发表于 2014-1-13 10:55:50
源代码来源于网路,感谢共享。稍作修改,去掉了对文件系统的判定。
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Microsoft.Win32.SafeHandles;
using System.Runtime.InteropServices;
namespace whjcns
class SDUtils
private const uint GENERIC_READ = 0x80000000;
private const uint GENERIC_WRITE = 0x40000000;
private const uint FILE_SHARE_READ = 0x00000001;
private const uint FILE_SHARE_WRITE = 0x00000002;
private const uint OPEN_EXISTING = 3;
[DllImport("kernel32.dll", SetLastError = true)]
private static extern SafeFileHandle CreateFileA(string lpFileName, uint dwDesiredAccess, uint dwShareMode, IntPtr lpSecurityAttributes, uint dwCreationDisposition, uint dwFlagsAndAttributes, IntPtr hTemplateFile);
private System.IO.FileStream _DriverStream;
private long _SectorLength = 0;
private SafeFileHandle _DriverHandle;
/// <summary>
/// 扇区数
/// </summary>
public long SectorLength { get { return _SectorLength; } }
/// <summary>
/// 获取磁盘扇区信息
/// </summary>
/// <param name="DriverName">G:</param>
public SDUtils(string DriverName)
if (DriverName == null && DriverName.Trim().Length == 0) return;
_DriverHandle = CreateFileA("\\\\.\\" + DriverName.Trim(), GENERIC_READ | GENERIC_WRITE, FILE_SHARE_READ | FILE_SHARE_WRITE, IntPtr.Zero, OPEN_EXISTING, 0, IntPtr.Zero);
_DriverStream = new System.IO.FileStream(_DriverHandle, System.IO.FileAccess.ReadWrite);
GetSectorCount();
/// <summary>
/// 扇区显示转换
/// </summary>
/// <param name="SectorBytes">扇区长度512</param>
/// <returns>EB 52 90 ......55 AA</returns>
public string Byte2String(byte[] SectorBytes)
if (SectorBytes==null || SectorBytes.Length != 512) return "Content is empty";
StringBuilder ReturnText = new StringBuilder();
int RowCount = 0;
for (int i = 0; i != 512; i++)
ReturnText.Append(SectorBytes[i].ToString("X02") + " ");
if (RowCount == 15)
ReturnText.Append("\r\n");
RowCount = -1;
RowCount++;
return ReturnText.ToString();
/// <summary>
/// 获取扇区数
/// </summary>
private void GetSectorCount()
if (_DriverStream == null) return;
_DriverStream.Position = 0;
byte[] ReturnByte = new byte[512];
_DriverStream.Read(ReturnByte, 0, 512); //获取第1扇区
if (ReturnByte[0] == 0xEB && ReturnByte[1] == 0x58) //DOS的好象都是32位
_SectorLength = (long)BitConverter.ToInt32(new byte[] { ReturnByte[32], ReturnByte[33], ReturnByte[34], ReturnByte[35] }, 0);
if (ReturnByte[0] == 0xEB && ReturnByte[1] == 0x52) //NTFS好象是64位
_SectorLength = BitConverter.ToInt64(new byte[] { ReturnByte[40], ReturnByte[41], ReturnByte[42], ReturnByte[43], ReturnByte[44], ReturnByte[45], ReturnByte[46], ReturnByte[47] }, 0);
/// <summary>
/// 读一个扇区
/// </summary>
/// <param name="SectorIndex">扇区号</param>
/// <returns>如果扇区数字大于分区信息的扇区数返回NULL</returns>
public byte[] ReadSector(long SectorIndex)
//if (SectorIndex > _SectorLength)
// return null;
_DriverStream.Position = SectorIndex * 512;
_DriverStream.Read(ReturnByte, 0, 512); //获取扇区
return ReturnByte;
/// <summary>
/// 写入数据
/// </summary>
/// <param name="SectorIndex">扇区位置</param>
public void WriteSector(byte[] SectorBytes, long SectorIndex)
if (SectorBytes.Length != 512) return;
if (SectorIndex > _SectorLength) return;
_DriverStream.Write(SectorBytes, 0, 512); //写入扇区
/// <summary>
/// 关闭
/// </summary>
public void Close()
_DriverStream.Close();
