GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; //
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //上拉输入模式
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3, ENABLE); //TIM3局部复用功能开启,在TIM3的局部复用开启时,PB5会被复用为TIM3_CH2
TIM_TimeBaseStructure.TIM_Period = 2000; //设定计数器自动重装值 最大10ms溢出
TIM_TimeBaseStructure.TIM_Prescaler = 71; //预分频器,1M的计数频率,1us加1.
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //设置时钟分割:TDTS = Tck_tim
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上计数模式
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); //根据指定的参数初始化TIMx
TIM_ICInitStructure.TIM_Channel = TIM_Channel_2; // 选择输入端 IC2映射到TI2上
TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising; //上升沿捕获
TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1; //配置输入分频,不分频
TIM_ICInitStructure.TIM_ICFilter = 0x03; //IC2F=0011 配置输入滤波器 8个定时器时钟周期滤波
TIM_ICInit(TIM3, &TIM_ICInitStructure); //初始化定时器输入捕获通道
TIM_Cmd(TIM3, ENABLE); //使能定时器3
TIM_ITConfig(TIM3, TIM_IT_Update | TIM_IT_CC2, ENABLE); //允许更新中断 ,允许CC4IE捕获中断
问题是:定时器分频为71,程序可以运行,但是捕获时间不正确,如果将定时器分频为719,出现Jlink ERROR如下:
求指教原因?
