求怎么回事,第1、3、4个频率正常,唯独频率从1K到5K左右不正常
- // 名称: 用TIMER1输入捕获功能设计的频率计
- // 说明: 本例运行时,切换不同的频率输入,然后按下K1按键,数码管上将
- // 显示当前频率值.两次捕获的时间差值即为当前输入频率的周期,
- // 周期倒数即可得到当前频率.
- #define F_CPU 1000000UL //1M晶振
- #include <avr/io.h>
- #include <avr/interrupt.h>
- #include <util/delay.h>
- #define INT8U unsigned char
- #define INT16U unsigned int
- //共阴数码管0-9的数字编码,最后一位为黑屏
- const INT8U SEG_CODE[] =
- {0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x00};
- //分解后的待显示数位
- INT8U Display_Buffer[] = {0,0,0,0};
- //连续两次捕获计数变量
- INT16U CAPi=0,CAPj=0;
- volatile INT16U Buffer[6] = {0};
- volatile unsigned long SS = 0;
- volatile INT8U j=0;
- // 数码管显示频率
- void Show_FRQ_ON_DSY()
- INT8U i=0;
- for( i =0;i<4;i++)
- PORTB = ~_BV(i);
- PORTA = SEG_CODE[ Display_Buffer[i] ];
- if(i==0)PORTA |= 0x80;
- _delay_ms(2);
- // 主程序
- int main()
- INT8U LastKey = 0xff;
- DDRA = 0xff;
- DDRB = 0xff;
- DDRC = 0x00; PORTC = 0xff;
- DDRD = 0x00; PORTD = 0xff;
- TCCR1B = _BV(ICNC1) | _BV(ICES1); //输入捕获噪声音消除,ICP上升沿触发捕获,分频系数1(1MHz,1us触发一次)
- sei();
- while(1)
- if( LastKey != PINC)
- TIMSK = _BV(TICIE1);
- TCCR1B |= 0x01;
- LastKey = PINC;
- Show_FRQ_ON_DSY();
- // T1输入捕获中断子程序
- ISR (TIMER1_CAPT_vect)
- INT8U i,k;
- INT16U temp=0;
- if(CAPi == 0 )CAPi = ICR1;
- else
- CAPj = ICR1 - CAPi;
- Buffer[j] =1000000UL/ CAPj;
- j++;
- if(j==6)
- j=0;
- TIMSK = 0x00;
- TCCR1B &= 0xf8;
- for(k=0;k<6;k++) //采样6次,取中间4个值求平均
- for(i=0;i<5-k;i++)
- if(Buffer[i]>Buffer[i+1])
- temp = Buffer[i];
- Buffer[i] = Buffer[i+1];
- Buffer[i+1] = temp;
- SS = (Buffer[1] + Buffer[2] + Buffer[3]+ Buffer[4] )/4;
- for(i=3;i!= 0xff;i--)
- Display_Buffer[i] = SS%10;
- SS /= 10;
- TCNT1 = CAPi = CAPj = 0;
复制代码 |
