发表于 2014-4-9 08:52:29
#include "bk2423.h"
UINT8 op_status;
//Bank1 register initialization value
//In the array Bank1_Reg0_13,all[] the register value is the byte reversed!!!!!!!!!!!!!!!!!!!!!
code unsigned long Bank1_Reg0_13[]={
0xE2014B40,
0x00004BC0,
0x028CFCD0,
0x41390099,
0x0B86BED9, //high sensitivity mode, to enable normal sensitivity mode,use 0x0B869ED9
0xA67F0624, //RSSI measurement disabled, to enable RSSI measurement,use 0xA67F0224
0x00000000,
0x00000000,
0x00000000,
0x00000000,
0x00000000,
0x00000000,
0x00127305,
0x36B48000,
code UINT8 Bank1_Reg14[]=
0x41,0x10,0x04,0x82,0x20,0x08,0x08,0xF2,0x7D,0xEF,0xFF
//Bank0 register initialization value
code UINT8 Bank0_Reg[][2]={
{0,0x0F},
{1,0x3F},
{2,0x3F},
{3,0x03},
{4,0xff},
{5,0x17},
{6,0x0F}, //0x0F or 0x2F:2Mbps; 0x07:1Mbps ; 0x27:250Kbps
{7,0x07},
{8,0x00},
{9,0x00},
{12,0xc3},
{13,0xc4},
{14,0xc5},
{15,0xc6},
{17,0x20},
{18,0x20},
{19,0x20},
{20,0x20},
{21,0x20},
{22,0x20},
{23,0x00},
{28,0x3F},
{29,0x07}
code UINT8 RX0_Address[]={0x15,0x59,0x23,0xC6,0x29};
code UINT8 RX1_Address[]={0x10,0x56,0x24,0xCD,0x78};
// SPI access //
Function: SPI_RW();
Description:
Writes one UINT8 to BK2423, and return the UINT8 read
UINT8 SPI_RW(UINT8 value)
UINT8 bit_ctr;
for(bit_ctr=0;bit_ctr<8;bit_ctr++) // output 8-bit
if(value & 0x80)
MOSI=1;
MOSI=0;
value = (value << 1); // shift next bit into MSB..
SCK = 1; // Set SCK high..
value |= MISO; // capture current MISO bit
SCK = 0; // ..then set SCK low again
return(value); // return read UINT8
Function: SPI_Write_Reg();
Description:
Writes value 'value' to register 'reg'
void SPI_Write_Reg(UINT8 reg, UINT8 value)
CSN = 0; // CSN low, init SPI transaction
op_status = SPI_RW(reg); // select register
SPI_RW(value); // ..and write value to it..
CSN = 1; // CSN high again
Function: SPI_Read_Reg();
Description:
Read one UINT8 from BK2423 register, 'reg'
UINT8 SPI_Read_Reg(UINT8 reg)
UINT8 value;
CSN = 0; // CSN low, initialize SPI communication...
op_status=SPI_RW(reg); // Select register to read from..
value = SPI_RW(0); // ..then read register value
CSN = 1; // CSN high, terminate SPI communication
return(value); // return register value
Function: SPI_Read_Buf();
Description:
Reads 'length' #of length from register 'reg'
void SPI_Read_Buf(UINT8 reg, UINT8 *pBuf, UINT8 length)
UINT8 status,byte_ctr;
CSN = 0; // Set CSN l
status = SPI_RW(reg); // Select register to write, and read status UINT8
for(byte_ctr=0;byte_ctr<length;byte_ctr++)
pBuf[byte_ctr] = SPI_RW(0); // Perform SPI_RW to read UINT8 from BK2423
CSN = 1; // Set CSN high again
Function: SPI_Write_Buf();
Description:
Writes contents of buffer '*pBuf' to BK2423
void SPI_Write_Buf(UINT8 reg, UINT8 *pBuf, UINT8 length)
UINT8 byte_ctr;
CSN = 0; // Set CSN low, init SPI tranaction
op_status = SPI_RW(reg); // Select register to write to and read status UINT8
for(byte_ctr=0; byte_ctr<length; byte_ctr++) // then write all UINT8 in buffer(*pBuf)
SPI_RW(*pBuf++);
Function: SwitchToRxMode();
Description:
switch to Rx mode
void SwitchToRxMode()
xdata UINT8 value;
SPI_Write_Reg(FLUSH_RX,0);//flush Rx
value=SPI_Read_Reg(STATUS); // read register STATUS's value
SPI_Write_Reg(WRITE_REG|STATUS,value);// clear RX_DR or TX_DS or MAX_RT interrupt flag
CE=0;
value=SPI_Read_Reg(CONFIG); // read register CONFIG's value
//PRX
value=value|0x01;//set bit 1
SPI_Write_Reg(WRITE_REG | CONFIG, value); // Set PWR_UP bit, enable CRC(2 length) & Prim:RX. RX_DR enabled..
CE=1;
Function: SwitchToTxMode();
Description:
switch to Tx mode
void SwitchToTxMode()
xdata UINT8 value;
SPI_Write_Reg(FLUSH_TX,0);//flush Tx
CE=0;
//PTX
value=value&0xfe;//set bit 1
CE=1;
Function: SwitchCFG();
Description:
access switch between Bank1 and Bank0
Parameter:
_cfg 1:register bank1
0:register bank0
Return:
None
void SwitchCFG(char _cfg)//1:Bank1 0:Bank0
UINT8 Tmp;
Tmp=SPI_Read_Reg(7);
Tmp=Tmp&0x80;
if( ( (Tmp)&&(_cfg==0) )
||( ((Tmp)==0)&&(_cfg) ) )
SPI_Write_Reg(ACTIVATE_CMD,0x53);
Function: SetChannelNum();
Description:
set channel number
void SetChannelNum(UINT8 ch)
SPI_Write_Reg((UINT8)(WRITE_REG|5),(UINT8)(ch));
// BK2423 initialization //
Function: BK2423_Initialize();
Description:
void BK2423_Initialize()
INT8 i,j;
UINT8 WriteArr[4];
DelayMs(100);//delay more than 50ms.
SwitchCFG(0);
//********************Write Bank0 register******************
for(i=20;i>=0;i--)
SPI_Write_Reg((WRITE_REG|Bank0_Reg[0]),Bank0_Reg[1]);
//reg 10 - Rx0 addr
SPI_Write_Buf((WRITE_REG|10),RX0_Address,5);
//REG 11 - Rx1 addr
SPI_Write_Buf((WRITE_REG|11),RX1_Address,5);
//REG 16 - TX addr
SPI_Write_Buf((WRITE_REG|16),RX0_Address,5);
// printf("\nEnd Load Reg");
i=SPI_Read_Reg(29);
if(i==0) // i!=0 showed that chip has been actived.so do not active again.
SPI_Write_Reg(ACTIVATE_CMD,0x73);// Active
for(i=22;i>=21;i--)
//********************Write Bank1 register******************
SwitchCFG(1);
for(i=0;i<=8;i++)//reverse
for(j=0;j<4;j++)
WriteArr[j]=(Bank1_Reg0_13>>(8*(j) ) )&0xff;
SPI_Write_Buf((WRITE_REG|i),&(WriteArr[0]),4);
for(i=9;i<=13;i++)
for(j=0;j<4;j++)
WriteArr[j]=(Bank1_Reg0_13>>(8*(3-j) ) )&0xff;
SPI_Write_Buf((WRITE_REG|14),&(Bank1_Reg14[0]),11);
//toggle REG4<25,26>
for(j=0;j<4;j++)
WriteArr[j]=(Bank1_Reg0_13[4]>>(8*(j) ) )&0xff;
WriteArr[0]=WriteArr[0]|0x06;
SPI_Write_Buf((WRITE_REG|4),&(WriteArr[0]),4);
WriteArr[0]=WriteArr[0]&0xf9;
DelayMs(10);
//********************switch back to Bank0 register access******************
SwitchCFG(0);
SwitchToRxMode();//switch to RX mode
Function: DelayMs();
Description:
delay ms,please implement this function according to your MCU.
void DelayMs(UINT16 ms)
