其实,并不是这几个包没有安装,而是路径不对,
需要修改usr/local/ltib/bin/Ltibutils.pm文件第588行将
glob('/usr/lib/libz.so*;), 修改为glob('/usr/lib/i386-linux-gnu/libz.so*'),
glob('/lib/libz.so*'), 修改为glob('/lib/i386-linux-gnu/libz.so*'),
将第569行的
sub { -f '/usr/lib/libm.so'}, 修改为 sub {-f '/usr/lib/i386-linux-gnu/libm.so' },
将580行的
sub { -f '/usr/lib/rpm/rpmb' },更改成sub { -f '/usr/lib/rpm/rpmrc' },
然后修改
as root using the command "/usr/sbin/visudo",
and add the following line in the User privilege section:
username ALL = NOPASSWD: /usr/bin/rpm, /opt/freescale/ltib/usr/bin/rpm
再执行"./ltib"编译 |
