- //**** PITCH & ROLL & YAW PID ****
- int16_t prop;
- prop = min(max(abs(rcCommand[PITCH]),abs(rcCommand[ROLL])),500); // range [0;500]
- for(axis=0;axis<3;axis++) {
- if ((f.ANGLE_MODE || f.HORIZON_MODE) && axis<2 ) { // MODE relying on ACC
- // 50 degrees max inclination,倾角限定在50度,对应下面语句的【-500,500】,angle角度也是数值乘0.1后的结果。
- //rcCommand [-500;+500] for ROLL/PITCH/YAW ,‘<<1’扩大到[-1000,1000],与gps角度求和
- errorAngle = constrain((rcCommand[axis]<<1) + GPS_angle[axis],-500,+500) - angle[axis] + conf.angleTrim[axis]; //16 bits is ok here
- PTermACC = ((int32_t)errorAngle*conf.P8[PIDLEVEL])>>7; // 32 bits is needed for calculation: errorAngle*P8[PIDLEVEL] could exceed 32768 16 bits is ok for result
- PTermACC = constrain(PTermACC,-conf.D8[PIDLEVEL]*5,+conf.D8[PIDLEVEL]*5);
- errorAngleI[axis] = constrain(errorAngleI[axis]+errorAngle,-10000,+10000); // WindUp //16 bits is ok here
- ITermACC = ((int32_t)errorAngleI[axis]*conf.I8[PIDLEVEL])>>12; // 32 bits is needed for calculation:10000*I8 could exceed 32768 16 bits is ok for result
- if ( !f.ANGLE_MODE || f.HORIZON_MODE || axis == 2 ) { // MODE relying on GYRO or YAW axis
- if (abs(rcCommand[axis])<500) error = (rcCommand[axis]<<6)/conf.P8[axis] ; // 16 bits is needed for calculation: 500*64 = 32000 16 bits is ok for result if P8>5 (P>0.5)
- else error = ((int32_t)rcCommand[axis]<<6)/conf.P8[axis] ; // 32 bits is needed for calculation
- error -= gyroData[axis];
- PTermGYRO = rcCommand[axis];
- errorGyroI[axis] = constrain(errorGyroI[axis]+error,-16000,+16000); // WindUp 16 bits is ok here
- if (abs(gyroData[axis])>640) errorGyroI[axis] = 0;
- ITermGYRO = ((errorGyroI[axis]>>7)*conf.I8[axis])>>6; // 16 bits is ok here 16000/125 = 128 ; 128*250 = 32000
- if ( f.HORIZON_MODE && axis<2) {
- PTerm = ((int32_t)PTermACC*(512-prop) + (int32_t)PTermGYRO*prop)>>9; // the real factor should be 500, but 512 is ok
- ITerm = ((int32_t)ITermACC*(512-prop) + (int32_t)ITermGYRO*prop)>>9;
- } else {
- if ( f.ANGLE_MODE && axis<2) {
- PTerm = PTermACC;
- ITerm = ITermACC;
- } else {
- PTerm = PTermGYRO;
- ITerm = ITermGYRO;
- PTerm -= ((int32_t)gyroData[axis]*dynP8[axis])>>6; // 32 bits is needed for calculation
- delta = gyroData[axis] - lastGyro[axis]; // 16 bits is ok here, the dif between 2 consecutive gyro reads is limited to 800
- lastGyro[axis] = gyroData[axis];
- deltaSum = delta1[axis]+delta2[axis]+delta;
- delta2[axis] = delta1[axis];
- delta1[axis] = delta;
- DTerm = ((int32_t)deltaSum*dynD8[axis])>>5; // 32 bits is needed for calculation
- axisPID[axis] = PTerm + ITerm - DTerm;
上面代码是MWC 2.2中的PID相关代码,有几个问题,麻烦大家指点下~
1.像“ PTermACC = ((int32_t)errorAngle*conf.P8[PIDLEVEL])>>7; ”这条语句里面的移位操作,代码里的位移操作的依据是什么呢呢?
2.“PTerm -= ((int32_t)gyroData[axis]*dynP8[axis])>>6; // 32 bits is needed for calculation”,PTermACC减去这部分的依据是什么呢? |
