谷歌上找了代码,但是没有说使用模式匹配接收,现在用的是混乱接收模式,导致所有数据都接收,会造成网卡接收出现问题,我用中断接收,会出现无法进入中断的现象,也就导致数据无法接收。网卡的发送还是正常。
以下是谷歌上的代码:并未开启混乱模式,不知道他怎么做接收处理的。
void enc424j600Init(void) {
//Set default bank
currentBank = 0;
// release CS
ENC424J600_CONTROL_PORT |= (1 << ENC424J600_CONTROL_CS);
sbi(ENC424J600_CONTROL_DDR, ENC424J600_CONTROL_CS);
sbi(ENC424J600_CONTROL_PORT, ENC424J600_CONTROL_CS);
sbi(ENC424J600_SPI_PORT, ENC424J600_SPI_SCK); // set SCK hi
sbi(ENC424J600_SPI_DDR, ENC424J600_SPI_SCK); // set SCK as output
cbi(ENC424J600_SPI_DDR, ENC424J600_SPI_MISO); // set MISO as input
sbi(ENC424J600_SPI_DDR, ENC424J600_SPI_MOSI); // set MOSI as output
sbi(ENC424J600_SPI_DDR, ENC424J600_SPI_SS); // SS must be output for Master mode to work
// initialize SPI interface
// master mode
sbi(SPCR, MSTR);
// select clock phase positive-going in middle of data
cbi(SPCR, CPOL);
// Data order MSB first
cbi(SPCR, DORD);
// switch to f/4 2X = f/2 bitrate
cbi(SPCR, SPR0);
cbi(SPCR, SPR1);
sbi(SPSR, SPI2X);
// enable SPI
sbi(SPCR, SPE);
// Perform a reliable reset
enc424j600SendSystemReset();
// Initialize RX tracking variables and other control state flags
nextPacketPointer = RXSTART;
// Set up TX/RX/UDA buffer addresses
enc424j600WriteReg(ETXST, TXSTART);
enc424j600WriteReg(ERXST, RXSTART);
enc424j600WriteReg(ERXTAIL, RAMSIZE - 2);
enc424j600WriteReg(EUDAST, USSTART);
enc424j600WriteReg(EUDAND, USEND);
// If promiscuous mode is set, than allow accept all packets
#ifdef PROMISCUOUS_MODE
enc424j600WriteReg(ERXFCON, (ERXFCON_CRCEN | ERXFCON_RUNTEN | ERXFCON_UCEN | ERXFCON_NOTMEEN | ERXFCON_MCEN));
// Set PHY Auto-negotiation to support 10BaseT Half duplex,
// 10BaseT Full duplex, 100BaseTX Half Duplex, 100BaseTX Full Duplex,
// and symmetric PAUSE capability
enc424j600WritePHYReg(PHANA, PHANA_ADPAUS0 | PHANA_AD10FD | PHANA_AD10 | PHANA_AD100FD | PHANA_AD100 | PHANA_ADIEEE0);
// Enable RX packet reception
enc424j600BFSReg(ECON1, ECON1_RXEN);
