KL25Z128xxx SRAM有16KB,前面4KB和后面的12KB地址不是连续的,当前的MDK环境下需要修改分散加载文件才能支持4KB使用。当我修改完成后,编译出现以下提示(红色部分)
程序可以正常运行,但是总感觉什么地方有问题。。。
Build target 'MKL25Z128xxx4'
compiling app_es201.c...
linking...
.\Project_Settings\Linker_Files\ProcessorExpert.scf(49): warning: L6314W: No section matches pattern *.o(RESET).
Program Size: Code=30144 RO-data=1204 RW-data=52 ZI-data=11556
".\UV4Build\MQX_freedom.axf" - 0 Errors, 1 Warning(s).
Load "F:\\飞思卡尔\\work\\SVN\\UV4Build\\MQX_freedom.axf"
No Algorithm found for: 1FFFF000H - 1FFFF00BH
Partial Erase Done (areas with no algorithms skipped!)
Partial Programming Done (areas with no algorithms skipped!)
Partial Verify OK (areas with no algorithms skipped!)
Application running ... |
