大家好
本人近期在把玩51单片机,在工程里实现一些简单的功能,用到了定时器0中断,串口中断以及外部中断0和外部中断1,现在将详细解释一下:
(问题;在外没有触发外部中断0或者是外部中断1时,串口通信正常,但是当外部一旦触发了外部中断0或者是外部中断1的操作时,串口通信就不正常了,我用串口调试助手发送数据,没有返回。请问各位大神,这个问题出现在哪了?)
定时器0:用于定时刷新数码管显示,并作1秒计数加1后放在数码管上显示;
串口中断:用于和外部通信,
外部中断0:触发方式为低电平,检测到低电平信号时,打开蜂鸣器;
外部中断1:触发方式为低电平,检测到低电平信号时,关闭蜂鸣器;
//main.c
#include <reg51.h>
#include "uart.h"
#include "delay.h"
#include "crc.h"
sbit LED_G1 = P2^0;
sbit LED_G2 = P2^1;
sbit LED_G3 = P2^2;
sbit LED_G4 = P2^3;
sbit LED_G5 = P2^4;
sbit LED_G6 = P2^5;
sbit LED_G7 = P2^6;
sbit LED_G8 = P2^7;
sbit SPK = P1^4;
sbit SMG1 = P1^0;
sbit SMG2 = P1^1;
sbit SMG3 = P1^2;
sbit SMG4 = P1^3;
//共阳段码编码表0-1-2-3-4-5-6-7-8-9-A-B-C-D-E-F(本程序中用共阳)
unsigned char code SMG_TabV[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
//共阴段码编码表0-1-2-3-4-5-6-7-8-9-A-B-C-D-E-F
unsigned char code SMG_TabG[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
unsigned char qian,bai,shi,ge;
unsigned int smg_count;
unsigned int t0_count;
unsigned char next_c;
extern unsigned char rx_buf[20];
extern unsigned char rx_count;
unsigned char tx_buf[20]={0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08};
void timer0_init(void);
void SMG_data(void);
void exit_int01_init(void);
int main()
timer0_init();
exit_int01_init();
uart_init();
EA = 1;//开全局总中断
if((rx_buf[0]==2)&&(usMBCRC16(rx_buf,rx_count)==0))
tx_buf[8] = rx_count;
data8_send(tx_buf,9);
rx_buf[0] = 0;
rx_count = 0;
//定时器0中断入口函数
void timer0_isr(void) interrupt 1 using 1
t0_count++;
next_c++;
TH0 = 0XF8; //定时2ms,装置数据高8位
TL0 = 0X30; //定时2ms,装置数据低8位
if(next_c == 1)
SMG_data();
P0 = SMG_TabV[qian];
SMG1 = 1;
SMG2 = 1;
SMG3 = 1;
SMG4 = 0;
else if(next_c == 2)
SMG_data();
P0 = SMG_TabV[bai];
SMG1 = 1;
SMG2 = 1;
SMG3 = 0;
SMG4 = 1;
else if(next_c == 3)
SMG_data();
P0 = SMG_TabV[shi];
SMG1 = 1;
SMG2 = 0;
SMG3 = 1;
SMG4 = 1;
else if(next_c == 4)
SMG_data();
P0 = SMG_TabV[ge];
SMG1 = 0;
SMG2 = 1;
SMG3 = 1;
SMG4 = 1;
if(next_c == 4)
next_c = 0;
//定时器0 实现10ms定时初始化
TMOD = 0X01; //使能定时器0,工作方式1,16位计数
TR0 = 1; //使能定时器0
ET0 = 1; //允许定时器0中断
EX0 = 1;//允许外部中断0开
IT0 = 0;//电平触发方式,低电平有效,若为1,则为脉冲触发方式,下降沿有效
EX1 = 1;//允许外部中断1开
IT1 = 0;//电平触发方式,低电平有效,若为1,则为脉冲触发方式,下降沿有效
void int0_isr(void) interrupt 0 using 0
IE0 = 0;
SPK = 0;//打开蜂鸣器
void int1_isr(void) interrupt 2 using 1
IE1 = 0;
SPK = 1;//关闭蜂鸣器
void SMG_data(void)
if(t0_count == 500)
t0_count = 0;
LED_G1 = ~LED_G1;
LED_G2 = ~LED_G2;
LED_G3 = ~LED_G3;
LED_G4 = ~LED_G4;
LED_G5 = ~LED_G5;
LED_G6 = ~LED_G6;
LED_G7 = ~LED_G7;
LED_G8 = ~LED_G8;
//数码管显示计数,1秒累加一次
smg_count++;
ge = smg_count%10;
shi = (smg_count/10)%10;
bai = (smg_count/100)%10;
qian = smg_count/1000;
以下部分为串口中断//////////////////////////////////////////////////////////////////////////////////////////
unsigned char rx_buf[20]={0};
unsigned char rx_count=0;
void uart_init(void)
SCON = 0X50;//8位UART,波特率可变
TMOD |= 0X20;//定时器1工作方式2,产生9600 baudrate
TH1 = 0XFD;//装置波特率参数
TR1 = 1; //使能定时器1工作
ES = 1; //便能串口中断
void uart_isr() interrupt 4 using 1
if(RI == 1) //判断是接收中断产生
RI = 0; //标志位清零
rx_buf[rx_count++] = SBUF; //读缓冲区的值
if(TI == 1) //如果是发送标志位,清零
TI=0;
void data8_send(unsigned char *tx_dat,unsigned char len)
unsigned char i;
for(i=0;i<len;i++)
SBUF = *(tx_dat+i);
delay_ms(1);
问题;
真的是非常感谢了哦。 |
