发表于 2014-3-21 09:14:41
FreeRTOS的tickless模式在文件port.C里面,内容如下,看下大概的注释就懂是什么意思了。
- #if configUSE_TICKLESS_IDLE == 1
- __weak void vPortSuppressTicksAndSleep( TickType_t xExpectedIdleTime )
- uint32_t ulReloadValue, ulCompleteTickPeriods, ulCompletedSysTickDecrements, ulSysTickCTRL;
- TickType_t xModifiableIdleTime;
- /* Make sure the SysTick reload value does not overflow the counter. */
- if( xExpectedIdleTime > xMaximumPossibleSuppressedTicks )
- xExpectedIdleTime = xMaximumPossibleSuppressedTicks;
- /* Stop the SysTick momentarily. The time the SysTick is stopped for
- is accounted for as best it can be, but using the tickless mode will
- inevitably result in some tiny drift of the time maintained by the
- kernel with respect to calendar time. */
- portNVIC_SYSTICK_CTRL_REG &= ~portNVIC_SYSTICK_ENABLE_BIT;
- /* Calculate the reload value required to wait xExpectedIdleTime
- tick periods. -1 is used because this code will execute part way
- through one of the tick periods. */
- ulReloadValue = portNVIC_SYSTICK_CURRENT_VALUE_REG + ( ulTimerCountsForOneTick * ( xExpectedIdleTime - 1UL ) );
- if( ulReloadValue > ulStoppedTimerCompensation )
- ulReloadValue -= ulStoppedTimerCompensation;
- /* Enter a critical section but don't use the taskENTER_CRITICAL()
- method as that will mask interrupts that should exit sleep mode. */
- __disable_irq();
- /* If a context switch is pending or a task is waiting for the scheduler
- to be unsuspended then abandon the low power entry. */
- if( eTaskConfirmSleepModeStatus() == eAbortSleep )
- /* Restart from whatever is left in the count register to complete
- this tick period. */
- portNVIC_SYSTICK_LOAD_REG = portNVIC_SYSTICK_CURRENT_VALUE_REG;
- /* Restart SysTick. */
- portNVIC_SYSTICK_CTRL_REG |= portNVIC_SYSTICK_ENABLE_BIT;
- /* Reset the reload register to the value required for normal tick
- periods. */
- portNVIC_SYSTICK_LOAD_REG = ulTimerCountsForOneTick - 1UL;
- /* Re-enable interrupts - see comments above __disable_irq() call
- above. */
- __enable_irq();
- else
- /* Set the new reload value. */
- portNVIC_SYSTICK_LOAD_REG = ulReloadValue;
- /* Clear the SysTick count flag and set the count value back to
- zero. */
- portNVIC_SYSTICK_CURRENT_VALUE_REG = 0UL;
- /* Sleep until something happens. configPRE_SLEEP_PROCESSING() can
- set its parameter to 0 to indicate that its implementation contains
- its own wait for interrupt or wait for event instruction, and so wfi
- should not be executed again. However, the original expected idle
- time variable must remain unmodified, so a copy is taken. */
- xModifiableIdleTime = xExpectedIdleTime;
- configPRE_SLEEP_PROCESSING( xModifiableIdleTime );
- if( xModifiableIdleTime > 0 )
- __dsb( portSY_FULL_READ_WRITE );
- __wfi();
- __isb( portSY_FULL_READ_WRITE );
- configPOST_SLEEP_PROCESSING( xExpectedIdleTime );
- /* Stop SysTick. Again, the time the SysTick is stopped for is
- accounted for as best it can be, but using the tickless mode will
- ulSysTickCTRL = portNVIC_SYSTICK_CTRL_REG;
- portNVIC_SYSTICK_CTRL_REG = ( ulSysTickCTRL & ~portNVIC_SYSTICK_ENABLE_BIT );
- above. */
- __enable_irq();
- if( ( ulSysTickCTRL & portNVIC_SYSTICK_COUNT_FLAG_BIT ) != 0 )
- uint32_t ulCalculatedLoadValue;
- /* The tick interrupt has already executed, and the SysTick
- count reloaded with ulReloadValue. Reset the
- portNVIC_SYSTICK_LOAD_REG with whatever remains of this tick
- period. */
- ulCalculatedLoadValue = ( ulTimerCountsForOneTick - 1UL ) - ( ulReloadValue - portNVIC_SYSTICK_CURRENT_VALUE_REG );
- /* Don't allow a tiny value, or values that have somehow
- underflowed because the post sleep hook did something
- that took too long. */
- if( ( ulCalculatedLoadValue < ulStoppedTimerCompensation ) || ( ulCalculatedLoadValue > ulTimerCountsForOneTick ) )
- ulCalculatedLoadValue = ( ulTimerCountsForOneTick - 1UL );
- portNVIC_SYSTICK_LOAD_REG = ulCalculatedLoadValue;
- /* The tick interrupt handler will already have pended the tick
- processing in the kernel. As the pending tick will be
- processed as soon as this function exits, the tick value
- maintained by the tick is stepped forward by one less than the
- time spent waiting. */
- ulCompleteTickPeriods = xExpectedIdleTime - 1UL;
- else
- /* Something other than the tick interrupt ended the sleep.
- Work out how long the sleep lasted rounded to complete tick
- periods (not the ulReload value which accounted for part
- ticks). */
- ulCompletedSysTickDecrements = ( xExpectedIdleTime * ulTimerCountsForOneTick ) - portNVIC_SYSTICK_CURRENT_VALUE_REG;
- /* How many complete tick periods passed while the processor
- was waiting? */
- ulCompleteTickPeriods = ulCompletedSysTickDecrements / ulTimerCountsForOneTick;
- /* The reload value is set to whatever fraction of a single tick
- period remains. */
- portNVIC_SYSTICK_LOAD_REG = ( ( ulCompleteTickPeriods + 1 ) * ulTimerCountsForOneTick ) - ulCompletedSysTickDecrements;
- /* Restart SysTick so it runs from portNVIC_SYSTICK_LOAD_REG
- again, then set portNVIC_SYSTICK_LOAD_REG back to its standard
- value. The critical section is used to ensure the tick interrupt
- can only execute once in the case that the reload register is near
- zero. */
- portENTER_CRITICAL();
- vTaskStepTick( ulCompleteTickPeriods );
- portEXIT_CRITICAL();
- #endif /* #if configUSE_TICKLESS_IDLE */
复制代码 |
