC1;
output DA_DIN2;
output DA_SYNC2;
wire DA_WCLK;
//output[11:0] DA_data1;
output[5:0] DA_data2;
pll pll_inst(
.inclk0(CLK),
.c0(DA_SCLK1),
.c1(DA_SCLK2),
.c2(DA_WCLK)
reg [4:0] sync_cnt1;
reg DA_SYNC1_r;
always @(posedge DA_WCLK or negedge RST_N)
begin
if(!RST_N)
sync_cnt1 <= 5'd0;
else if(sync_cnt1==5'd23)
sync_cnt1 <= 5'd0;
sync_cnt1 <= sync_cnt1 + 1'b1;
end
begin
if(!RST_N)
DA_SYNC1_r <= 1'b0;
else if(sync_cnt1 < 5'd1)
DA_SYNC1_r <= 1'b1;
DA_SYNC1_r <= 1'b0;
end
assign DA_SYNC1 = DA_SYNC1_r;
reg adr_en;
begin
if(!RST_N)
adr_en <= 1'b0;
else if(sync_cnt1==5'd20)
adr_en <= 1'b1;
adr_en <= 1'b0;
end
wire [11:0] adr_rom;
reg [11:0] adr_rom_r;
wire [11:0] DA_data1;
wire rom_clk;
assign rom_clk = ~DA_WCLK;
assign adr_rom = adr_rom_r;
reg[1:0] out_st;
reg[15:0] high_cnt;
begin
if(!RST_N)
begin
adr_rom_r <= 12'd0;
out_st <= 2'b00;
high_cnt <= 16'd0;
end
case(out_st)
2'b00:begin
if(adr_en && adr_rom_r<12'd3013 )
adr_rom_r <= adr_rom_r + 1'b1;
else if(adr_rom_r==12'd3013)
begin
out_st <= 2'b01;
end
adr_rom_r <= adr_rom_r;
end
2'b01:begin
adr_rom_r <= 12'd3013;
if(high_cnt==16'd59999)
begin
out_st <= 2'b10;
high_cnt <= 16'd0;
end
begin
high_cnt <= high_cnt + 1'b1;
out_st <= 2'b01;
end
end
2'b10:begin
if(adr_en && adr_rom_r>12'd0 )
adr_rom_r <= adr_rom_r - 1'b1;
else if(adr_rom_r==12'd0)
begin
out_st <= 2'b11;
end
end
2'b11:begin
adr_rom_r <= 12'd0;
begin
out_st <= 2'b00;
high_cnt <= 16'd0;
end
begin
out_st <= 2'b11;
end
end
default: out_st <= 2'b00;
endcase
end
rom1 rom1_inst(
.address(adr_rom),
.clock(rom_clk),
.q(DA_data1)
reg DA_DIN1_r;
reg [4:0] st;
begin
if(!RST_N)
begin
DA_DIN1_r <= 1'b0;
st <= 5'd0;
end
begin
case(st)
5'd0:begin
if(DA_SYNC1_r==1'b1)
begin
DA_DIN1_r <= 1'b0;//16
st <= 5'd1;
end
st <= 5'd0;
end
5'd1:begin DA_DIN1_r <= 1'b0; st <= 5'd2;end//15
5'd2:begin DA_DIN1_r <= 1'b0; st <= 5'd3;end//14
5'd3:begin DA_DIN1_r <= 1'b0; st <= 5'd4;end//13
5'd4:begin DA_DIN1_r <= DA_data1[11]; st <= 5'd5;end//12
5'd5:begin DA_DIN1_r <= DA_data1[10]; st <= 5'd6;end//11
5'd6:begin DA_DIN1_r <= DA_data1[9]; st <= 5'd7;end//10
5'd7:begin DA_DIN1_r <= DA_data1[8]; st <= 5'd8;end//9
5'd8:begin DA_DIN1_r <= DA_data1[7]; st <= 5'd9;end//8
5'd9:begin DA_DIN1_r <= DA_data1[6]; st <= 5'd10;end//7
5'd10:begin DA_DIN1_r <= DA_data1[5]; st <= 5'd11;end//6
5'd11:begin DA_DIN1_r <= DA_data1[4]; st <= 5'd12;end//5
5'd12:begin DA_DIN1_r <= DA_data1[3]; st <= 5'd13;end//4
5'd13:begin DA_DIN1_r <= DA_data1[2]; st <= 5'd14;end//3
5'd14:begin DA_DIN1_r <= DA_data1[1]; st <= 5'd15;end//2
5'd15:begin DA_DIN1_r <= DA_data1[0]; st <= 5'd0;end//1
default st <= 5'd0;
endcase
end
end
assign DA_DIN1 = DA_DIN1_r;
//.............50mv.................
reg [5:0] sync_cnt2;
reg DA_SYNC2_r;
begin
if(!RST_N)
sync_cnt2 <= 6'd0;
else if(sync_cnt2==6'd33)
sync_cnt2 <= 6'd0;
sync_cnt2 <= sync_cnt2 + 1'b1;
end
begin
if(!RST_N)
DA_SYNC2_r <= 1'b0;
else if(sync_cnt2 < 6'd1)
DA_SYNC2_r <= 1'b1;
DA_SYNC2_r <= 1'b0;
end
assign DA_SYNC2 = DA_SYNC2_r;
reg adr_en2;
begin
if(!RST_N)
adr_en2 <= 1'b0;
else if(sync_cnt2==6'd20)
adr_en2 <= 1'b1;
adr_en2 <= 1'b0;
end
wire [5:0] adr_rom2;
reg [5:0] adr_rom_r2;
//wire [11:0] DA_data2;
reg[1:0] out_st2;
reg[15:0] high_cnt2;
begin
if(!RST_N)
begin
adr_rom_r2 <= 6'd0;
out_st2 <= 2'b00;
high_cnt2 <= 16'd0;
end
case(out_st2)
2'b00:begin
if(adr_en2 && adr_rom_r2<6'd59 )
adr_rom_r2 <= adr_rom_r2 + 1'b1;
else if(adr_rom_r==6'd59)
begin
out_st2 <= 2'b01;
end
adr_rom_r2 <= adr_rom_r2;
end
2'b01:begin
adr_rom_r2 <= 6'd59;
if(high_cnt2==16'd59999)
begin
out_st2 <= 2'b10;
high_cnt2 <= 16'd0;
end
begin
high_cnt2 <= high_cnt2 + 1'b1;
out_st2 <= 2'b01;
end
end
2'b10:begin
if(adr_en2 && adr_rom_r>6'd0 )
adr_rom_r2 <= adr_rom_r2 - 1'b1;
else if(adr_rom_r==6'd0)
begin
out_st2 <= 2'b11;
end
end
2'b11:begin
adr_rom_r2 <= 6'd0;
begin
out_st2 <= 2'b00;
high_cnt2 <= 16'd0;
end
begin
out_st2 <= 2'b11;
end
end
default: out_st2 <= 2'b00;
endcase
end
assign adr_rom2 = adr_rom_r2;
rom3 rom3_inst(
.address(adr_rom2),
.clock(rom_clk),
.q(DA_data2)
reg DA_DIN2_r;
reg [4:0] st2;
begin
if(!RST_N)
begin
DA_DIN2_r <= 1'b0;
st2 <= 5'd0;
end
begin
case(st2)
5'd0:begin
if(DA_SYNC2_r==1'b1)
begin
DA_DIN2_r <= 1'b0;//16
st2 <= 5'd1;
end
st2 <= 5'd0;
end
5'd1:begin DA_DIN2_r <= 1'b0; st2 <= 5'd2;end//15
5'd2:begin DA_DIN2_r <= 1'b0; st2 <= 5'd3;end//14
5'd3:begin DA_DIN2_r <= 1'b0; st2 <= 5'd4;end//13
5'd4:begin DA_DIN2_r <= 1'b0; st2 <= 5'd5;end//12
5'd5:begin DA_DIN2_r <= 1'b0; st2 <= 5'd6;end//11
5'd6:begin DA_DIN2_r <= 1'b0; st2 <= 5'd7;end//10
5'd7:begin DA_DIN2_r <= 1'b0; st2 <= 5'd8;end//9
5'd8:begin DA_DIN2_r <= 1'b0; st2 <= 5'd9;end//8
5'd9:begin DA_DIN2_r <= 1'b0; st2 <= 5'd10;end//7
5'd10:begin DA_DIN2_r <= DA_data2[5]; st2 <= 5'd11;end//6
5'd11:begin DA_DIN2_r <= DA_data2[4]; st2 <= 5'd12;end//5
5'd12:begin DA_DIN2_r <= DA_data2[3]; st2 <= 5'd13;end//4
5'd13:begin DA_DIN2_r <= DA_data2[2]; st2 <= 5'd14;end//3
5'd14:begin DA_DIN2_r <= DA_data2[1]; st2 <= 5'd15;end//2
5'd15:begin DA_DIN2_r <= DA_data2[0]; st2 <= 5'd0;end//1
default st2 <= 5'd0;
endcase
end
end
assign DA_DIN2 = DA_DIN2_r;
endmodule
